  3. 请教:第三代涡识别方法Liutex的代码在linux中运行的问题
66 帖子 15 发布者 102.3k 浏览
  • 五好青年五 离线
    五好青年五 离线
    五好青年
    在 中回复了 五好青年 最后由 编辑
    已测试,OpenFOAM-2006以上版本
    感谢
  • 五好青年五 离线
    五好青年五 离线
    五好青年
    在 中回复了 yhdthu 最后由 编辑
    @yhdthu
    您好
    我尝试往OF官网版本上移植,提示了一些报错,主要有:error: ‘complex’ was not declared in this scope
    经过很久的折腾,发现您可能参考tensor.C文件来修改的,并且我对比了OpenFOAM低版本的tensor.C来逐个修改报错,但是始终没能解决。
    可否帮忙帮忙编一个低版本的,或者给一些修改的思路
    感谢
    dyfluid@dyfluid:~/postVersion$ wclean
    dyfluid@dyfluid:~/postVersion$ wmake
    Making dependency list for source file Liutex.C
    SOURCE=Liutex.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/dyfluid/OpenFOAM/OpenFOAM-2.4.x/src/finiteVolume/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-2.4.x/src/meshTools/lnInclude -IlnInclude -I. -I/home/dyfluid/OpenFOAM/OpenFOAM-2.4.x/src/OpenFOAM/lnInclude -I/home/dyfluid/OpenFOAM/OpenFOAM-2.4.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/Liutex.o
    Liutex.C: In function ‘Foam::vector getZdEVec(const tensor&)’:
    Liutex.C:44:18: error: ‘complex’ was not declared in this scope
         const Vector<complex> EVals(eigenValues(T));
    Liutex.C:44:25: error: template argument 1 is invalid
    Liutex.C:44:47: error: cannot convert ‘Foam::vector {aka Foam::Vector<double>}’ to ‘const int’ in initialization
    Liutex.C:46:25: error: type/value mismatch at argument 1 in template parameter list for ‘template<class Cmpt> class Foam::Vector’
         const Vector<complex> standardBasis1(Zero, pTraits<complex>::one, Zero);
    Liutex.C:46:25: note:   expected a type, got ‘complex’
    Liutex.C:46:42: error: ‘Zero’ was not declared in this scope
    Liutex.C:46:63: error: type/value mismatch at argument 1 in template parameter list for ‘template<class PrimitiveType> class Foam::pTraits’
    Liutex.C:46:63: note:   expected a type, got ‘complex’
    Liutex.C:46:75: error: expression list treated as compound expression in initializer [-fpermissive]
    Liutex.C:47:25: error: type/value mismatch at argument 1 in template parameter list for ‘template<class Cmpt> class Foam::Vector’
         const Vector<complex> standardBasis2(Zero, Zero, pTraits<complex>::one);
    Liutex.C:47:25: note:   expected a type, got ‘complex’
    Liutex.C:47:69: error: type/value mismatch at argument 1 in template parameter list for ‘template<class PrimitiveType> class Foam::pTraits’
    Liutex.C:47:69: note:   expected a type, got ‘complex’
    Liutex.C:47:75: error: expression list treated as compound expression in initializer [-fpermissive]
    Liutex.C:48:25: error: type/value mismatch at argument 1 in template parameter list for ‘template<class Cmpt> class Foam::Vector’
         const Vector<complex> EVec
    Liutex.C:48:25: note:   expected a type, got ‘complex’
    Liutex.C:50:30: error: request for member ‘x’ in ‘EVals’, which is of non-class type ‘const int’
             eigenVector(T, EVals.x(), standardBasis1, standardBasis2)
    Liutex.C:53:23: error: request for member ‘x’ in ‘EVec’, which is of non-class type ‘const int’
         vector EVecR(EVec.x().real(), EVec.y().real(), EVec.z().real());
    Liutex.C:53:40: error: request for member ‘y’ in ‘EVec’, which is of non-class type ‘const int’
    Liutex.C:53:57: error: request for member ‘z’ in ‘EVec’, which is of non-class type ‘const int’
    Liutex.C: In function ‘Foam::tensor rotation(const vector&)’:
    Liutex.C:62:14: error: ‘Zero’ was not declared in this scope
         tensor q(Zero);
    Liutex.C: In function ‘Foam::vector liutex(const tensor&, const vector&)’:
    Liutex.C:100:19: error: ‘Zero’ was not declared in this scope
         vector liutex(Zero);
    Liutex.C: In function ‘int main(int, char**)’:
    Liutex.C:156:48: error: ‘Zero’ was not declared in this scope
                 dimensionedVector("zero", dimless, Zero)
    Liutex.C:158:39: error: ‘Foam::volVectorField {aka class Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>}’ has no member named ‘primitiveFieldRef’
             vectorField& iLiutex = Liutex.primitiveFieldRef();
    Liutex.C:174:43: error: ‘Foam::volTensorField {aka class Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>}’ has no member named ‘primitiveField’
             const tensorField& iGradU = gradU.primitiveField();
    Liutex.dep:674: recipe for target 'Make/linux64GccDPOpt/Liutex.o' failed
    make: *** [Make/linux64GccDPOpt/Liutex.o] Error 1
    @yhdthu 你写的看起来比期刊上的那个neat很多:146:
    五好青年五 1 条回复 最后回复
  • 五好青年五 离线
    五好青年五 离线
    五好青年
    测试了一下这个程序,给大家反馈下
    1. OpenFOAM-v2006以上可用
    2. OpenFOAM-8调试好了,编译没报错,但是处理算例报错
    3. foam-extend4.1上,调试好了,但是不识别浸入边界
    目前只能在高版本上用了,如果谁编译了低版本,记得回来分享下啊
    五好青年五 尚 2 条回复 最后回复
  • 五好青年五 离线
    五好青年五 离线
    五好青年
    在 中回复了 五好青年 最后由 编辑
    东岳老师,能不能分享一个空的Ubuntu虚拟机出来呢。我记得以前是有的呢,但是找不到啦。
    这样我在空的ubuntu系统上,尝试装一下不同版本,安装完我再反馈提供给您。分享给CFD中文网的Fans
  • 尚 在线
    尚 在线
    尚善若水
    在 中回复了 五好青年 最后由 编辑
    #26
    @五好青年 请问老师,后来of8的可用了吗?
    五好青年五 1 条回复 最后回复
  • 五好青年五 离线
    五好青年五 离线
    五好青年
    在 中回复了 尚善若水 最后由 编辑
    #27
    @尚善若水 可以啦,直接用刘老师的fortran程序
    尚 2 条回复 最后回复
  • 尚 在线
    尚 在线
    尚善若水
    在 中回复了 五好青年 最后由 编辑
    #28
    @五好青年 好的,我去查下,谢谢。
    按道理来说 这个C++跑起来应该没问题啊 为什么后来大佬们都转fortran了呢
    我把 http://www.jhydrodynamics.com/en/download-of-liutex-code/ 这个链接里面的代码,小改了一下,放到了OpenFOAM-9里面可以编译成功。
    下载:Rotex.zip
    我目前来看这个代码是每个网格做了循环,每个循环里面做了大量的操作。因此如果网格越多,确实会越来越慢。这跟其他的变量算起来完全不一样,其他的变量比如Q之类都是在体场层面做操作,这个Rotex从代码上来看,要从cell做循环来操作。
    哪个大佬可以提供个算例,我来测试下。
  • 尚 在线
    尚 在线
    尚善若水
    在 中回复了 五好青年 最后由 编辑
    #31
    @五好青年 再次来打扰下 seeeeeeeeeeer 老师,没 google到 fortran 代码,可以给我贴一个吗?感谢。
    在 中回复了 bestucan 最后由 李东岳 编辑
    #32
    @bestucan 确实,这个大佬竟然等了半个月。。。是不是家里服务器太多了,有一个算例跑起来忘了,半个月之后才想起来,发现还在算Rotex!
    之前不是说有个土豪车太多了,扔某个车库一个玛莎拉蒂,几年之后才想起来,车上已经一层灰。
    256³的网格算了半个月都没有算出一个时间步文件!
    :xiezuoye:
    bestucanB 1 条回复 最后回复
    @李东岳 佛系计算,不给服务器压力,不push
    :shangxue:
    coolhhh 神
    #34
    @yhdthu 在 请教:第三代涡识别方法Liutex的代码在linux中运行的问题 中说:
    @yfleung jhd上的代码有bug,且效率低,我自己重写可用。
    https://cloud.tsinghua.edu.cn/d/05b0149e37904e7ca61c/
    你好,这个下载地址已经失效了,能否再提供一下吗,非常感谢
    @bestucan 想当年2021年这个时候,我还在计算LES。3台服务器,每个64核心每个跑一个算例。600万网格也是算了半个月,每个算了1000秒。现在俺手握800核,LES跑的很血腥,3000万网格跑的跟单相流一样。
    @李东岳 摩尔定律之东岳流体分律:146:
    coolhhh 神
    1、李老师,我用OpenFOAM-8编译了这个程序,编译过程提示有一些未使用变量,但能正常编译。
    Making dependency list for source file Rotex.C
    g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I/home/install/OpenFOAM/OpenFOAM-8/src/finiteVolume/lnInclude -I/home/install/OpenFOAM/OpenFOAM-8/src/meshTools/lnInclude -IlnInclude -I. -I/home/install/OpenFOAM/OpenFOAM-8/src/OpenFOAM/lnInclude -I/home/install/OpenFOAM/OpenFOAM-8/src/OSspecific/POSIX/lnInclude   -fPIC -c Rotex.C -o Make/linux64GccDPInt32Opt/Rotex.o
    Rotex.C: In function \u2018int main(int, char**)\u2019:
    Rotex.C:153:20: warning: unused variable \u2018eig1c_r\u2019 [-Wunused-variable]
      153 |             scalar eig1c_r=-0.5*(aaaa+bbbb)-aa/3.0;
    Rotex.C:154:20: warning: unused variable \u2018eig1c_i\u2019 [-Wunused-variable]
      154 |             scalar eig1c_i=0.5*Foam::sqrt(scalar(3.0))*(aaaa-bbbb);
    Rotex.C:155:20: warning: unused variable \u2018eig2c_r\u2019 [-Wunused-variable]
      155 |             scalar eig2c_r=-0.5*(aaaa+bbbb)-aa/3.0;
    Rotex.C:156:20: warning: unused variable \u2018eig2c_i\u2019 [-Wunused-variable]
      156 |             scalar eig2c_i=-0.5*Foam::sqrt(scalar(3.0))*(aaaa-bbbb);
    g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I/home/install/OpenFOAM/OpenFOAM-8/src/finiteVolume/lnInclude -I/home/install/OpenFOAM/OpenFOAM-8/src/meshTools/lnInclude -IlnInclude -I. -I/home/install/OpenFOAM/OpenFOAM-8/src/OpenFOAM/lnInclude -I/home/install/OpenFOAM/OpenFOAM-8/src/OSspecific/POSIX/lnInclude   -fPIC -fuse-ld=bfd -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/Rotex.o -L/home/install/OpenFOAM/OpenFOAM-8/platforms/linux64GccDPInt32Opt/lib \
        -lfiniteVolume -lfvOptions -lmeshTools -lOpenFOAM -ldl  \
         -lm -o /home/user1/OpenFOAM/user1-8/platforms/linux64GccDPInt32Opt/bin/Rotex
    2、提供4个加载CDRFG脉动风的空风洞算例结果下载链接:
    (1)3个算例用snappyHexMesh画的六面体网格,数量分别为9.6w,150w,364w。
    (2)1个算例用fluentmeshing画的poly网格,网格数量为141w
    (3)RotexCase下载链接:
    链接:https://pan.baidu.com/s/1HQZkWVg2-ZKUF8SmqwkwOg
    提取码:fgzl
    3、测试结果
    (1)9.6w SHM网格算例,Rotex用单核、并行都能正常计算,单核40 s,并行20核计算用0.36 s。但用paraview看后处理结果,虽然可以看到Rotex数据,但由于Rotex输出的结果为矢量,画contour图的时候,选项找不到Rotex,但能选择Lambda2和Q画等值面图。
    问题是采用Liutex如何画出三维形状的涡?
    这是选择Rotex画出来的纵向截面图:
    这是选择Q准则画出的涡形状:
    (2)150w SHM网格算例。Rotex并行20核计算用时127 s。
    (3)364w SHM网格算例。Rotex并行20核计算用时1855 s。可以看出运行Rotex随着网格增加,运行时间是非线性增加的。
    (4)141w poly网格算例。Rotex并行20核计算,报错Floating point exception,但运行Lambda2和Q画等值面图,能正常运行。
    Time = 9
        Reading U
    [4] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
    [4] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [4] #2  ? in "/lib64/libc.so.6"
    [4] #3  ? at ??:?
    [4] #4  __libc_start_main in "/lib64/libc.so.6"
    [4] #5  ? at ??:?
    [hpws14:21072] *** Process received signal ***
    [hpws14:21072] Signal: Floating point exception (8)
    [hpws14:21072] Signal code:  (-6)
    [hpws14:21072] Failing at address: 0x3e800005250
    [hpws14:21072] [ 0] /lib64/libc.so.6(+0x36400)[0x7fab592fb400]
    [hpws14:21072] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x7fab592fb387]
    [hpws14:21072] [ 2] /lib64/libc.so.6(+0x36400)[0x7fab592fb400]
    [hpws14:21072] [ 3] Rotex[0x4136e0]
    [hpws14:21072] [ 4] /lib64/libc.so.6(__libc_start_main+0xf5)[0x7fab592e7555]
    [hpws14:21072] [ 5] Rotex[0x4146f0]
    [hpws14:21072] *** End of error message ***
    [9] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
    [9] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [9] #2  ? in "/lib64/libc.so.6"
    [9] #3  ? at ??:?
    [9] #4  __libc_start_main in "/lib64/libc.so.6"
    [9] #5  ? at ??:?
    [hpws14:21077] *** Process received signal ***
    [hpws14:21077] Signal: Floating point exception (8)
    [hpws14:21077] Signal code:  (-6)
    [hpws14:21077] Failing at address: 0x3e800005255
    [hpws14:21077] [ 0] /lib64/libc.so.6(+0x36400)[0x7f02ac8ea400]
    [hpws14:21077] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x7f02ac8ea387]
    [hpws14:21077] [ 2] /lib64/libc.so.6(+0x36400)[0x7f02ac8ea400]
    [hpws14:21077] [ 3] Rotex[0x4136e0]
    [hpws14:21077] [ 4] /lib64/libc.so.6(__libc_start_main+0xf5)[0x7f02ac8d6555]
    [hpws14:21077] [ 5] Rotex[0x4146f0]
    [hpws14:21077] *** End of error message ***
    Primary job  terminated normally, but 1 process returned
    a non-zero exit code. Per user-direction, the job has been aborted.
    [6] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
    [6] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [6] #2  ? in "/lib64/libc.so.6"
    [6] #3  ? at ??:?
    [6] #4  __libc_start_main--------------------------------------------------------------------------
    mpirun noticed that process rank 9 with PID 0 on node hpws14 exited on signal 8 (Floating point exception).
    这是poly网格选择Q准则画出的涡形状:
    @coolhhh 在 请教:第三代涡识别方法Liutex的代码在linux中运行的问题 中说:
    你用calculator做一个计算器,计算Liutex的mag,然后做等值面图可以么。
    这个可能要看一下liutex的sci的定义,看是不是通过这个方法来进行的。
    我下载你150万网格的看下Liutex哪一块最耗费时间。
    coolhhh 神
    @李东岳 在 请教:第三代涡识别方法Liutex的代码在linux中运行的问题 中说:
    李老师,我看了刘老师的论文(刘超群, Liutex-涡定义和第三代涡识别方法. 空气动力学学报, 2020. 038(003): 第413-431,478页.),里边提到以下几点:
    1. Liutex算出的是一个矢量,而Q是标量。
    2.文章中提到Liutex为基础的几个涡识别方法,其中之一就是可以用计算mag来画等值面,但这个时候又需要指定阈值:
    3.用paraview计算9.6w 网格的算例的mag(Rotex),阈值分别取不同结果如下。Liutex采用幅值等值面因此会存在跟用Q准则一样指定阈值的问题,但根据论文意思是此时画出的等值面和Liutex向量线是大致平行的。
    (1)mag(Rotex)=0.1结果
    (2)mag(Rotex)=0.5结果
    (3)mag(Rotex)=2结果
    我测试了一下,单核计算,对于这个150万网格的算例,每个网格的操作要占用30ms来计算,150万网格就是45000秒。
    因为我对Liutex这个计算过程不熟悉,不清楚这个是否能做简化。
