  3. 运行算例出现segmentation fault
4 帖子 2 发布者 3.4k 浏览
    Rachel0096
    写于 最后由 Rachel0096 编辑
    各位老师晚上好~
    我自定义求解器编译成功,在运行算例的时候,读取我自定义phaseCoupling.H文件,会出现segmentation fault。其中这个文件是参照之前文章提供的求解器,我只进行了小部分修改。通过逐行输出,可以发现问题主要出现在 Heat_Capacity[volID] += alpha_[cellI]*mesh_.V()[cellI]*Cp_[cellI];这一句。
    可以麻烦有经验的老师帮我看一下可能的错误嘛~
    phaseCoupling.H
     forAll(mesh_.cells(), cellI)
            if (vofID_[cellI] > 0.1)
                Info << " debug6 " << endl;
                // Get volume ID
                label volID = floor(vofID_[cellI] + 0.5);
                Info << " debug7 " << endl;
                noCells[volID] += 1;
                Info << " debug8 " << endl;
                cellVolume[volID] += mesh_.V()[cellI];
                Info << " debug9 " << endl;
                volume[volID] += alpha_[cellI]*mesh_.V()[cellI];
                Info << " debug10 " << endl;
                velocity[volID] += alpha_[cellI]*mesh_.V()[cellI]*U_[cellI];
                Info << " debug11 " << endl;
                position[volID] += alpha_[cellI]*mesh_.V()[cellI]*mesh_.C()[cellI];
                Info << " debug12 " << endl;
                Temperature[volID] += alpha_[cellI]*mesh_.V()[cellI]*T_[cellI];
                Info << " debug13 " << endl;
                Info << " debug14 " << endl;
                Density[volID] += alpha_[cellI]*mesh_.V()[cellI]*density_[cellI];
    报错信息:
     debug1
     debug2
     debug3
     debug4
     debug5
     debug6
     debug7
     debug8
     debug9
     debug10
     debug11
     debug12
     debug13
    #1  Foam::sigSegv::sigHandler(int) at ??:?
    #2  ? in /lib/x86_64-linux-gnu/libpthread.so.0
    #3  Foam::phaseCoupling::update() at ??:?
    #4  ? in ~/OpenFOAM/dyfluid-v2012/platforms/linux64GccDPInt32Opt/bin/mycompressible
    #5  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
    #6  ? in ~/OpenFOAM/dyfluid-v2012/platforms/linux64GccDPInt32Opt/bin/mycompressible
    Segmentation fault (core dumped)
    @Rachel0096 在 运行算例出现segmentation fault 中说:
    把这个东西在debug13之后,输出一下看看是什么
    R 1 条回复 最后回复
    Rachel0096
    @李东岳 李老师
    输出Heat_Capacity[volID]的结果是:Heat Capacity[volID]:9.0420861e-12,这个值异常的小,我后面对这个变量进行累加并加权平均,这导致我液滴的Cp几乎为零,这或许是我segmentation fault的原因?
    Cp_[cellI]输出一下
