  3. 给我干蒙了
给我干蒙了
6 帖子 2 发布者 2.7k 浏览
    这在cent8下面装个openfoam,大于15个核就报错,小于15个核啥问题都没有。
    [0] #0  Foam::error::printStack(Foam::Ostream&)[1] #0  Foam::error::printStack(Foam::Ostream&)[2] #0  Foam::error::printStack(Foam::Ostream&)[3] #0  Foam::error::printStack(Foam::Ostream&)[4] #0  Foam::error::printStack(Foam::Ostream&)[5] #0  Foam::error::printStack(Foam::Ostream&)[8] #0  Foam::error::printStack(Foam::Ostream&)[9] #0  Foam::error::printStack(Foam::Ostream&)[10] #0  Foam::error::printStack(Foam::Ostream&)[12] #0  Foam::error::printStack(Foam::Ostream&)[13] #0  Foam::error::printStack(Foam::Ostream&)[14] #0  Foam::error::printStack(Foam::Ostream&)[15] #0  Foam::error::printStack(Foam::Ostream&)[7] #0  Foam::error::printStack(Foam::Ostream&)[11] #0  Foam::error::printStack(Foam::Ostream&)[6] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
    [2] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [4] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [15] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [5] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [10] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [12] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [13] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [14] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [6] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [3] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [8] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [9] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [7] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [0] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [12] #2  ? at ??:?
    [13] #2  ?[1] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [5] #2  ? at ??:?
    [6] #2  ? in "/lib64/libc.so.6"
    [14] #3  ucp_proto_perf_envelope_make at ??:?
    [11] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [3] #2  ? at ??:?
    [8] #2  ? at ??:?
    [1] #2  ? in "/lib64/libc.so.6"
    [10] #3  ucp_proto_perf_envelope_make in "/lib64/libc.so.6"
    [12] #3  ucp_proto_perf_envelope_make in "/lib64/libc.so.6"
    [13] #3  ucp_proto_perf_envelope_make in "/lib64/libc.so.6"
    [2] #3  ucp_proto_perf_envelope_make in "/lib64/libc.so.6"
    [5] #3  ucp_proto_perf_envelope_make[15] #3  ucp_proto_perf_envelope_make in "/lib64/libc.so.6"
    [4] #3  ucp_proto_perf_envelope_make in "/lib64/libucp.so.0"
    [12] #4  ucp_proto_init_parallel_stages in "/lib64/libucp.so.0"
    [15] #4  ucp_proto_init_parallel_stages in "/lib64/libucp.so.0"
    [2] #4  ucp_proto_init_parallel_stages in "/lib64/libc.so.6"
    [9] #3   in "/lib64/libucp.sucp_proto_perf_envelope_makeo.0"
    [14] #4   in "/lib64/libucucp_proto_init_parallel_stagesp.so.0"
    OpenFOAM编译了10多次!换了3 5个版本!
    openmpi换了3 4个版本!intelmpi换了3 4个版本!
    mpich没编译过!
    最后来,换了openmpi-5.0.3没啥问题了。
    这玩意整了我5个小时!
    大佬别用CentOS了。不维护了
    建议换Rocky Linux
    是有这个想法,就是不知道对商软的支持怎么样。现在ansys那面我看就cent支持的特别好。ubuntu装ansys都相当费事。
    都是红帽系的。一个命令就能从centOS转到Rocky这边。我们学校超算现在就是这个系统。
    厉害啊!我看看
    我们打算换rocky了,过年期间安排
