  3. reactingfoam算了4步就自动停止了,出现了什么问题吗
1 帖子 1 发布者 600 浏览
  • 钟 离线
    钟 离线
    钟余
    \ / F ield OpenFOAM: The Open Source CFD Toolbox
    \ / O peration Website: https://openfoam.org
    \ / A nd Version: 6
    \/ M anipulation
    Build : 6-fa1285188035
    Exec : reactingFoam
    Date : Dec 24 2024
    Time : 10:45:39
    Host : "DESKTOP-MGCJK2F"
    PID : 3256
    I/O : uncollated
    Case : /home/mywsl/OpenFOAM/mywsl-6/run/turbulent
    nProcs : 1
    fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
    Create time
    Create mesh for time = 0
    PIMPLE: No convergence criteria found
    PIMPLE: Operating solver in PISO mode
    Reading thermophysical properties
    Selecting thermodynamics package
    type hePsiThermo;
    mixture reactingMixture;
    transport sutherland;
    thermo janaf;
    energy sensibleEnthalpy;
    equationOfState perfectGas;
    specie specie;
    Selecting chemistryReader foamChemistryReader
    elements not defined in "/home/mywsl/OpenFOAM/mywsl-6/run/turbulent/constant/chem_Li_2007"
    Reading field U
    Creating turbulence model.
    Selecting turbulence model type RAS
    Selecting RAS turbulence model kEpsilon
    kEpsilonCoeffs
    Prt 0.85;
    Cmu 0.09;
    C1 1.44;
    C2 1.92;
    C3 0;
    sigmak 1;
    sigmaEps 1.3;
    Creating reaction model
    Selecting combustion model EDC
    Selecting chemistry solver
    solver ode;
    method standard;
    StandardChemistryModel: Number of species = 9 and reactions = 21
    Selecting ODE solver seulex
    using integrated reaction rate
    Creating field dpdt
    Creating field kinetic energy K
    No MRF models present
    Courant Number mean: 0 max: 0
    Starting time loop
    deltaT = 1.111111111e-05
    Time = 1.11111e-05
    diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
    DILUPBiCGStab: Solving for Ux, Initial residual = 1, Final residual = 7.237527843e-08, No Iterations 1
    DILUPBiCGStab: Solving for Uy, Initial residual = 1, Final residual = 6.496027629e-08, No Iterations 1
    DILUPBiCGStab: Solving for H, Initial residual = 1, Final residual = 1.249524693e-08, No Iterations 1
    DILUPBiCGStab: Solving for H2, Initial residual = 0.9999999548, Final residual = 1.249524636e-08, No Iterations 1
    DILUPBiCGStab: Solving for O, Initial residual = 1, Final residual = 1.249524693e-08, No Iterations 1
    DILUPBiCGStab: Solving for OH, Initial residual = 1, Final residual = 1.249524693e-08, No Iterations 1
    DILUPBiCGStab: Solving for H2O, Initial residual = 1, Final residual = 1.249524693e-08, No Iterations 1
    DILUPBiCGStab: Solving for O2, Initial residual = 0.9999997617, Final residual = 1.249524395e-08, No Iterations 1
    DILUPBiCGStab: Solving for HO2, Initial residual = 1, Final residual = 1.249524693e-08, No Iterations 1
    DILUPBiCGStab: Solving for H2O2, Initial residual = 1, Final residual = 1.249524693e-08, No Iterations 1
    DILUPBiCGStab: Solving for h, Initial residual = 0.001698464143, Final residual = 6.399191709e-07, No Iterations 1
    min/max(T) = 300, 1800.356388
    DICPCG: Solving for p, Initial residual = 0.8154141575, Final residual = 0.05901504271, No Iterations 4
    time step continuity errors : sum local = 0.1648808522, global = -0.04664958196, cumulative = -0.04664958196
    DICPCG: Solving for p, Initial residual = 0.5937630302, Final residual = 9.1448632e-07, No Iterations 49
    time step continuity errors : sum local = 1.031207163e-06, global = 1.108666077e-07, cumulative = -0.0466494711
    DILUPBiCGStab: Solving for epsilon, Initial residual = 0.7898692099, Final residual = 7.356031497e-07, No Iterations 13
    bounding epsilon, min: -57.68897069 max: 199.8018274 average: 2.853407683
    DILUPBiCGStab: Solving for k, Initial residual = 1, Final residual = 7.436499697e-07, No Iterations 14
    bounding k, min: -53.76693743 max: 137.3801042 average: 1.662759794
    ExecutionTime = 7.11 s ClockTime = 7 s
    Courant Number mean: 0.3263677773 max: 38.86161238
    deltaT = 5.71632726e-08
    Time = 1.11683e-05
    DILUPBiCGStab: Solving for Ux, Initial residual = 0.01088173554, Final residual = 9.291750018e-07, No Iterations 2
    DILUPBiCGStab: Solving for Uy, Initial residual = 0.126974428, Final residual = 5.413457541e-07, No Iterations 3
    DILUPBiCGStab: Solving for H, Initial residual = 0.05031914993, Final residual = 2.526806224e-07, No Iterations 3
    DILUPBiCGStab: Solving for H2, Initial residual = 0.04988384318, Final residual = 2.536567037e-07, No Iterations 3
    DILUPBiCGStab: Solving for O, Initial residual = 0.05023601744, Final residual = 2.528851275e-07, No Iterations 3
    DILUPBiCGStab: Solving for OH, Initial residual = 0.0498739039, Final residual = 2.53709804e-07, No Iterations 3
    DILUPBiCGStab: Solving for H2O, Initial residual = 0.04983585131, Final residual = 2.537599816e-07, No Iterations 3
    DILUPBiCGStab: Solving for O2, Initial residual = 0.04987406878, Final residual = 2.536836372e-07, No Iterations 3
    DILUPBiCGStab: Solving for HO2, Initial residual = 0.04887920295, Final residual = 2.557918423e-07, No Iterations 3
    DILUPBiCGStab: Solving for H2O2, Initial residual = 0.04849527326, Final residual = 2.565684649e-07, No Iterations 3
    DILUPBiCGStab: Solving for h, Initial residual = 0.05497148043, Final residual = 4.9437153e-07, No Iterations 3
    min/max(T) = 299.9248087, 1796.462561
    DICPCG: Solving for p, Initial residual = 0.01518365283, Final residual = 3.016271454e-08, No Iterations 1
    time step continuity errors : sum local = 6.870692989e-09, global = -5.333936149e-09, cumulative = -0.04664947643
    DICPCG: Solving for p, Initial residual = 0.0003488105302, Final residual = 1.108179983e-09, No Iterations 1
    time step continuity errors : sum local = 2.557155586e-10, global = 8.320508309e-11, cumulative = -0.04664947635
    DILUPBiCGStab: Solving for epsilon, Initial residual = 0.1451083224, Final residual = 2.148726213e-07, No Iterations 2
    DILUPBiCGStab: Solving for k, Initial residual = 0.8290663092, Final residual = 5.98405794e-08, No Iterations 4
    ExecutionTime = 8.97 s ClockTime = 9 s
    Courant Number mean: 0.0013035774 max: 0.1228067562
    deltaT = 6.644108124e-08
    Time = 1.12347e-05
    DILUPBiCGStab: Solving for Ux, Initial residual = 0.1832008417, Final residual = 3.515359245e-07, No Iterations 8
    DILUPBiCGStab: Solving for Uy, Initial residual = 0.8416763107, Final residual = 7.756203776e-07, No Iterations 10
    DILUPBiCGStab: Solving for H, Initial residual = 0.4428609204, Final residual = 9.062138129e-07, No Iterations 9
    DILUPBiCGStab: Solving for H2, Initial residual = 0.4410214426, Final residual = 9.736737868e-07, No Iterations 9
    DILUPBiCGStab: Solving for O, Initial residual = 0.4424908421, Final residual = 9.30398611e-07, No Iterations 9
    DILUPBiCGStab: Solving for OH, Initial residual = 0.4409439717, Final residual = 9.745009796e-07, No Iterations 9
    DILUPBiCGStab: Solving for H2O, Initial residual = 0.4408222366, Final residual = 9.738422502e-07, No Iterations 9
    DILUPBiCGStab: Solving for O2, Initial residual = 0.4409741964, Final residual = 9.739327596e-07, No Iterations 9
    DILUPBiCGStab: Solving for HO2, Initial residual = 0.4368143603, Final residual = 7.794393661e-07, No Iterations 9
    DILUPBiCGStab: Solving for H2O2, Initial residual = 0.4352225269, Final residual = 9.850169941e-07, No Iterations 9
    DILUPBiCGStab: Solving for h, Initial residual = 0.4603404275, Final residual = 8.710686777e-07, No Iterations 10
    min/max(T) = 299.9999982, 1791.283236
    DICPCG: Solving for p, Initial residual = 0.04989128258, Final residual = 1.728078903e-08, No Iterations 1
    time step continuity errors : sum local = 3.9720677e-09, global = -2.805246459e-09, cumulative = -0.04664947915
    DICPCG: Solving for p, Initial residual = 0.00040507004, Final residual = 2.635572617e-10, No Iterations 1
    time step continuity errors : sum local = 6.291142477e-11, global = 5.449968679e-11, cumulative = -0.0466494791
    DILUPBiCGStab: Solving for epsilon, Initial residual = 0.2709179929, Final residual = 2.790707667e-07, No Iterations 9
    DILUPBiCGStab: Solving for k, Initial residual = 0.6253639963, Final residual = 3.507848237e-07, No Iterations 10
    ExecutionTime = 10.81 s ClockTime = 11 s
    Courant Number mean: 0.0008942027266 max: 0.05529325678
    deltaT = 7.968158396e-08
    Time = 1.13144e-05
    DILUPBiCGStab: Solving for Ux, Initial residual = 0.06593954665, Final residual = 3.351747253e-07, No Iterations 8
    DILUPBiCGStab: Solving for Uy, Initial residual = 0.4102152305, Final residual = 9.318726704e-07, No Iterations 10
    DILUPBiCGStab: Solving for H, Initial residual = 0.2892697203, Final residual = 5.28621965e-07, No Iterations 9
    DILUPBiCGStab: Solving for H2, Initial residual = 0.2624968155, Final residual = 4.376897291e-07, No Iterations 9
    DILUPBiCGStab: Solving for O, Initial residual = 0.2808888368, Final residual = 5.574822147e-07, No Iterations 9
    DILUPBiCGStab: Solving for OH, Initial residual = 0.2591248329, Final residual = 4.295608139e-07, No Iterations 9
    DILUPBiCGStab: Solving for H2O, Initial residual = 0.2597666461, Final residual = 4.522225416e-07, No Iterations 9
    DILUPBiCGStab: Solving for O2, Initial residual = 0.2612620687, Final residual = 4.395858975e-07, No Iterations 9
    DILUPBiCGStab: Solving for HO2, Initial residual = 0.2220485989, Final residual = 5.99379148e-07, No Iterations 9
    DILUPBiCGStab: Solving for H2O2, Initial residual = 0.1820866327, Final residual = 6.019580413e-07, No Iterations 10
    DILUPBiCGStab: Solving for h, Initial residual = 0.09990726406, Final residual = 5.829150064e-07, No Iterations 10
    min/max(T) = 299.9999961, 1784.763549
    DICPCG: Solving for p, Initial residual = 0.02262674874, Final residual = 3.398546862e-08, No Iterations 1
    time step continuity errors : sum local = 8.084807953e-09, global = -4.286910994e-09, cumulative = -0.04664948339
    DICPCG: Solving for p, Initial residual = 0.0001704309813, Final residual = 3.621876029e-10, No Iterations 1
    time step continuity errors : sum local = 8.790648795e-11, global = 1.74305778e-11, cumulative = -0.04664948337
    DILUPBiCGStab: Solving for epsilon, Initial residual = 0.0897510291, Final residual = 6.434387951e-07, No Iterations 3
    DILUPBiCGStab: Solving for k, Initial residual = 0.2857450205, Final residual = 8.582666035e-07, No Iterations 9
    ExecutionTime = 12.45 s ClockTime = 12 s
    Courant Number mean: 0.001010967894 max: 0.05839075857
    deltaT = 9.556638249e-08
    Time = 1.141e-05
    DILUPBiCGStab: Solving for Ux, Initial residual = 0.01353903567, Final residual = 4.237016717e-07, No Iterations 6
    DILUPBiCGStab: Solving for Uy, Initial residual = 0.1965833104, Final residual = 4.895900842e-07, No Iterations 7
