  3. Continuity error该给什么样的边界条件呀?
1 帖子 1 发布者 845 浏览
  • 东方白杨东 离线
    东方白杨东 离线
    东方白杨
    我把边界条件都改了一遍,还是有这个问题,做的是一个通道流动,用的是buoyantBoussinesqSimpleFoam,给了进口速度1.82m/s,出口大气压,流体温度20K,壁面300K,边界条件如下:
    速度:
    FoamFile
        version     2.0;
        format      ascii;
        class       volVectorField;
        object      U;
    internalField   uniform (1.82 0 0);
    boundaryField
        inlet
            type            fixedValue;
            value           uniform (1.82 0 0);
        outlet
            type            zeroGradient;
        top
            type            noSlip;
        ground
            type            noSlip;
        FrontandBack
            type            noSlip;
        Trib
            type            noSlip;
    压力:
    boundaryField
        inlet
            type            zeroGradient;
        outlet
            type            fixedValue;
            value           uniform 0;//大气压出口
        top
            type            zeroGradient;
        ground
            type            zeroGradient;
        FrontandBack
            type            zeroGradient;
        Trib
            type            zeroGradient;
    参考压力:
    FoamFile
        version     2.0;
        format      ascii;
        class       volScalarField;
        object      p_rgh;
    internalField   uniform 0;
    boundaryField
        "(inlet|outlet|top|ground|FrontandBack|Trib)"
            type            fixedFluxPressure;
    一直报错如下:
    --> FOAM FATAL ERROR:
    Continuity error cannot be removed by adjusting the outflow.
    Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
    Total flux              : 0.999375
    Specified mass inflow   : 0.0167107
    Specified mass outflow  : 0
    Adjustable mass outflow : 0
        From function bool Foam::adjustPhi(Foam::surfaceScalarField&, const volVectorField&, Foam::volScalarField&)
        in file cfdTools/general/adjustPhi/adjustPhi.C at line 111.
    FOAM exiting
    CAS-IET
