  3. ,老师们openfoam2306并行计算对流方案选择一直无效
5 帖子 2 发布者 2.0k 浏览
  • 火 离线
    火 离线
    火丙三金
    [4] --> FOAM FATAL IO ERROR: (openfoam-2306)
    [4] Unknown convection type
    Valid convection types :
    2(Gauss bounded)
    [4]
    [4]
    [4] file: stream.divSchemes.div(phi,h) at line 0.
    [4]
    [4] From static Foam::tmp<Foam::fv::convectionScheme<Type> > Foam::fv::convectionScheme<Type>::New(const Foam::fvMesh&, const surfaceScalarField&, Foam::Istream&) [with Type = double; Foam::surfaceScalarField = Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>]
    [4] in file /home/dyfluid/OpenFOAM/OpenFOAM-v2306/src/finiteVolume/lnInclude/convectionScheme.C at line 92.
    [4]
    FOAM parallel run exiting
    [4]
    [dyfluid-virtual-machine:03783] 7 more processes have sent help message help-mpi-api.txt / mpi-abort
    [dyfluid-virtual-machine:03783] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
    应该是bounded Gauss
  • 火 离线
    火 离线
    火丙三金
    div(phi,h) Gauss linearUpwind grad(h);老师 我改成这个可以运行一段时间,然后又浮点数溢出了
    可以那么改。不过就是发散了
    火 1 条回复 最后回复
  • 火 离线
    火 离线
    火丙三金
    @李东岳 已经没招了,一直溢出:136:
