  3. 使用overset计算浮体在波浪下运动时浮体运动异常(飞出去了。。)
10 帖子 4 发布者 3.4k 浏览
    wzlr2023
    本身是一个很简单的案例,二维的方箱在波浪作用下运动,使用了重叠网格,用of自带的floatingBody案例更改的,可是在计算了几步后,方箱的垂向速度振荡,最后慢慢变大,到了18次方的量级,用命令提取了部分方箱的线速度如下:
        Linear velocity: (-1.91542457151e-06 -0.00135827305279 0)
        Linear velocity: (-2.15710332077e-06 0.00111202047891 0)
        Linear velocity: (-2.41767412947e-06 0.00260261966864 0)
        Linear velocity: (0.0989209598413 -546.73550894 0)
        Linear velocity: (0.0883712548553 -340.476075085 0)
        Linear velocity: (0.0467607474571 185.838921431 -0)
        Linear velocity: (0.150364701271 -361.987863494 0)
        Linear velocity: (0.359492211159 -1874.79348536 0)
        Linear velocity: (0.318758482597 -1159.16674178 0)
        Linear velocity: (0.192438074537 630.147173239 -0)
        Linear velocity: (0.680108763246 -1456.15159395 0)
        Linear velocity: (1.49788128146 -6826.0000562 0)
        Linear velocity: (1.41386364482 -4264.12384652 0)
        Linear velocity: (0.956295248336 2153.26695027 0)
        Linear velocity: (2.51485988514 -5514.66212084 0)
        Linear velocity: (4.96732483128 -24310.1703926 0)
        Linear velocity: (4.44524314882 -14419.2509978 0)
        Linear velocity: (2.44194802246 9150.62467989 -0)
        Linear velocity: (9.1294805619 -23302.6849784 0)
        Linear velocity: (20.4668906787 -93213.9366717 0)
        Linear velocity: (19.8687629901 -55798.9112031 0)
        Linear velocity: (15.9451318073 32453.0741479 -0)
        Linear velocity: (42.6515469395 -100098.024999 0)
        Linear velocity: (80.7624597507 -357186.307128 0)
        Linear velocity: (74.8730279424 -202941.440388 0)
        Linear velocity: (40.1654968732 138596.03469 -0)
        Linear velocity: (152.128923734 -409740.496391 0)
        Linear velocity: (306.976847121 -1346764.10283 0)
        Linear velocity: (461955.202831 -941127581.331 0)
        Linear velocity: (1454171.11916 -4517414949.32 0)
        Linear velocity: (30500257.004 -23096949614.6 0)
        Linear velocity: (-2711275695.75 -9.23445027755e+12 0)
        Linear velocity: (-182076601222 2.15967217623e+14 0)
        Linear velocity: (357016928793 3.37572779872e+14 0)
        Linear velocity: (-165982717722 1.87348726017e+14 0)
        Linear velocity: (-1.80226889532e+12 -8.18857537503e+13 0)
        Linear velocity: (1.9713735909e+12 1.46486850954e+14 0)
        Linear velocity: (1.03390418821e+13 7.76730469486e+14 0)
        Linear velocity: (1.35887023944e+12 5.06243915037e+14 -0)
        Linear velocity: (-1.61594169478e+13 -1.7900944247e+14 0)
        Linear velocity: (-8.51102456927e+12 1.89480548646e+13 0)
    这时候后处理发现方箱早就飞出去了😂,我把能想到的地方都尝试了一遍,前后经过了三四天,结果还是不行,感觉已经黔驴技穷了,我把代码贴下面,希望哪位大佬能够指点一二,在下感激不尽。floatingBody.zip
    wzlr2023
    对浮体区域进行了加密,感觉网格已经足够细了,而且是一个方箱,网格应该没问题了,但是仍然还是算不了😑,仔细研究了一下log文件,感觉压强场发散了,可是我还是找不到是那里的问题。。。
    wzlr2023
    写于 最后由 wzlr2023 编辑
    附上两个时间步的输出日志,大佬们看看,能不能给点建议,谢谢大佬。
    Courant Number mean: 0.00735537390793 max: 0.583636577736
    Interface Courant Number mean: 0.000511181990626 max: 0.583636577736
    deltaT = 0.000244897959184
    Time = 0.0140204
    PIMPLE: iteration 1
    forces forces:
        rho: rho
        Not including porosity effects
    6-DoF rigid body motion
        Centre of rotation: (-8.94498440699e-07 -0.0164456747667 0)
        Centre of mass: (-8.94498440699e-07 -0.0164456747667 0)
        Orientation: (0.999999999848 -1.74335290174e-05 0 1.74335290174e-05 0.999999999848 0 0 0 1)
        Linear velocity: (-0.00293368624098 -48.7266053369 0)
        Angular velocity: (0 0 0.0260211371501)
    cellVolumeWeight : detected 2 mesh regions
        zone:0 nCells:15232
        zone:1 nCells:1408
    Marking patch-cells on zone 0
    Marking patch-cells on zone 1
    After patch analysis : nCells : 16640
        other  : 15832
        patch  : 604
        overset: 204
    Creating mesh-to-mesh addressing for region0 and region0 regions using cellVolumeWeight
    meshToMesh: Using AABBTree method
        Overlap volume: 0.00109999996229
    cellVolumeWeight : detected 3 mesh regions after overset
    Front : fraction:1 size:364
    Overset analysis : nCells : 16640
        calculated   : 15551
        interpolated : 356
        hole         : 733
    Updating StokesII wave model for patch inlet
    Updating shallowWaterAbsorption wave model for patch outlet
    Execution time for mesh.update() = 0.13 s
    smoothSolver:  Solving for alpha.water, Initial residual = 0.000249999048227, Final residual = 6.80498898311e-11, No Iterations 3
    Phase-1 volume fraction = 0.503920613005  Min(alpha.water) = -5.13127170995e-12  Max(alpha.water) = 1
    MULES: Correcting alpha.water
    Phase-1 volume fraction = 0.50392714434  Min(alpha.water) = -6.63435707652e-05  Max(alpha.water) = 1.0000000001
    smoothSolver:  Solving for alpha.water, Initial residual = 0.000249103932209, Final residual = 6.43573158857e-11, No Iterations 3
    Phase-1 volume fraction = 0.504175477931  Min(alpha.water) = -2.94680004953e-12  Max(alpha.water) = 1
    Phase-1 volume fraction = 0.504183786184  Min(alpha.water) = -0.00017940434073  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 0.000310868744296, Final residual = 3.04422030153e-06, No Iterations 58
    time step continuity errors : sum local = 3.96490246774e-05, global = -1.25171001239e-05, cumulative = -1.49775393475e-05
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.34902179705e-05, Final residual = 7.69997478103e-10, No Iterations 94
    time step continuity errors : sum local = 3.38122940616e-07, global = -3.37601268199e-07, cumulative = -1.53151406157e-05
    PIMPLE: iteration 2
    smoothSolver:  Solving for alpha.water, Initial residual = 0.00120237279896, Final residual = 3.53930819687e-09, No Iterations 4
    Phase-1 volume fraction = 0.504912181473  Min(alpha.water) = 0  Max(alpha.water) = 1
    Phase-1 volume fraction = 0.504919520521  Min(alpha.water) = -3.14841185265e-05  Max(alpha.water) = 1.00000029283
    smoothSolver:  Solving for alpha.water, Initial residual = 0.00119880798848, Final residual = 6.98825518494e-09, No Iterations 4
    Phase-1 volume fraction = 0.506154056117  Min(alpha.water) = 0  Max(alpha.water) = 1.00000002043
    Phase-1 volume fraction = 0.506165779936  Min(alpha.water) = -1.68626784389e-05  Max(alpha.water) = 1.00000005014
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.90517587839e-05, Final residual = 1.8214651533e-07, No Iterations 37
    time step continuity errors : sum local = 4.1923654332e-05, global = -3.05018962765e-05, cumulative = -4.58170368922e-05
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 6.39065412577e-06, Final residual = 7.63397439793e-10, No Iterations 75
    time step continuity errors : sum local = 1.86237192469e-07, global = -1.31816202546e-07, cumulative = -4.59488530947e-05
    ExecutionTime = 8.5 s  ClockTime = 12 s
    Courant Number mean: 0.235814158846 max: 5.37427555926
    Interface Courant Number mean: 0.00949195777417 max: 2.51708515605
    deltaT = 6.9970845481e-05
    Time = 0.0140904
    PIMPLE: iteration 1
    forces forces:
        rho: rho
        Centre of rotation: (-1.08067779962e-06 -0.019295752321 0)
        Centre of mass: (-1.08067779962e-06 -0.019295752321 0)
        Orientation: (0.999999999816 -1.92012124244e-05 0 1.92012124244e-05 0.999999999816 0 0 0 1)
        Linear velocity: (-0.00238794043494 -32.7381114221 0)
        Angular velocity: (0 0 0.0245051469086)
        zone:0 nCells:15232
        zone:1 nCells:1408
        other  : 15832
        patch  : 604
        overset: 204
        Overlap volume: 0.00109999999488
        calculated   : 15551
        interpolated : 356
        hole         : 733
    Execution time for mesh.update() = 0.14 s
    smoothSolver:  Solving for alpha.water, Initial residual = 0.000377707391121, Final residual = 6.71971274391e-09, No Iterations 2
    Phase-1 volume fraction = 0.506638642972  Min(alpha.water) = -6.04435695918e-08  Max(alpha.water) = 1.00000001498
    Phase-1 volume fraction = 0.506641278027  Min(alpha.water) = -6.02169762921e-08  Max(alpha.water) = 1.00000001498
    smoothSolver:  Solving for alpha.water, Initial residual = 0.000377799740649, Final residual = 6.97823487912e-09, No Iterations 2
    Phase-1 volume fraction = 0.507013009003  Min(alpha.water) = -2.53184572837e-09  Max(alpha.water) = 1.00000000834
    Phase-1 volume fraction = 0.507014571193  Min(alpha.water) = -2.4774186131e-09  Max(alpha.water) = 1.00000000834
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 5.44491503205e-05, Final residual = 1.57391889401e-07, No Iterations 54
    time step continuity errors : sum local = 2.51380621235e-06, global = 4.18779084622e-08, cumulative = -4.59069751863e-05
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.4141816622e-05, Final residual = 6.93894196946e-10, No Iterations 95
    time step continuity errors : sum local = 1.92459691085e-08, global = 2.85638433789e-09, cumulative = -4.59041188019e-05
    PIMPLE: iteration 2
    smoothSolver:  Solving for alpha.water, Initial residual = 0.000607091902099, Final residual = 1.08827165501e-10, No Iterations 3
    Phase-1 volume fraction = 0.506766015426  Min(alpha.water) = -3.06640979772e-09  Max(alpha.water) = 1.00000000775
    Phase-1 volume fraction = 0.506769027235  Min(alpha.water) = -2.9938628057e-09  Max(alpha.water) = 1.00000000775
    smoothSolver:  Solving for alpha.water, Initial residual = 0.000498218264715, Final residual = 9.8336652446e-09, No Iterations 2
    Phase-1 volume fraction = 0.507267924831  Min(alpha.water) = -7.65421127887e-10  Max(alpha.water) = 1.00000000487
    Phase-1 volume fraction = 0.507269775942  Min(alpha.water) = -7.50043599137e-10  Max(alpha.water) = 1.00000000486
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 9.0967455725e-06, Final residual = 8.77703691491e-08, No Iterations 28
    time step continuity errors : sum local = 2.08615978654e-06, global = 1.47998645536e-06, cumulative = -4.44241323466e-05
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.37725643056e-06, Final residual = 9.51675297182e-10, No Iterations 65
    time step continuity errors : sum local = 2.26526056154e-08, global = 1.96253692104e-09, cumulative = -4.44221698096e-05
    ExecutionTime = 8.78 s  ClockTime = 13 s
    wzlr2023
    此问题已解决,影响最大的因素已经找出,感觉就是压力场求解问题,增大PIMPLE外循环次数就正常了。。。
    zbxia
    你好,我最近也遇到类似的问题,重叠网格一个浮体,背景网格用toposet设置出一个固定结构,计算的时候我增加外循环次数为5,还是发现压力不收敛。另外背景网格可以用snappyHexMesh扣出复杂固定结构吗?我检查了所有设置,压力也是不收敛。重叠网格单个浮体,背景网格不做任何操作就没问题。谢谢回答!
    W C 2 条回复 最后回复
    wzlr2023
    在 中回复了 zbxia 最后由 编辑
    @zbxia 压力场不收敛的原因很难找,首先,我是个菜鸡,深层次的原因我没找到,只能说有些增加稳定性的大致方向,通过大量的试错来解决。其次,对于你的问题,只看你的描述我没有什么思路,只能建议你把网格质量在检查一下,因为snappyHexMesh的网格有时候其实不那么理想。
  • thegameT 离线
    thegameT 离线
    thegame
    你这个问题如果增加pimple外迭代解决的话,可能通过调小压力和速度收敛因子也能让计算稳定
    chenboyao
    在 中回复了 zbxia 最后由 编辑
    @zbxia 还是不收敛,那可能是离散格式的问题了
    zbxia
    @chenboyao @thegame @wzlr2023 谢谢大家的回答,我把背景网格画的更密了点。因为我的重叠网格(浮体)比较复杂,会有一些比较小的网格。可能和背景网格进行插值的时候导致压力发散。另外我测试了一下,背景网格好像步不可以用snappyHexMesh进行网格扣除。请问大家dynamicMeshDict中accelerationRelaxation和accelerateDamping这两个值一般都是取多少?
    chenboyao
    在 中回复了 zbxia 最后由 编辑
    @zbxia 正常建议取值0.9-1.0
