  3. Flex有人了解么?
Flex有人了解么?
2 帖子 2 发布者 3.8k 浏览
    写于 最后由 CFD中文网 编辑
    http://flex.sourceforge.net/
    https://www.baidu.com/s?wd=flex linux&pn=0&oq=flex linux&tn=baiduhome_pg&ie=utf-8&usm=1&rsv_idx=2&rsv_pq=f10c1bcb0017d3ef&rsv_t=63192P0pX%2BoImYG7RGAFEMIserOduB%2FtPDLiDV3nZJ7vJT16E8uP5L4%2BN0qrMI3xzQ4U
    目前OpenFOAM关于网格转换等需要使用Flex,不过这个东西主要是做什么的?
    目前只是粗略的发现他会生成一个.C文件
    Flex is a tool for generating scanners. A scanner, sometimes called a tokenizer, is a program which recognizes lexical patterns in text. The flex program reads user-specified input files, or its standard input if no file names are given, for a description of a scanner to generate. The description is in the form of pairs of regular expressions and C code, called rules. Flex generates a C source file named, "lex.yy.c", which defines the function yylex(). The file "lex.yy.c" can be compiled and linked to produce an executable. When the executable is run, it analyzes its input for occurrences of text matching the regular expressions for each rule. Whenever it finds a match, it executes the corresponding C code.
    CFD中国标准用户测试帐号
    目前由徐笑笑登录
  • WayneW 离线
    WayneW 离线
    Wayne
    利用正则表达式生成文本分析程序
    主要做AI,懂一点CFD
