  3. 拉格朗日求解器代码求助
拉格朗日求解器代码求助
14 帖子 4 发布者 7.5k 浏览
    youhaoyu
    各位大佬好,我想要在DPMFoam植入我的颗粒张大的RP方程,简单如下
    这个里面需要对颗粒进行一些定义,所以我修改了 OpenFOAM/OpenFOAM-3.0.0/src/lagrangian/intermediate这个源文件库,再去进行我的求解器编译,但是编译求解器中我遇到了如下报错
    g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3  -DNoRepository -ftemplate-depth-100 -I./DPMTurbulenceModels/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/lagrangian/basic/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/lagrangian/intermediate/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/thermophysicalModels/specie/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/transportModels/compressible/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/thermophysicalModels/basic/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/thermophysicalModels/reactionThermo/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/thermophysicalModels/radiation/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/transportModels -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/transportModels/incompressible/singlePhaseTransportModel -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/TurbulenceModels/turbulenceModels/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/TurbulenceModels/incompressible/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/TurbulenceModels/phaseIncompressible/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/regionModels/regionModel/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/regionModels/surfaceFilmModels/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/finiteVolume/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/meshTools/lnInclude -IlnInclude -I. -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/OpenFOAM/lnInclude -I/home/zly/OpenFOAM/OpenFOAM-3.0.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/ppDPMFoam.o -L/home/zly/OpenFOAM/OpenFOAM-3.0.0/platforms/linux64GccDPInt32Opt/lib \
        -llagrangian -llagrangianIntermediate -llagrangianTurbulence -lthermophysicalFunctions -lspecie -lradiationModels -lincompressibleTransportModels -lturbulenceModels -lincompressibleTurbulenceModels -lDPMTurbulenceModels -lregionModels -lsurfaceFilmModels -lsampling -lfiniteVolume -lmeshTools -lOpenFOAM -ldl  \
         -lm -o /home/zly/OpenFOAM/zly-3.0.0/platforms/linux64GccDPInt32Opt/bin/ppDPMFoam
    Make/linux64GccDPInt32Opt/ppDPMFoam.o: In function `Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > >::setParcelThermoProperties(Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> >&, double) [clone .isra.656]':
    ppDPMFoam.C:(.text+0x1377): undefined reference to `Foam::KinematicParcel<Foam::particle>::Ro()'
    ppDPMFoam.C:(.text+0x13c9): undefined reference to `Foam::KinematicParcel<Foam::particle>::pgo()'
    Make/linux64GccDPInt32Opt/ppDPMFoam.o: In function `void Foam::KinematicParcel<Foam::particle>::setCellValues<Foam::KinematicParcel<Foam::particle>::TrackingData<Foam::CollidingCloud<Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > > > >(Foam::KinematicParcel<Foam::particle>::TrackingData<Foam::CollidingCloud<Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > > >&, double, int)':
    ppDPMFoam.C:(.text._ZN4Foam15KinematicParcelINS_8particleEE13setCellValuesINS2_12TrackingDataINS_14CollidingCloudINS_14KinematicCloudINS_5CloudINS_15CollidingParcelIS2_EEEEEEEEEEEEvRT_di[_ZN4Foam15KinematicParcelINS_8particleEE13setCellValuesINS2_12TrackingDataINS_14CollidingCloudINS_14KinematicCloudINS_5CloudINS_15CollidingParcelIS2_EEEEEEEEEEEEvRT_di]+0x23c): undefined reference to `Foam::KinematicParcel<Foam::particle>::TrackingData<Foam::CollidingCloud<Foam::KinematicCloud<Foam::Cloud<Foam::CollidingParcel<Foam::KinematicParcel<Foam::particle> > > > > >::PInterp() const'
    make: *** [/home/zly/OpenFOAM/zly-3.0.0/platforms/linux64GccDPInt32Opt/bin/ppDPMFoam] Error 1
    似乎在说我的Ro,pgo和PInterp没有定义,其中第一个是初始的气泡半径,第二个是初始气泡内压,第三个是颗粒受到的压强插值。
    但是我明明在KinematicParcel.H和.C文件进行了定义,如下其中//-myadd即为我的自己添加)
    KinematicParcel.H
    #ifndef KinematicParcel_H
    #define KinematicParcel_H
    #include "particle.H"
    #include "IOstream.H"
    #include "autoPtr.H"
    #include "interpolation.H"
    #include "demandDrivenEntry.H"
    // #include "ParticleForceList.H" // TODO
    namespace Foam
    template<class ParcelType>
    class KinematicParcel;
    // Forward declaration of friend functions
    Ostream& operator<<
        Ostream&,
        const KinematicParcel<ParcelType>&
                             Class KinematicParcel Declaration
        public ParcelType
        // Private data
            //- Size in bytes of the fields
            static const std::size_t sizeofFields_;
            //- Number of particle tracking attempts before we assume that it stalls
            static label maxTrackAttempts;
    public:
        //- Class to hold kinematic particle constant properties
        class constantProperties
        protected:
            // Protected data
                //- Constant properties dictionary
                const dictionary dict_;
        private:
            // Private data
                //- Parcel type id - used for post-processing to flag the type
                //  of parcels issued by this cloud
                demandDrivenEntry<label> parcelTypeId_;
                //- Minimum density [kg/m3]
                demandDrivenEntry<scalar> rhoMin_;
                //- Particle density [kg/m3] (constant)
                demandDrivenEntry<scalar> rho0_;
                //- Minimum parcel mass [kg]
                demandDrivenEntry<scalar> minParcelMass_;
                //- myadd Particle initial radius [m]
                demandDrivenEntry<scalar> Ro0_;
                //- myadd Particle initial pressure inside [kg/m/s2]
                demandDrivenEntry<scalar> pgo0_;
        public:
            // Constructors
                //- Null constructor
                constantProperties();
                //- Copy constructor
                constantProperties(const constantProperties& cp);
                //- Construct from dictionary
                constantProperties(const dictionary& parentDict);
            // Member functions
                //- Return const access to the constant properties dictionary
                inline const dictionary& dict() const;
                //- Return const access to the parcel type id
                inline label parcelTypeId() const;
                //- Return const access to the minimum density
                inline scalar rhoMin() const;
                //- Return const access to the particle density
                inline scalar rho0() const;
                //- Return const access to the minimum parcel mass
                inline scalar minParcelMass() const;
                //- myadd Return const access to the particle intitial radius
                inline scalar Ro0() const;
                //- myadd Return const access to the particle initial pressure
                inline scalar pgo0() const;
        template<class CloudType>
        class TrackingData
            public ParcelType::template TrackingData<CloudType>
        public:
            enum trackPart
                tpVelocityHalfStep,
                tpLinearTrack,
                tpRotationalTrack
        private:
            // Private data
                // Interpolators for continuous phase fields
                    //- Density interpolator
                    autoPtr<interpolation<scalar> > rhoInterp_;
                    //- Velocity interpolator
                    autoPtr<interpolation<vector> > UInterp_;
                    //- Dynamic viscosity interpolator
                    autoPtr<interpolation<scalar> > muInterp_;
                    //-myadd Pressure interpolator
                    autoPtr<interpolation<scalar> > PInterp_;
                //- Local gravitational or other body-force acceleration
                const vector& g_;
                // label specifying which part of the integration
                // algorithm is taking place
                trackPart part_;
        public:
            // Constructors
                //- Construct from components
                inline TrackingData
                    CloudType& cloud,
                    trackPart part = tpLinearTrack
            // Member functions
                //- Return conat access to the interpolator for continuous
                //  phase density field
                inline const interpolation<scalar>& rhoInterp() const;
                //  phase velocity field
                inline const interpolation<vector>& UInterp() const;
                //  phase dynamic viscosity field
                inline const interpolation<scalar>& muInterp() const;
                //- myadd Return const access to the interpolator for continuous phase pressure field
                inline const interpolation<scalar>& PInterp() const;
                // Return const access to the gravitational acceleration vector
                inline const vector& g() const;
                //- Return the part of the tracking operation taking place
                inline trackPart part() const;
                //- Return access to the part of the tracking operation taking place
                inline trackPart& part();
    protected:
        // Protected data
            // Parcel properties
                //- Active flag - tracking inactive when active = false
                bool active_;
                //- Parcel type id
                label typeId_;
                //- Number of particles in Parcel
                scalar nParticle_;
                //- Diameter [m]
                scalar d_;
                //- Target diameter [m]
                scalar dTarget_;
                //- Velocity of Parcel [m/s]
                vector U_;
                //- Density [kg/m3]
                scalar rho_;
                //- Age [s]
                scalar age_;
                //- Time spent in turbulent eddy [s]
                scalar tTurb_;
                //- Turbulent velocity fluctuation [m/s]
                vector UTurb_;
                //- myadd change rate of bubble radius [m/s]
                scalar dRt_;
                //- myadd initial bubble radius [m]
                scalar Ro_;
                //- myadd initial bubble pressuer [Pa]
                scalar pgo_;
            // Cell-based quantities
                //- Density [kg/m3]
                scalar rhoc_;
                //- Velocity [m/s]
                vector Uc_;
                //- Viscosity [Pa.s]
                scalar muc_;
                //- myadd Pressure [Pa]
                scalar Pc_;
        // Protected Member Functions
            //- Calculate new particle velocity
            template<class TrackData>
            const vector calcVelocity
                TrackData& td,
                const scalar dt,           // timestep
                const label cellI,         // owner cell
                const scalar Re,           // Reynolds number
                const scalar mu,           // local carrier viscosity
                const scalar mass,         // mass
                const vector& Su,          // explicit particle momentum source
                vector& dUTrans,           // momentum transfer to carrier
                scalar& Spu                // linearised drag coefficient
            ) const;
            //- myadd Calculate new particle Diameter
            const vector calcDiameter
                TrackData& td,
                const scalar dt,
                const label cellI,
                const scalar mu,
                const scalar rhoc
            ) const;
    public:
        // Static data members
            //- Runtime type information
            TypeName("KinematicParcel");
            //- String representation of properties
            AddToPropertyList
                ParcelType,
                " active"
              + " typeId"
              + " nParticle"
              + " d"
              + " dTarget "
              + " (Ux Uy Uz)"
              + " rho"
              + " age"
               //- myadd
              + " dRt"
              + " Ro"
              + " pgo"
              //- end
              + " tTurb"
              + " (UTurbx UTurby UTurbz)"
        // Constructors
            //- Construct from owner, position, and cloud owner
            //  Other properties initialised as null
            inline KinematicParcel
                const polyMesh& mesh,
                const vector& position,
                const label cellI,
                const label tetFaceI,
                const label tetPtI
                const label cellI,
                const label tetPtI,
                const label typeId,
                const scalar nParticle0,
                const scalar d0,
                const scalar dTarget0,
                const vector& torque0,
                //- myadd
                const scalar dRt0,
                const constantProperties& constProps
            //- Construct from Istream
            KinematicParcel
                Istream& is,
                bool readFields = true
            //- Construct as a copy
            KinematicParcel(const KinematicParcel& p);
            KinematicParcel(const KinematicParcel& p, const polyMesh& mesh);
            //- Construct and return a (basic particle) clone
            virtual autoPtr<particle> clone() const
                return autoPtr<particle>(new KinematicParcel(*this));
            virtual autoPtr<particle> clone(const polyMesh& mesh) const
                return autoPtr<particle>(new KinematicParcel(*this, mesh));
            //- Factory class to read-construct particles used for
            //  parallel transfer
            class iNew
                const polyMesh& mesh_;
            public:
                iNew(const polyMesh& mesh)
                    mesh_(mesh)
                autoPtr<KinematicParcel<ParcelType> > operator()(Istream& is) const
                    return autoPtr<KinematicParcel<ParcelType> >
                        new KinematicParcel<ParcelType>(mesh_, is, true)
        // Member Functions
            // Access
                //- Return const access to active flag
                inline bool active() const;
                //- Return const access to type id
                inline label typeId() const;
                //- Return const access to number of particles
                inline scalar nParticle() const;
                //- Return const access to diameter
                inline scalar d() const;
                //- Return const access to target diameter
                inline scalar dTarget() const;
                //- Return const access to velocity
                inline const vector& U() const;
                //- Return const access to density
                inline scalar rho() const;
                //- Return const access to the age
                inline scalar age() const;
                //- myadd Return const access to the change rate of bubble radius
                inline scalar dRt() const;
                //- myadd Return const access to intial bubble radius
                inline scalar Ro() const;
                //- myadd Return const access to initial pressure inside
                inline scalar pgo() const;
                //- Return const access to time spent in turbulent eddy
                inline scalar tTurb() const;
                //- Return const access to turbulent velocity fluctuation
                inline const vector& UTurb() const;
                //- Return const access to carrier density [kg/m3]
                inline scalar rhoc() const;
                //- Return const access to carrier velocity [m/s]
                inline const vector& Uc() const;
                //- Return const access to carrier viscosity [Pa.s]
                inline scalar muc() const;
                //- myadd Return const carrier pressure
                inline scalar Pc() const;
            // Edit
                inline bool& active();
                //- Return access to type id
                inline label& typeId();
                //- Return access to number of particles
                inline scalar& nParticle();
                //- Return access to diameter
                inline scalar& d();
                //- Return access to target diameter
                inline scalar& dTarget();
                //- Return access to velocity
                inline vector& U();
                //- Return access to density
                inline scalar& rho();
                //- Return access to the age
                inline scalar& age();
                //- myadd Return access to the change rate of bubble radius
                inline scalar& dRt();
                //- myadd Return access to intial bubble radius
                inline scalar& Ro();
                //- myadd Return access to intial pressure inside
                inline scalar& pgo();
                //- Return access to time spent in turbulent eddy
                inline scalar& tTurb();
                //- Return access to turbulent velocity fluctuation
                inline vector& UTurb();
            // Helper functions
                //- Return the index of the face used in the interpolation routine
                inline label faceInterpolation() const;
                //- Cell owner mass
                inline scalar massCell(const label cellI) const;
                //- Particle mass
                inline scalar mass() const;
                //- Particle moment of inertia around diameter axis
                inline scalar momentOfInertia() const;
                //- Particle volume
                inline scalar volume() const;
                //- Particle volume for a given diameter
                inline static scalar volume(const scalar d);
                //- Particle projected area
                inline scalar areaP() const;
                //- Projected area for given diameter
                inline static scalar areaP(const scalar d);
                //- Particle surface area
                inline scalar areaS() const;
                //- Surface area for given diameter
                inline static scalar areaS(const scalar d);
                //- Reynolds number
                inline scalar Re
                    const vector& U,        // particle velocity
                    const scalar d,         // particle diameter
                    const scalar rhoc,      // carrier density
                    const scalar muc        // carrier dynamic viscosity
                ) const;
                //- Weber number
                inline scalar We
                    const scalar sigma      // particle surface tension
                ) const;
                //- Eotvos number
                inline scalar Eo
                    const vector& a,        // acceleration
                ) const;
            // Main calculation loop
                //- Set cell values
                void setCellValues
                    TrackData& td,
                    const scalar dt,
                    const label cellI
                //- Correct cell values using latest transfer information
                void cellValueSourceCorrection
                    TrackData& td,
                    const scalar dt,
                    const label cellI
                //- Update parcel properties over the time interval
                void calc
                    TrackData& td,
                    const scalar dt,
                    const label cellI
            // Tracking
                //- Move the parcel
                bool move(TrackData& td, const scalar trackTime);
            // Patch interactions
                //- Overridable function to handle the particle hitting a face
                //  without trackData
                void hitFace(int& td);
                void hitFace(TrackData& td);
                //- Overridable function to handle the particle hitting a patch
                //  Executed before other patch-hitting functions
                bool hitPatch
                    const polyPatch& p,
                    TrackData& td,
                    const label patchI,
                    const scalar trackFraction,
                    const tetIndices& tetIs
                //  processorPatch
                void hitProcessorPatch
                    const processorPolyPatch&,
                    TrackData& td
                //- Overridable function to handle the particle hitting a wallPatch
                void hitWallPatch
                    const wallPolyPatch&,
                    TrackData& td,
                    const tetIndices&
                //- Overridable function to handle the particle hitting a polyPatch
                void hitPatch
                    const polyPatch&,
                    TrackData& td
                //- Transform the physical properties of the particle
                //  according to the given transformation tensor
                virtual void transformProperties(const tensor& T);
                //  according to the given separation vector
                virtual void transformProperties(const vector& separation);
                //- The nearest distance to a wall that the particle can be
                //  in the n direction
                virtual scalar wallImpactDistance(const vector& n) const;
            // I-O
                //- Read
                static void readFields(CloudType& c);
                //- Write
                static void writeFields(const CloudType& c);
        // Ostream Operator
            friend Ostream& operator<< <ParcelType>
                Ostream&,
    } // End namespace Foam
    #include "KinematicParcelI.H"
    #include "KinematicParcelTrackingDataI.H"
    #ifdef NoRepository
        #include "KinematicParcel.C"
    #endif
    #endif
    以及KinematicParcel.C
       \\    /   O peration     |
        \\  /    A nd           | Copyright (C) 2011-2014 OpenFOAM Foundation
         \\/     M anipulation  |
    License
        This file is part of OpenFOAM.
        OpenFOAM is free software: you can redistribute it and/or modify it
        under the terms of the GNU General Public License as published by
        the Free Software Foundation, either version 3 of the License, or
        (at your option) any later version.
        OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
        ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
        FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
        for more details.
        You should have received a copy of the GNU General Public License
        along with OpenFOAM.  If not, see <http://www.gnu.org/licenses/>.
    #include "KinematicParcel.H"
    #include "forceSuSp.H"
    #include "IntegrationScheme.H"
    #include "meshTools.H"
    // * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * //
    Foam::label Foam::KinematicParcel<ParcelType>::maxTrackAttempts = 1;
    // * * * * * * * * * * *  Protected Member Functions * * * * * * * * * * * * //
    void Foam::KinematicParcel<ParcelType>::setCellValues
        TrackData& td,
        const scalar dt,
        const label cellI
        tetIndices tetIs = this->currentTetIndices();
        rhoc_ = td.rhoInterp().interpolate(this->position(), tetIs);
        if (rhoc_ < td.cloud().constProps().rhoMin())
            if (debug)
                WarningIn
                    "void Foam::KinematicParcel<ParcelType>::setCellValues"
                        "TrackData&, "
                        "const scalar, "
                        "const label"
                )   << "Limiting observed density in cell " << cellI << " to "
                    << td.cloud().constProps().rhoMin() <<  nl << endl;
            rhoc_ = td.cloud().constProps().rhoMin();
        Uc_ = td.UInterp().interpolate(this->position(), tetIs);
        muc_ = td.muInterp().interpolate(this->position(), tetIs);
        // Apply dispersion components to carrier phase velocity
        Uc_ = td.cloud().dispersion().update
            dt,
            cellI,
            U_,
            Uc_,
            UTurb_,
            tTurb_
        Pc_ = td.PInterp().interpolate(this->position(), tetIs);  //- myadd
    void Foam::KinematicParcel<ParcelType>::cellValueSourceCorrection
        TrackData& td,
        const scalar dt,
        const label cellI
        Uc_ += td.cloud().UTrans()[cellI]/massCell(cellI);
    void Foam::KinematicParcel<ParcelType>::calc
        TrackData& td,
        const scalar dt,
        const label cellI
        // Define local properties at beginning of time step
        const scalar np0 = nParticle_;
        const scalar mass0 = mass();
        // Reynolds number
        const scalar Re = this->Re(U_, d_, rhoc_, muc_);
        // Sources
        // Explicit momentum source for particle
        vector Su = vector::zero;
        // Linearised momentum source coefficient
        scalar Spu = 0.0;
        // Momentum transfer from the particle to the carrier phase
        vector dUTrans = vector::zero;
        //- myadd
        if(Ro_>0)
        vector storeddRt = calcDiameter(td, dt, cellI, muc_, rhoc_);
        this->dRt_=storeddRt[0];
        this->d_=storeddRt[1];
        // Motion
        // Calculate new particle velocity
        this->U_ = calcVelocity(td, dt, cellI, Re, muc_, mass0, Su, dUTrans, Spu);
        // Accumulate carrier phase source terms
        if (td.cloud().solution().coupled())
            // Update momentum transfer
            td.cloud().UTrans()[cellI] += np0*dUTrans;
            // Update momentum transfer coefficient
            td.cloud().UCoeff()[cellI] += np0*Spu;
    const Foam::vector Foam::KinematicParcel<ParcelType>::calcVelocity
        TrackData& td,
        const scalar dt,
        const label cellI,
        const scalar Re,
        const scalar mu,
        const scalar mass,
        const vector& Su,
        vector& dUTrans,
        scalar& Spu
    ) const
        typedef typename TrackData::cloudType cloudType;
        typedef typename cloudType::parcelType parcelType;
        typedef typename cloudType::forceType forceType;
        const forceType& forces = td.cloud().forces();
        // Momentum source due to particle forces
        const parcelType& p = static_cast<const parcelType&>(*this);
        const forceSuSp Fcp = forces.calcCoupled(p, dt, mass, Re, mu);
        const forceSuSp Fncp = forces.calcNonCoupled(p, dt, mass, Re, mu);
        const forceSuSp Feff = Fcp + Fncp;
        const scalar massEff = forces.massEff(p, mass);
        // New particle velocity
        // Update velocity - treat as 3-D
        const vector abp = (Feff.Sp()*Uc_ + (Feff.Su() + Su))/massEff;
        const scalar bp = Feff.Sp()/massEff;
        Spu = dt*Feff.Sp();
        IntegrationScheme<vector>::integrationResult Ures =
            td.cloud().UIntegrator().integrate(U_, dt, abp, bp);
        vector Unew = Ures.value();
        // note: Feff.Sp() and Fc.Sp() must be the same
        dUTrans += dt*(Feff.Sp()*(Ures.average() - Uc_) - Fcp.Su());
        // Apply correction to velocity and dUTrans for reduced-D cases
        const polyMesh& mesh = td.cloud().pMesh();
        meshTools::constrainDirection(mesh, mesh.solutionD(), Unew);
        meshTools::constrainDirection(mesh, mesh.solutionD(), dUTrans);
        return Unew;
    //- myadd
    const Foam::vector Foam::KinematicParcel<ParcelType>::calcDiameter
        TrackData& td,
        const scalar dt,
        const label cellI,
        const scalar mu,
        const scalar rhoc
    ) const
        // Saturated vapor pressure
        const scalar pv=0;
        //surface tension
        const scalar siggma=0.0712;
        scalar R=d_/2;
        //The fourth-order Rungekuta method solves second-order differential equations
        const scalar k1=dRt_;
        const scalar h1=-3*pow(k1,2)/2/R-(4*mu*k1+2*siggma)/rhoc/pow(R,2)+(pv-Pc_+pgo_*pow(Ro_,4.2)*pow(R,-4.2))/rhoc/R;
        const scalar k2=k1+0.5*dt*h1;
        const scalar h2=-3*pow(k2,2)/2/(R+0.5*dt*k1)-(4*mu*k2+2*siggma)/rhoc/pow(R+0.5*dt*k1,2)+(pv-Pc_+pgo_*pow(Ro_,4.2)*pow(R+0.5*dt*k1,-4.2))/rhoc/(R+0.5*dt*k1);
        const scalar k3=k1+0.5*dt*h2;
        const scalar h3=-3*pow(k3,2)/2/(R+0.5*dt*k2)-(4*mu*k3+2*siggma)/rhoc/pow(R+0.5*dt*k2,2)+(pv-Pc_+pgo_*pow(Ro_,4.2)*pow(R+0.5*dt*k2,-4.2))/rhoc/(R+0.5*dt*k2);
        const scalar k4=k1+dt*h3;
        const scalar h4=-3*pow(k4,2)/2/(R+0.5*dt*k3)-(4*mu*k4+2*siggma)/rhoc/pow(R+0.5*dt*k3,2)+(pv-Pc_+pgo_*pow(Ro_,4.2)*pow(R+0.5*dt*k3,-4.2))/rhoc/(R+0.5*dt*k3);
        vector Rtvector(0,0,0);
        Rtvector[0]=k1+dt/6*(h1+2*h2+2*h3+h4);
        Rtvector[1]=2*(R+dt/6*(k1+2*k2+2*k3+k4));
        return Rtvector;
    // * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
    Foam::KinematicParcel<ParcelType>::KinematicParcel
        const KinematicParcel<ParcelType>& p
        ParcelType(p),
        active_(p.active_),
        typeId_(p.typeId_),
        nParticle_(p.nParticle_),
        d_(p.d_),
        dTarget_(p.dTarget_),
        U_(p.U_),
        rho_(p.rho_),
        age_(p.age_),
        tTurb_(p.tTurb_),
        UTurb_(p.UTurb_),
        rhoc_(p.rhoc_),
        Uc_(p.Uc_),
        muc_(p.muc_),
        //- myadd
        dRt_(p.dRt_),
        Ro_(p.Ro_),
        pgo_(p.pgo_),
        Pc_(p.Pc_)
        const KinematicParcel<ParcelType>& p,
        ParcelType(p, mesh),
        active_(p.active_),
        typeId_(p.typeId_),
        d_(p.d_),
        U_(p.U_),
        rho_(p.rho_),
        age_(p.age_),
        tTurb_(p.tTurb_),
        UTurb_(p.UTurb_),
        rhoc_(p.rhoc_),
        Uc_(p.Uc_),
        muc_(p.muc_),
        //- myadd
        dRt_(p.dRt_),
        Ro_(p.Ro_),
        pgo_(p.pgo_),
        Pc_(p.Pc_)
    我明明进行了定义,但是仍然报错,有没有相关操作过的大佬进行以下,这个方程植入我植入了两个月了还没成功:136:
    把你这两个方程里面自定义参数的值都写一下我看看。
    youhaoyu
    @李东岳 我忽略了第一个方程最后那个u和ub
    R — 气泡半径
    ··R — 气泡半径对时间二阶导
    ·R — 气泡半径对时间一阶导
    pv — 气泡内饱和蒸汽压(我这里设置的0,因为这个方程考虑了空化现象,我直接取的0)
    pg — 气泡内部气压(根据第二个方程在计算)
    p∞ — 气泡受到的液体压强(我这里使用PInterp插值,在DPMFoam求解器也自定义了个P=p*rhoc)
    σ — 表面张力
    pgo — 初始气泡内部压强
    Ro — 初始气泡直径
    值得一提的是,修改完求解器之后,这个pgo和Ro我看我现在阅读的论文代码上是直接在KinematicCloudProperties的颗粒参数上进行了赋值。
    在我上面那个KinematicParcel.C是主要算法,使用龙格库朗四阶对于这个二阶的方程进行的求解(他直接把方程2-49代入了2-48计算)。
    r\frac{\p^2 r}{\p t^2}+1.5\frac{\p r}{\p t}=
    \frac{1}{\rho}\left(p_{g0} \left(r_0/r\right)^{3\gamma} -p\rho_\rc-\frac{2\sigma}{r} - \frac{4\mu}{r}\frac{\p r}{\p t}\right)+\frac{(\bfU_\rc-\bfU)^2}{4}
    \end{equation}
    我把这个方程简化成这个行不行
    r\frac{\p^2 r}{\p t^2}+1.5\frac{\p r}{\p t}=A+\frac{(\bfU_\rc-\bfU)^2}{4}
    \end{equation}
    $A=0$
    Y 2 条回复 最后回复
    youhaoyu
    @李东岳 这个把右侧括号部分考虑成0的话可能不大妥吧,因为我是个动态过程,气泡的入口和出口的压力差相差了两个数量级,还是挺大的。要看这个气泡慢慢变大过程。
    如果你把A考虑成0,方程无法体现气泡内外压力差和表面张力,和我的模型可能也有一些问题。
    方程的解法其实也不是很大问题,主要是这些变量如何去申明定义太恶心了。东岳老师您这种就简化的模型不大适合我目前的课题。 最开始我也想过,直接使用最简单的理想方程PV=NRT这种去修改,但是我觉得这种方程使用起来不是特别好
    我只是提供一个框架,而不是实际把r计算出来。后续你要在框架上自己进行修改,比如把A改成真实的。
    youhaoyu
    @李东岳 我的模型大概是1米高的管道,下方10000大气压,上方600Pa(液体是钢液,密度7000),底部通入气泡这种模型,对于气泡和液体之间压强差这个就是我们主要考虑的因素。这种来说A感觉不能直接考虑为0,所以我一直在看如何直接植入这个完整的方程
  • 杨英狄杨 离线
    杨英狄杨 离线
    杨英狄
    粒子性质的定义不仅在KinematicParcel.C和KinematicParcel.H,在其他文件中也涉及相关代码。你可以正则搜索一下,看看那些文件涉及粒子性质的声明和定义。
    youhaoyu
    在 中回复了 杨英狄 最后由 编辑
    @杨英狄 谢谢,这几天我我看了看,是我有些地方没有定义完成,我看您之前也在往DPMFoam添加RP方程,添加成功了吗?我最近添加编译成功了,库和求解器都成功了,但是计算出来结果颗粒直径没有变化。(您好久没登陆了,我还在尝试联系您,没成功)
    杨英狄杨 1 条回复 最后回复
  • 杨英狄杨 离线
    杨英狄杨 离线
    杨英狄
    在 中回复了 youhaoyu 最后由 编辑
    @youhaoyu 如果计算过程中发现粒径没有变化,可能是添加的RP方程计算程序没有被调用。参考原生的lagrange库,粒子速度的更新函数calcVelocity(),是在函数calc()里面被调用的。你可以看看你的RP方程函数是否在calc()里面调用了。
    youhaoyu
    在 中回复了 杨英狄 最后由 编辑
    @杨英狄 是的,我就是这么编写的,我写了个calcDiameter,但是就是没发现哪儿有问题,现在我在一点点改看看哪儿有问题。
    但是现在麻烦来了,修改了代码之后,编译能成功,但是使用求解器时候会报错,什么浮点数异常什么的,我初始条件都没改,哎麻烦死了。能不能给个联系方式,想咨询下您问题,因为刚好看到您也修改过
    mingyangM 1 条回复 最后回复
  • mingyangM 离线
    mingyangM 离线
    mingyang
    @youhaoyu 你好,能学习一下您的植入方法吗,我最近也被困在这了,期待你的回复,感谢
    youhaoyu
    在 中回复了 mingyang 最后由 编辑
    @mingyang 您好可以加我qq 2269609762一起探讨,我也没做成功
    我在几年前做了个一拉格朗日粒子直径变化的代码。我现在已经记不起来太多了。能想起来的是:
    1. 粒子直径跟流场的湍流动能耗散率有关系
    2. 植入的是一个跟PBM有关的粒径变化方程,考虑了coalescense和破碎
    3. 代码可以编译并且测试过可以体现粒径变化
    可以把下面的MomentumCloud.C:替换到OpenFOAM原来的代码然后编译。搞明白之后看看思路然后适配到你们的算法上。
    MomentumCloud.C:
        \\  /    A nd           | Copyright (C) 2011-2021 OpenFOAM Foundation
         \\/     M anipulation  |
    License
        for more details.
    #include "MomentumCloud.H"
    #include "integrationScheme.H"
    #include "subCycleTime.H"
    #include "InjectionModelList.H"
    #include "DispersionModel.H"
    #include "PatchInteractionModel.H"
    #include "StochasticCollisionModel.H"
    #include "SurfaceFilmModel.H"
    // * * * * * * * * * * * * * Protected Member Functions  * * * * * * * * * * //
    void Foam::MomentumCloud<CloudType>::setModels()
        dispersionModel_.reset
            DispersionModel<MomentumCloud<CloudType>>::New
                subModelProperties_,
                *this
            ).ptr()
        patchInteractionModel_.reset
            PatchInteractionModel<MomentumCloud<CloudType>>::New
                *this
            ).ptr()
        stochasticCollisionModel_.reset
            StochasticCollisionModel<MomentumCloud<CloudType>>::New
                *this
            ).ptr()
        surfaceFilmModel_.reset
            SurfaceFilmModel<MomentumCloud<CloudType>>::New
                *this
            ).ptr()
        UIntegrator_.reset
            integrationScheme::New
                "U",
                solution_.integrationSchemes()
            ).ptr()
    template<class TrackCloudType>
    void Foam::MomentumCloud<CloudType>::solve
        TrackCloudType& cloud,
        typename parcelType::trackingData& td
        if (solution_.steadyState())
            cloud.storeState();
            cloud.preEvolve();
            evolveCloud(cloud, td);
            if (solution_.coupled())
                cloud.relaxSources(cloud.cloudCopy());
        else
            Info<< "Dyfluid: Evolve function in MomentumCloud.C" << nl;
            List<DynamicList<label>> PartLabelPre(U_.size());
            List<DynamicList<label>> PartLabelPost(U_.size());
            DynamicList<label> cellWithPartPre;
            DynamicList<label> cellWithPartPost;
            pNumber_.primitiveFieldRef() = 0.0;
            forAllIter(typename MomentumCloud<CloudType>, *this, iter)
                parcelType& p = iter();
                pNumber_[p.cell()] += p.nParticle();
                PartLabelPre[p.cell()].append(p.origId());
            forAll(U_, cell)
                if (PartLabelPre[cell].size() != 0)
                    cellWithPartPre.append(cell);
            //Info<< cellWithPartPre << nl;
            cloud.preEvolve();
                cloud.scaleSources();
                PartLabelPost[p.cell()].append(p.origId());
            const volScalarField& epsi = U_.mesh().lookupObject<volScalarField>("epsilon.water");
            scalar C1 = 0.00481;
            scalar C2 = 0.08;
            scalar sigma = 0.072;
            scalar rhoc = 998.0;
            scalar D1 = 0.88;
            scalar D2 = 9e6;
            scalar muc = 1e-3;
            const scalar dt = this->mesh().time().deltaTValue();
            forAll(U_, cell)
                // if there are particles in some cell
                if (PartLabelPost[cell].size() != 0)
                    cellWithPartPost.append(cell);
                    scalar allVolume = 0.0;
                    scalar allnParticle = 0.0;
                    scalar allnParticleNew = 0.0;
                    scalar diamAve = 0.0;
                    //Info<< "Cell [" << cell << "] has " << PartLabelPost[cell].size()
                    //    << " particles" << nl;
                    // loop all over particles
                        // loop particles label in this cell
                        forAll(PartLabelPost[cell], i)
                            // if this particle belongs to this cell
                            if (p.origId() == PartLabelPost[cell](i))
                                allVolume += p.nParticle()*M_PI/6.0*pow3(p.d());
                                allnParticle += p.nParticle();
                                diamAve = pow(allVolume/allnParticle*6.0/M_PI, 1.0/3.0);
                                //Info<< " Labels are " << PartLabelPost[cell](i)
                                //    << ", its nParticle is " << p.nParticle()
                                //    << ", volume is " << allVolume << nl;
                    const scalar d = diamAve;
                    // cell manipulation, calculate average diameter
                    if (d > SMALL)
                        const scalar epsilon = epsi[cell];
                        scalar gN =
                            allnParticle*C1*pow(epsilon, 1.0/3.0)/pow(d, 2.0/3.0)
                           *exp(-C2*sigma/(rhoc*pow(epsilon, 2.0/3.0)*pow(d, 5.0/3.0)));
                        scalar aSqrN =
                            sqr(allnParticle)*D1*pow(epsilon, 1.0/3.0)*4.0*sqrt(2.0)*pow(d, 7.0/6.0)
                           *exp(-D2*muc*rhoc*epsilon/sqr(sigma)*pow4(d)/16.0);
                        allnParticleNew = allnParticle + (gN - aSqrN)*dt;
                        diamAve = diamAve*pow(allnParticle/allnParticleNew, 1.0/3.0);
                        //Info<< "gN = " << gN << nl;
                        //Info<< "aSqrN = " << aSqrN << nl;
                        //Info<< "Particle increased by " << allnParticleNew - allnParticle << nl;
                        //Info<< "diamAve is " << diamAve << nl;
                    scalar newVolume = 0.0;
                                p.nParticle() = allnParticleNew/PartLabelPost[cell].size();
                                p.d() = diamAve;
                                newVolume += p.nParticle()*M_PI/6.0*pow3(p.d());
                                //Info<< " after brecoa, volume is " << newVolume
                                //    << "p.nParticle is " << p.nParticle() << nl;
        cloud.info();
        cloud.postEvolve();
            cloud.restoreState();
    void Foam::MomentumCloud<CloudType>::buildCellOccupancy()
        if (cellOccupancyPtr_.empty())
            cellOccupancyPtr_.reset
                new List<DynamicList<parcelType*>>(this->mesh().nCells())
        else if (cellOccupancyPtr_().size() != this->mesh().nCells())
            // If the size of the mesh has changed, reset the
            // cellOccupancy size
            cellOccupancyPtr_().setSize(this->mesh().nCells());
        List<DynamicList<parcelType*>>& cellOccupancy = cellOccupancyPtr_();
        forAll(cellOccupancy, cO)
            cellOccupancy[cO].clear();
            cellOccupancy[iter().cell()].append(&iter());
    void Foam::MomentumCloud<CloudType>::updateCellOccupancy()
        // Only build the cellOccupancy if the pointer is set, i.e. it has
        // been requested before.
        if (cellOccupancyPtr_.valid())
            buildCellOccupancy();
    void Foam::MomentumCloud<CloudType>::evolveCloud
            cloud.resetSourceTerms();
        if (solution_.transient())
            label preInjectionSize = this->size();
            this->surfaceFilm().inject(cloud);
            // Update the cellOccupancy if the size of the cloud has changed
            // during the injection.
            if (preInjectionSize != this->size())
                updateCellOccupancy();
            injectors_.inject(cloud, td);
            // Assume that motion will update the cellOccupancy as necessary
            // before it is required.
            cloud.motion(cloud, td);
            stochasticCollision().update(td, solution_.trackTime());
        else
    //        this->surfaceFilm().injectSteadyState(cloud);
            injectors_.injectSteadyState(cloud, td, solution_.trackTime());
            CloudType::move(cloud, td, solution_.trackTime());
    void Foam::MomentumCloud<CloudType>::postEvolve()
        Info<< endl;
        if (debug)
            this->writePositions();
        this->dispersion().cacheFields(false);
        forces_.cacheFields(false);
        functions_.postEvolve();
        solution_.nextIter();
        if (this->db().time().writeTime())
            outputProperties_.writeObject
                IOstream::ASCII,
                IOstream::currentVersion,
                this->db().time().writeCompression(),
                true
    void Foam::MomentumCloud<CloudType>::cloudReset(MomentumCloud<CloudType>& c)
        CloudType::cloudReset(c);
        rndGen_ = c.rndGen_;
        forces_.transfer(c.forces_);
        functions_.transfer(c.functions_);
        injectors_.transfer(c.injectors_);
        dispersionModel_.reset(c.dispersionModel_.ptr());
        patchInteractionModel_.reset(c.patchInteractionModel_.ptr());
        stochasticCollisionModel_.reset(c.stochasticCollisionModel_.ptr());
        surfaceFilmModel_.reset(c.surfaceFilmModel_.ptr());
        UIntegrator_.reset(c.UIntegrator_.ptr());
    Foam::MomentumCloud<CloudType>::MomentumCloud
        const word& cloudName,
        const volScalarField& rho,
        const volVectorField& U,
        const volScalarField& mu,
        const dimensionedVector& g,
        const bool readFields
        CloudType(cloudName, rho, U, mu, g, false),
        cloudCopyPtr_(nullptr),
        particleProperties_
                cloudName + "Properties",
                this->mesh().time().constant(),
                this->mesh(),
                IOobject::MUST_READ_IF_MODIFIED,
                IOobject::NO_WRITE
        outputProperties_
                cloudName + "OutputProperties",
                this->mesh().time().timeName(),
                "uniform"/cloud::prefix/cloudName,
                this->mesh(),
                IOobject::READ_IF_PRESENT,
                IOobject::NO_WRITE
        solution_(this->mesh(), particleProperties_.subDict("solution")),
        constProps_(particleProperties_),
        subModelProperties_
            particleProperties_.subOrEmptyDict("subModels", true)
        rndGen_(0),
        cellOccupancyPtr_(),
        cellLengthScale_(mag(cbrt(this->mesh().V()))),
        pNumber_
                "pNumbers",
                this->mesh(),
                IOobject::NO_READ,
                IOobject::AUTO_WRITE
            this->mesh(),
            dimensionedScalar(dimless, 0.0)
        rho_(rho),
        U_(U),
        mu_(mu),
        g_(g),
        pAmbient_(0.0),
        forces_
            *this,
            this->mesh(),
            subModelProperties_.subOrEmptyDict
                "particleForces",
                true
            true
        functions_
            *this,
            particleProperties_.subOrEmptyDict("cloudFunctions"),
            true
        injectors_
            subModelProperties_.subOrEmptyDict("injectionModels"),
            *this
        dispersionModel_(nullptr),
        patchInteractionModel_(nullptr),
        stochasticCollisionModel_(nullptr),
        surfaceFilmModel_(nullptr),
        UIntegrator_(nullptr),
        UTrans_
            new volVectorField::Internal
                    this->name() + ":UTrans",
                    this->db().time().timeName(),
                    this->db(),
                this->mesh(),
                dimensionedVector(dimMass*dimVelocity, Zero)
        UCoeff_
            new volScalarField::Internal
                    this->name() + ":UCoeff",
                    this->db(),
                this->mesh(),
                dimensionedScalar( dimMass, 0)
        setModels();
        if (readFields)
            parcelType::readFields(*this);
            this->deleteLostParticles();
        if (solution_.resetSourcesOnStartup())
            resetSourceTerms();
        const fluidThermo& carrierThermo,
        MomentumCloud(cloudName, rho, U, carrierThermo.mu(), g, readFields)
        MomentumCloud<CloudType>& c,
        const word& name
        CloudType(c, name),
        particleProperties_(c.particleProperties_),
        outputProperties_(c.outputProperties_),
        solution_(c.solution_),
        constProps_(c.constProps_),
        subModelProperties_(c.subModelProperties_),
        rndGen_(c.rndGen_),
        cellOccupancyPtr_(nullptr),
        cellLengthScale_(c.cellLengthScale_),
        pNumber_(c.pNumber_),
        rho_(c.rho_),
        U_(c.U_),
        mu_(c.mu_),
        g_(c.g_),
        pAmbient_(c.pAmbient_),
        forces_(c.forces_),
        functions_(c.functions_),
        injectors_(c.injectors_),
        dispersionModel_(c.dispersionModel_->clone()),
        patchInteractionModel_(c.patchInteractionModel_->clone()),
        stochasticCollisionModel_(c.stochasticCollisionModel_->clone()),
        surfaceFilmModel_(c.surfaceFilmModel_->clone()),
        UIntegrator_(c.UIntegrator_->clone()),
        UTrans_
                    this->db(),
                    IOobject::NO_READ,
                    IOobject::NO_WRITE,
                    false
                c.UTrans_()
        UCoeff_
                    name + ":UCoeff",
                    this->db(),
                    IOobject::NO_READ,
                    IOobject::NO_WRITE,
                    false
                c.UCoeff_()
        const fvMesh& mesh,
        const word& name,
        const MomentumCloud<CloudType>& c
        CloudType(mesh, name, c),
        particleProperties_
                name + "Properties",
                mesh.time().constant(),
                mesh,
                IOobject::NO_READ,
                IOobject::NO_WRITE,
                false
        outputProperties_
                name + "OutputProperties",
                "uniform"/cloud::prefix/name,
                this->mesh(),
                IOobject::NO_READ,
                IOobject::NO_WRITE,
                false
        solution_(mesh),
        constProps_(),
        subModelProperties_(dictionary::null),
        rndGen_(0),
        rho_(c.rho_),
        U_(c.U_),
        mu_(c.mu_),
        g_(c.g_),
        forces_(*this, mesh),
        functions_(*this),
        injectors_(*this),
        UTrans_(nullptr),
        UCoeff_(nullptr)
    // * * * * * * * * * * * * * * * * Destructor  * * * * * * * * * * * * * * * //
    Foam::MomentumCloud<CloudType>::~MomentumCloud()
    // * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
    void Foam::MomentumCloud<CloudType>::setParcelThermoProperties
        parcelType& parcel,
        const scalar lagrangianDt
        parcel.rho() = constProps_.rho0();
    void Foam::MomentumCloud<CloudType>::checkParcelProperties
        parcelType& parcel,
        const scalar lagrangianDt,
        const bool fullyDescribed
        const scalar carrierDt = this->mesh().time().deltaTValue();
        parcel.stepFraction() = (carrierDt - lagrangianDt)/carrierDt;
        if (parcel.typeId() == -1)
            parcel.typeId() = constProps_.parcelTypeId();
    void Foam::MomentumCloud<CloudType>::storeState()
        cloudCopyPtr_.reset
            static_cast<MomentumCloud<CloudType>*>
                clone(this->name() + "Copy").ptr()
    void Foam::MomentumCloud<CloudType>::restoreState()
        cloudReset(cloudCopyPtr_());
        cloudCopyPtr_.clear();
    void Foam::MomentumCloud<CloudType>::resetSourceTerms()
        UTransRef().field() = Zero;
        UCoeffRef().field() = 0.0;
    template<class Type>
    void Foam::MomentumCloud<CloudType>::relax
        DimensionedField<Type, volMesh>& field,
        const DimensionedField<Type, volMesh>& field0,
        const word& name
    ) const
        const scalar coeff = solution_.relaxCoeff(name);
        field = field0 + coeff*(field - field0);
    void Foam::MomentumCloud<CloudType>::scale
        const word& name
    ) const
        field *= coeff;
    void Foam::MomentumCloud<CloudType>::relaxSources
        const MomentumCloud<CloudType>& cloudOldTime
        this->relax(UTrans_(), cloudOldTime.UTrans_(), "U");
        this->relax(UCoeff_(), cloudOldTime.UCoeff_(), "U");
    void Foam::MomentumCloud<CloudType>::scaleSources()
        this->scale(UTrans_(), "U");
        this->scale(UCoeff_(), "U");
    void Foam::MomentumCloud<CloudType>::preEvolve()
        // force calculation of mesh dimensions - needed for parallel runs
        // with topology change due to lazy evaluation of valid mesh dimensions
        label nGeometricD = this->mesh().nGeometricD();
        Info<< "\nSolving " << nGeometricD << "-D cloud " << this->name() << endl;
        this->dispersion().cacheFields(true);
        forces_.cacheFields(true);
        pAmbient_ = constProps_.dict().template
            lookupOrDefault<scalar>("pAmbient", pAmbient_);
        functions_.preEvolve();
    void Foam::MomentumCloud<CloudType>::evolve()
        if (solution_.canEvolve())
            typename parcelType::trackingData td(*this);
            solve(*this, td);
    void Foam::MomentumCloud<CloudType>::motion
    void Foam::MomentumCloud<CloudType>::patchData
        const parcelType& p,
        const polyPatch& pp,
        vector& nw,
        vector& Up
    ) const
        p.patchData(nw, Up);
        Up /= p.mesh().time().deltaTValue();
        // If this is a wall patch, then there may be a non-zero tangential velocity
        // component; the lid velocity in a lid-driven cavity case, for example. We
        // want the particle to interact with this velocity, so we look it up in the
        // velocity field and use it to set the wall-tangential component.
        if (!this->mesh().moving() && isA<wallPolyPatch>(pp))
            const label patchi = pp.index();
            const label patchFacei = pp.whichFace(p.face());
            // We only want to use the boundary condition value only if it is set
            // by the boundary condition. If the boundary values are extrapolated
            // (e.g., slip conditions) then they represent the motion of the fluid
            // just inside the domain rather than that of the wall itself.
            if (U_.boundaryField()[patchi].fixesValue())
                const vector Uw1 = U_.boundaryField()[patchi][patchFacei];
                const vector& Uw0 =
                    U_.oldTime().boundaryField()[patchi][patchFacei];
                const scalar f = p.currentTimeFraction();
                const vector Uw = Uw0 + f*(Uw1 - Uw0);
                const tensor nnw = nw*nw;
                Up = (nnw & Up) + Uw - (nnw & Uw);
    void Foam::MomentumCloud<CloudType>::updateMesh()
        injectors_.updateMesh();
        cellLengthScale_ = mag(cbrt(this->mesh().V()));
    void Foam::MomentumCloud<CloudType>::autoMap(const mapPolyMesh& mapper)
        Cloud<parcelType>::autoMap(mapper);
        updateMesh();
    void Foam::MomentumCloud<CloudType>::info()
        vector linearMomentum = linearMomentumOfSystem();
        reduce(linearMomentum, sumOp<vector>());
        scalar linearKineticEnergy = linearKineticEnergyOfSystem();
        reduce(linearKineticEnergy, sumOp<scalar>());
        Info<< "Cloud: " << this->name() << nl
            << "    Current number of parcels       = "
            << returnReduce(this->size(), sumOp<label>()) << nl
            << "    Current mass in system          = "
            << returnReduce(massInSystem(), sumOp<scalar>()) << nl
            << "    Linear momentum                 = "
            << linearMomentum << nl
            << "   |Linear momentum|                = "
            << mag(linearMomentum) << nl
            << "    Linear kinetic energy           = "
            << linearKineticEnergy << nl;
        injectors_.info(Info);
        this->surfaceFilm().info(Info);
        this->patchInteraction().info(Info);
