  3. 关于interFoam 中的alphaEqn里面的两个系数cAlpha和icAlpha
8 帖子 5 发布者 11.1k 浏览
    yuan_neu
    写于 最后由 CFD中文网 编辑
    版本3.0.x中的interFoam里面的alphaEqn.H line46-54
    // Standard face-flux compression coefficient
    surfaceScalarField phic(mixture.cAlpha()*mag(phi/mesh.magSf()));
    // Add the optional isotropic compression contribution
    if (icAlpha > 0)
        phic *= (1.0 - icAlpha);
        phic += (mixture.cAlpha()*icAlpha)*fvc::interpolate(mag(U));
    查看了一下源文件, 这两个系数都是用户可以指定的,小弟不太明白,这两个系数的作用的什么?有知道的朋友告诉一下,谢谢!
    麻烦把所有alphaeqn.H里面的内容发一下:confused:
    CFD中国标准用户测试帐号
    目前由徐笑笑登录
    yuan_neu
    @cfd-china alphaeqn.H里面的内容如下
        word alphaScheme("div(phi,alpha)");
        word alpharScheme("div(phirb,alpha)");
        tmp<fv::ddtScheme<scalar> > ddtAlpha
            fv::ddtScheme<scalar>::New
                mesh,
                mesh.ddtScheme("ddt(alpha)")
        // Set the off-centering coefficient according to ddt scheme
        scalar ocCoeff = 0;
        if
            isType<fv::EulerDdtScheme<scalar> >(ddtAlpha())
         || isType<fv::localEulerDdtScheme<scalar> >(ddtAlpha())
            ocCoeff = 0;
        else if (isType<fv::CrankNicolsonDdtScheme<scalar> >(ddtAlpha()))
            if (nAlphaSubCycles > 1)
                FatalErrorIn(args.executable())
                    << "Sub-cycling is not supported "
                       "with the CrankNicolson ddt scheme"
                    << exit(FatalError);
            ocCoeff =
                refCast<fv::CrankNicolsonDdtScheme<scalar> >(ddtAlpha()).ocCoeff();
        else
                << "Only Euler and CrankNicolson ddt schemes are supported"
        scalar cnCoeff = 1.0/(1.0 + ocCoeff);
        if (icAlpha > 0)
        // Do not compress interface at non-coupled boundary faces
        // (inlets, outlets etc.)
        forAll(phic.boundaryField(), patchi)
            fvsPatchScalarField& phicp = phic.boundaryField()[patchi];
            if (!phicp.coupled())
                phicp == 0;
        tmp<surfaceScalarField> phiCN(phi);
        // Calculate the Crank-Nicolson off-centred volumetric flux
        if (ocCoeff > 0)
            phiCN = cnCoeff*phi + (1.0 - cnCoeff)*phi.oldTime();
        if (MULESCorr)
            fvScalarMatrix alpha1Eqn
                    LTS
                  ? fv::localEulerDdtScheme<scalar>(mesh).fvmDdt(alpha1)
                  : fv::EulerDdtScheme<scalar>(mesh).fvmDdt(alpha1)
              + fv::gaussConvectionScheme<scalar>
                    mesh,
                    phiCN,
                    upwind<scalar>(mesh, phiCN)
                ).fvmDiv(phiCN, alpha1)
            alpha1Eqn.solve();
            Info<< "Phase-1 volume fraction = "
                << alpha1.weightedAverage(mesh.Vsc()).value()
                << "  Min(" << alpha1.name() << ") = " << min(alpha1).value()
                << "  Max(" << alpha1.name() << ") = " << max(alpha1).value()
                << endl;
            tmp<surfaceScalarField> talphaPhiUD(alpha1Eqn.flux());
            alphaPhi = talphaPhiUD();//based on updated alpha from alpha1Eqn.solve() to correct alphaPhi
            if (alphaApplyPrevCorr && talphaPhiCorr0.valid())
                Info<< "Applying the previous iteration compression flux" << endl;
                MULES::correct(alpha1, alphaPhi, talphaPhiCorr0(), 1, 0);
                alphaPhi += talphaPhiCorr0();
            // Cache the upwind-flux
            talphaPhiCorr0 = talphaPhiUD;
            alpha2 = 1.0 - alpha1;
            mixture.correct();
        for (int aCorr=0; aCorr<nAlphaCorr; aCorr++)
            surfaceScalarField phir(phic*mixture.nHatf());
            tmp<surfaceScalarField> talphaPhiUn
                fvc::flux
                    phi,
                    alpha1,
                    alphaScheme
              + fvc::flux
                   -fvc::flux(-phir, alpha2, alpharScheme),
                    alpha1,
                    alpharScheme
            // Calculate the Crank-Nicolson off-centred alpha flux
            if (ocCoeff > 0)
                talphaPhiUn =
                    cnCoeff*talphaPhiUn + (1.0 - cnCoeff)*alphaPhi.oldTime();
            if (MULESCorr)
                tmp<surfaceScalarField> talphaPhiCorr(talphaPhiUn() - alphaPhi);
                volScalarField alpha10("alpha10", alpha1);
                MULES::correct(alpha1, talphaPhiUn(), talphaPhiCorr(), 1, 0);
                // Under-relax the correction for all but the 1st corrector
                if (aCorr == 0)
                    alphaPhi += talphaPhiCorr();
                else
                    alpha1 = 0.5*alpha1 + 0.5*alpha10;
                    alphaPhi += 0.5*talphaPhiCorr();
            else
                alphaPhi = talphaPhiUn;
                MULES::explicitSolve(alpha1, phiCN, alphaPhi, 1, 0);
            mixture.correct();
        if (alphaApplyPrevCorr && MULESCorr)
            talphaPhiCorr0 = alphaPhi - talphaPhiCorr0;
        if
            word(mesh.ddtScheme("ddt(rho,U)"))
         == fv::EulerDdtScheme<vector>::typeName
            rhoPhi = alphaPhi*(rho1 - rho2) + phiCN*rho2;
        else
            if (ocCoeff > 0)
                // Calculate the end-of-time-step alpha flux
                alphaPhi = (alphaPhi - (1.0 - cnCoeff)*alphaPhi.oldTime())/cnCoeff;
            // Calculate the end-of-time-step mass flux
            rhoPhi = alphaPhi*(rho1 - rho2) + phi*rho2;
            << endl;
  • supersoldierS 离线
    supersoldierS 离线
    supersoldier
    在论文DYNAMIC MESHING AROUND FLUID-FLUID INTERFACES WITH APPLICATIONS TO DROPLET TRACKING IN CONTRACTION GEOMETRIES第58页最上部有写cAlpha的作用。
    The cAlpha keyword specified in the file <case>/system/fvSolution is
    a factor that controls the compression of the interface, where 0 corresponds to no
    compression. After solving the volume fluid equation, the density and viscosity are
    modified using the new values of α.
    Y yhdthuY 3 条回复 最后回复
    yuan_neu
    在 中回复了 supersoldier 最后由 编辑
    @supersoldier thanks
    yuan_neu
    @supersoldier 非常有用的回复,直接帮我解决了很多疑问。谢谢!!
  • yhdthuY 离线
    yhdthuY 离线
    yhdthu 大神
    @supersoldier 你好,可以再详细解释一下不?
    长风破浪会有时,直挂云帆济沧海
    CYW
    在 中回复了 yuan_neu 最后由 编辑
    @yuan_neu 请问icAlpha的作用是什么?
