  3. SHM尖锐直角边界层添加
SHM尖锐直角边界层添加
4 帖子 2 发布者 3.4k 浏览
    hachikoi
    最近在使用OF计算环形浮体的自衰减,采用k-omega SST模型,网格基于SHM离散,但是边角处的边界层始终贴合不上,请大神支支招。
    具体问题如下:
    • 边界贴合质量:尝试通过提升stl质量(SW和犀牛加密)/增加surfaceFeatureExtractDict-includedAngle/提升snappyHexMeshDict-features和refinementSurfaces level均没能很好地将边角贴合地很好。远看质量还行,但是边角网格质量细看却很差,请问有何提升方法
    • 基于k-omega SST计算的yplus在1000左右,首层边界层设置为1.75mm,发现是在内环面拐角处边界层未添加上,尝试好多办法均无法添加,大家有没有添加的办法
    |  \\    /   O peration     | Version:  v2306                                 |
    |   \\  /    A nd           | Website:  www.openfoam.com                      |
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        object      snappyHexMeshDict;
    castellatedMesh true;
    snap true;
    addLayers true;
    geometry
        WECMiddle.stl
            type triSurfaceMesh;
            name WECMiddle;
            regions
                OBJECT // Defined in .stl file
                   name WECMiddle;
        WECMiddleWaveElevationRefineZone
            type searchableBox;
            min (-17.5 -17.5 -1.25);
            max (17.5 17.5 11.25);
        WECMiddleCornerRefineZone1
            type searchableCone;
            point1 (0 0 -1.5);
            radius1 12.75;
            innerRadius1 7.25;
            point2 (0 0 -1);
            radius2 12.75;
            innerRadius2 7.25;
        WECMiddleCornerRefineZone2
            point1 (0 0 11);
            radius1 12.75;
            innerRadius1 7.25;
            point2 (0 0 11.5);
            radius2 12.75;
            innerRadius2 7.25;
    castellatedMeshControls
        maxLocalCells 200000000;
        maxGlobalCells 300000000;
        minRefinementCells 20;
        nCellsBetweenLevels 3;
        maxLoadUnbalance 0.1;
        allowFreeStandingZoneFaces true;
        resolveFeatureAngle 30;
        features
                file "WECMiddle.eMesh";
                level 5;
        refinementSurfaces
            WECMiddle
                level (3 3); // 1.25/2/2^3 0.0781
                patchInfo
                    type wall;
                regions
                    WECMiddle
                        level (3 3);
                        patchInfo
                            type wall;
        refinementRegions
                mode inside;
                levels ((2 2));
                mode inside;
                levels ((4 4));
                mode inside;
                levels ((4 4));
        locationInMesh (0 0 0); // Generate meshes outside the body
    snapControls
        tolerance 2;
        implicitFeatureSnap false;
        explicitFeatureSnap true;
        multiRegionFeatureSnap true;
        detectNearSurfacesSnap true;
        nSmoothPatch 5;
        nSolveIter 300;
        nRelaxIter 8;
        nFeatureSnapIter 10;
        nSmoothInternal 5;
        nFaceSplitInterval 5;
    addLayersControls
        layers
            WECMiddle
                nSurfaceLayers 15;
        relativeSizes false;
        //thickness 0.1;
        firstLayerThickness 0.00175;
        //finalLayerThickness 0.1;
        expansionRatio 1.25;
        featureAngle 360;
        slipFeatureAngle 0;
        nGrow 0;
        nBufferCellsNoExtrude 0;
        minMedialAxisAngle 90;
        maxFaceThicknessRatio 0.5;
        maxThicknessToMedialRatio 0.3;
        minThickness 1e-06;
        nLayerIter 60;
        nRelaxIter 5;
        nSmoothSurfaceNormals 10;
        nSmoothNormals 3;
        nSmoothThickness 10;
        nRelaxedIter 20;
        nMedialAxisIter 10;
    meshQualityControls
        minVol 1e-20;
        minTetQuality 1e-20;
        minArea 1e-20;
        minTwist 0.05;
        minDeterminant 1e-06;
        minFaceWeight 0.02;
        minVolRatio 0.01;
        minTriangleTwist -1;
        minFlatness 0.5;
        maxNonOrtho 70;
        maxBoundarySkewness 20;
        maxInternalSkewness 4;
        maxConcave 80;
        nSmoothScale 4;
        errorReduction 0.75;
        relaxed
            minVol 1e-30;
            minTetQuality 1e-30;
            minArea 1e-30;
            minTwist 0.001;
            minFaceWeight 1e-06;
            minVolRatio 0.01;
            minFlatness 0.5;
            maxNonOrtho 75;
            maxInternalSkewness 8;
            maxConcave 80;
            nSmoothScale 4;
    mergeTolerance 1e-08;
    debug 0;
    • 首层边界层目前为1.75mm是调试很多次后得到的最小厚度,但仍然不满足要求,请问大家有没有进一步降低的方法
    先谢谢各位了:baobao:
    hachikoi
    环形浮体的边角周围做了加了处理,之前以为是过渡不均匀造成的,但改善效果不明显
    浮体外半径12.5m,内半径7.5m 高度12.5m 向上提升5m做自衰减
  • X 在线
    X 在线
    meshQualityControls 部分把 relaxed 里面的质量控制参数再放宽一些。然后 nRelaxedIter 设置为 0。
    hachikoi
    在 中回复了 xpqiu 最后由 hachikoi 编辑
    @xpqiu 感谢大佬回复,问题已解决 请问大佬有遇到过多重overset计算错误的问题吗
