  3. 用fluent3DMeshToFoam转化网格的时候报错
2 帖子 2 发布者 3.0k 浏览
  • 好 离线
    好 离线
    好好科研
    请教一下,我在icem保存用acsii格式保存了msh文件,用fluent3DMeshToFoam转化网格时出现如下报错,不知道是什么原因呢,操作是在天河二号上进行的。
    patch 15 from Fluent indices: 59793665 to: 59902377 type: wall
    #0  Foam::error::printStack(Foam::Ostream&)sh: addr2line: command not found
     addr2line failed
    #1  Foam::sigSegv::sigHandler(int)sh: addr2line: command not found
     addr2line failed
    #2  ?sh: addr2line: command not found
     addr2line failed
    #3  Foam::polyTopoChange::renumberCompact(Foam::List<int> const&, Foam::List<int>&)sh: addr2line: command not found
     addr2line failed
    #4  Foam::polyTopoChange::compact(bool, bool, int&, Foam::List<int>&, Foam::List<int>&)sh: addr2line: command not found
     addr2line failed
    #5  Foam::polyTopoChange::compactAndReorder(Foam::polyMesh const&, bool, bool, bool, int&, Foam::Field<Foam::Vector<double> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::Map<int> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam::Map<int> >&)sh: addr2line: command not found
     addr2line failed
    #6  Foam::polyTopoChange::changeMesh(Foam::polyMesh&, bool, bool, bool, bool)sh: addr2line: command not found
     addr2line failed
    #7  ?sh: addr2line: command not found
     addr2line failed
    #8  __libc_start_mainsh: addr2line: command not found
     addr2line failed
    #9  ?sh: addr2line: command not found
     addr2line failed
    缺这个包:binutils
    或者路径没配置对,可以用echo $PATH看看有没有/usr/bin这一项
