  3. bubbleColumn算例进行网格加密后会发散?
2 帖子 2 发布者 2.1k 浏览
    cyberk
    对于openfoam7中的算例
    OpenFOAM/OpenFOAM-7/tutorials/multiphase/twoPhaseEulerFoam/RAS/bubbleColumn
    blocks
        hex (0 1 2 3 4 5 6 7) (25 75 1) simpleGrading (1 1 1)
    将其blockMeshDict中的网格数从(25 75 1)修改为(50 150 1)和(100 300 1)得到bubbleColumnFine和bubbleColumnMorefine。然后运行./Allrun,这两个算例会分别在4.82s和1.785s发散
    报错信息如下:
    Courant Number mean: 0.193424 max: 2.38733
    Max Ur Courant Number = 1.70125
    Time = 1.785
    PIMPLE: Iteration 1
    MULES: Solving for alpha.air
    alpha.air volume fraction = 0.300065  Min(alpha.air) = -1.42077e-16  Max(alpha.air) = 1.01947
    Constructing momentum equations
    smoothSolver:  Solving for e.air, Initial residual = 0.00251771, Final residual = 1.55265e-08, No Iterations 2
    smoothSolver:  Solving for e.water, Initial residual = 6.01592e-05, Final residual = 5.94292e-08, No Iterations 4
    min T.air 300
    min T.water 300.167
    GAMG:  Solving for p_rgh, Initial residual = 0.000206863, Final residual = 2.12447e-09, No Iterations 6
    PIMPLE: Iteration 2
    alpha.air volume fraction = 0.30008  Min(alpha.air) = -0.000167232  Max(alpha.air) = 1.00044
    smoothSolver:  Solving for e.air, Initial residual = 0.000588382, Final residual = 1.82242e-08, No Iterations 2
    smoothSolver:  Solving for e.water, Initial residual = 4.07019e-05, Final residual = 5.33076e-08, No Iterations 4
    min T.air 300
    min T.water 300.167
    GAMG:  Solving for p_rgh, Initial residual = 0.000299811, Final residual = 4.64565e-09, No Iterations 6
    PIMPLE: Iteration 3
    alpha.air volume fraction = 0.300078  Min(alpha.air) = -0.286261  Max(alpha.air) = 1.3119
    smoothSolver:  Solving for e.air, Initial residual = 0.000643277, Final residual = 7.16972e-08, No Iterations 4
    smoothSolver:  Solving for e.water, Initial residual = 3.51151e-05, Final residual = 6.91279e-08, No Iterations 3
    min T.air -57.4121
    min T.water 300.167
    GAMG:  Solving for p_rgh, Initial residual = 0.00045527, Final residual = 8.56624e-09, No Iterations 13
    bounding km, min: 2.22028e-16 max: 0.0271421 average: 0.000650568
    smoothSolver:  Solving for epsilonm, Initial residual = 0.129979, Final residual = 9.93029e-12, No Iterations 1
    bounding epsilonm, min: -0.100887 max: 55.5581 average: 0.246321
    smoothSolver:  Solving for km, Initial residual = 6.55536e-12, Final residual = 5.87794e-14, No Iterations 1
    bounding km, min: -0.000581692 max: 0.0170913 average: 0.000649872
    #2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
    #3  ? in "/lib/x86_64-linux-gnu/libm.so.6"
    #4  pow in "/lib/x86_64-linux-gnu/libm.so.6"
    #5  Foam::pow(Foam::Field<double>&, Foam::UList<double> const&, double const&) at ??:?
    #6  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::pow<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensioned<double> const&) at ??:?
    #7  Foam::dragModels::SchillerNaumann::CdRe() const at ??:?
    #8  Foam::dragModel::Ki() const at ??:?
    #9  Foam::dragModel::K() const at ??:?
    #10  Foam::BlendedInterfacialModel<Foam::dragModel>::K() const at ??:?
    #11  Foam::twoPhaseSystem::Kd() const at ??:?
    #12  Foam::RASModels::mixtureKEpsilon<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::PhaseCompressibleTurbulenceModel<Foam::phaseModel> > > >::Ct2() const at ??:?
    #13  Foam::RASModels::mixtureKEpsilon<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::PhaseCompressibleTurbulenceModel<Foam::phaseModel> > > >::correct() at ??:?
    #14  Foam::twoPhaseSystem::correctTurbulence() at ??:?
    通过paraview查看发散前的结果,可以看到epsilonm的值在局部区域有震荡(epsilonm的量程为2e-16到384)
    调整松弛因子也未能解决问题,想请教一下各位前辈这种发散是由什么造成的?又该如何解决?
    库朗数减小试一下 也就是时间步长减小试一下
