  3. 主机并行运算问题
主机并行运算问题
36 帖子 4 发布者 29.8k 浏览
  • 青 离线
    青 离线
    青山
        \\/     M anipulation  |
    Build  : 7-3bcbaf946ae9
    Exec   : pisoFoam -parallel
    Date   : Jan 18 2022
    Time   : 10:22:57
    Host   : "ps"
    PID    : 4116
    I/O    : uncollated
    Case   : /home/ps/OpenFoam/benchMark/core_16
    nProcs : 16
    Slaves :
    15
    "ps.4117"
    "ps.4118"
    "ps.4119"
    "ps.4120"
    "ps.4121"
    "ps.4122"
    "ps.4123"
    "ps.4124"
    "ps.4125"
    "ps.4126"
    "ps.4127"
    "ps.4128"
    "ps.4129"
    "ps.4130"
    "ps.4131"
    Pstream initialized with:
       floatTransfer      : 0
       nProcsSimpleSum    : 0
       commsType          : nonBlocking
       polling iterations : 0
    fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
    Create time
    Create mesh for time = 0
    Reading field p
    Reading field U
    Selecting laminar stress model Stokes
    No MRF models present
    Creating finite volume options from "constant/fvOptions"
    Selecting finite volume options model type meanVelocityForce
       Source: momentumSource
       - selecting all cells
       - selected 2097152 cell(s) with volume 10
       Initial pressure gradient = 0
    Starting time loop
    fieldAverage fieldAverage1:
       Starting averaging at time 0
    Time = 0.1
    Courant Number mean: 0.731999 max: 1.22083
    GAMG:  Solving for p, Initial residual = 0.629082, Final residual = 0.00572723, No Iterations 3
    time step continuity errors : sum local = 1.06089e-05, global = -1.10517e-20, cumulative = -1.10517e-20
    Pressure gradient source: uncorrected Ubar = 0.133489, pressure gradient = 0.000115089
    GAMG:  Solving for p, Initial residual = 0.0561029, Final residual = 0.000467237, No Iterations 4
    time step continuity errors : sum local = 1.28615e-06, global = -3.71636e-20, cumulative = -4.82152e-20
    Pressure gradient source: uncorrected Ubar = 0.133489, pressure gradient = 0.000117874
    GAMG:  Solving for p, Initial residual = 0.0152276, Final residual = 9.92056e-07, No Iterations 30
    time step continuity errors : sum local = 2.62628e-09, global = -2.27344e-20, cumulative = -7.09497e-20
    Pressure gradient source: uncorrected Ubar = 0.133489, pressure gradient = 0.000117425
    ExecutionTime = 5.66 s  ClockTime = 6 s
    Time = 0.2
    Courant Number mean: 0.731698 max: 1.1641
    GAMG:  Solving for p, Initial residual = 0.758295, Final residual = 0.00701504, No Iterations 3
    time step continuity errors : sum local = 9.27309e-06, global = -2.6639e-13, cumulative = -2.66391e-13
    Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 0.000119203
    GAMG:  Solving for p, Initial residual = 0.0736589, Final residual = 0.000696871, No Iterations 6
    time step continuity errors : sum local = 6.00649e-07, global = -2.6639e-13, cumulative = -5.32781e-13
    Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 0.000117205
    GAMG:  Solving for p, Initial residual = 0.0148478, Final residual = 9.08119e-07, No Iterations 43
    time step continuity errors : sum local = 7.91859e-10, global = -2.66391e-13, cumulative = -7.99172e-13
    Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 0.00011676
    ExecutionTime = 11.78 s  ClockTime = 12 s
    Time = 0.3
    Courant Number mean: 0.731607 max: 1.18248
    GAMG:  Solving for p, Initial residual = 0.476883, Final residual = 0.00315427, No Iterations 4
    time step continuity errors : sum local = 2.37198e-06, global = -3.08998e-13, cumulative = -1.10817e-12
    Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 0.000119187
    GAMG:  Solving for p, Initial residual = 0.0807666, Final residual = 0.000618685, No Iterations 5
    time step continuity errors : sum local = 3.9245e-07, global = -3.08998e-13, cumulative = -1.41717e-12
    Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 0.000117229
    GAMG:  Solving for p, Initial residual = 0.018049, Final residual = 8.80851e-07, No Iterations 45
    time step continuity errors : sum local = 5.48708e-10, global = -3.08998e-13, cumulative = -1.72617e-12
    Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 0.00011678
    ExecutionTime = 18.04 s  ClockTime = 18 s
    Time = 0.4
    Courant Number mean: 0.731599 max: 1.17717
    GAMG:  Solving for p, Initial residual = 0.1167, Final residual = 0.000969819, No Iterations 5
    time step continuity errors : sum local = 6.01509e-07, global = -3.34128e-13, cumulative = -2.06029e-12
    Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 0.00011923
    GAMG:  Solving for p, Initial residual = 0.0809347, Final residual = 0.000631617, No Iterations 5
    time step continuity errors : sum local = 3.90613e-07, global = -3.34128e-13, cumulative = -2.39442e-12
    Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 0.00011725
    GAMG:  Solving for p, Initial residual = 0.0184664, Final residual = 6.81898e-07, No Iterations 47
    time step continuity errors : sum local = 4.15027e-10, global = -3.34128e-13, cumulative = -2.72855e-12
    Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 0.000116801
    ExecutionTime = 24.52 s  ClockTime = 25 s
    Time = 0.5
    Courant Number mean: 0.731615 max: 1.19242
    GAMG:  Solving for p, Initial residual = 0.108148, Final residual = 0.00095674, No Iterations 5
    time step continuity errors : sum local = 5.80503e-07, global = -3.47575e-13, cumulative = -3.07612e-12
    Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 0.000119271
    GAMG:  Solving for p, Initial residual = 0.0827827, Final residual = 0.000641763, No Iterations 5
    time step continuity errors : sum local = 3.89751e-07, global = -3.47575e-13, cumulative = -3.4237e-12
    Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 0.000117272
    GAMG:  Solving for p, Initial residual = 0.0189672, Final residual = 9.67464e-07, No Iterations 42
    time step continuity errors : sum local = 5.75885e-10, global = -3.47575e-13, cumulative = -3.77127e-12
    Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 0.000116822
    ExecutionTime = 30.63 s  ClockTime = 31 s
    星 C 2 条回复 最后回复
    从log上看没问题,不清楚为什么这么慢,之前他们别人也遇到过类似这种问题。所以买CFD服务器最好实测一下。
    @李东岳 所以我之前问他们内存是怎么搞的,一般情况下,这玩意cpu肯定没问题,硬盘应该也不是瓶颈,内存是不是走的多通道模式是有可能是限制,但是看了一下,好像也是多通道的。原生Ubuntu,不是走虚拟机什么的,Case的log看起来也没什么问题。 也不是多节点,都是本机的,也就没啥能慢的情况了啊。。而且这个应该不是自己弄的组装机吧?所以真心看不出来咋回事,重装一下系统看看好了~ 说不准神奇的解决了,或者试试老ubuntu ub18啊 ub16什么的
    在 中回复了 青山 最后由 编辑
    @青山 最简单粗暴的说,你们的内存条插满主板了么?或者说内存条有没有隔一个插一个,插了一半?没自己装过cluster,但是这玩意基本原理都是通用的。。支持8通道的话,8根插到对应的通道上就好。。他也是8根。完全看不出来为什么
    青 1 条回复 最后回复
    在 中回复了 青山 最后由 编辑
    @青山 我记得mpi官网还是哪里可以找到非常简单的并行测试程序,类似于输出很多“Hello World”这种。你这个问题感觉不仅仅是openfoam的,可能任何一个并行的程序你调用都会出现无法并行的情况?
    青 1 条回复 最后回复
  • 青 离线
    青 离线
    青山
    @cccrrryyy 并行是没问题的,就是速度太慢,跟没并行差的不多
  • 青 离线
    青 离线
    青山
    @星星星星晴 两个cpu槽插了一个cup,然后在cpu旁边的8个内存插槽都插了,搞不懂啥问题
    在 中回复了 青山 最后由 编辑
    @青山 之前有人从别人家买服务器发生过类似问题,但都在外地。如果在北京的话,可以让我学生看看你那个机器,我也好奇怎么回事。
    青 1 条回复 最后回复
  • 青 离线
    青 离线
    青山
    @李东岳 感谢东岳老师,机子在杭州。超微的主板,买来都是配好的,一直没测试,最近测了几个案例才发现问题。标准算例里面8核的并行速度比16核还快我是真想不通:136:
    C 李东岳李 2 条回复 最后回复
    在 中回复了 青山 最后由 编辑
    @青山 同在杭州,看来杭州现在做CFD多起来了啊:140:
    在 中回复了 青山 最后由 编辑
    @青山 你这个现在只能是重新做系统试一下。虽然我感觉基本不会有改变。感觉不是软件的问题。很奇怪怎么回事。
    另外就是你们可以把机器发北京过来,现在学生都放假了,只能我在春节期间在硬件层面给你们debug一下。但是需要你们老师出一定的费用。如果要这么搞的话,可以邮件联系我。
    青 1 条回复 最后回复
  • 青 离线
    青 离线
    青山
    @李东岳 感谢东岳老师,打算先找售后过来看看,如果他们说硬件没问题,换系统也没有改善的话,年后可能会麻烦东岳老师帮忙:146: 先提前向东岳老师和CFD中文网的朋友们问声新年好!
    在 中回复了 青山 最后由 编辑
    @青山 他们做服务器,你跑CFD算例跟他们说对比结果,估计他们彻底懵掉了,哈哈。
    谢谢,新年好,剩下10天过年了:high: :high:
