  3. change the k at first grid?
11 帖子 2 发布者 8.3k 浏览
    https://dyfluid.coding.net/p/OpenFOAM_dyfluid/d/OpenFOAM_dyfluid/git/tree/master/solver/dyfluidFoam.C 67-73
    K 2 条回复 最后回复
  • K 离线
    K 离线
    kimy
    @东岳 Hi, dongyue. Thanks a lot. I understood this method but can I use it in a kwallfunction? After I tried the code you suggested, the compiling error is mesh not decalred in this scope. If I would like to update the first grid value in the kwallfunction like epsilonwallfunction did, is it possible?
    Looks you used that in a Class. Try to include the following code snippet before you use it:
    const fvMesh& mesh = k.mesh();
    Everything is possible as long as it is physical.
    K 1 条回复 最后回复
  • K 离线
    K 离线
    kimy
    @东岳
    derivedFvPatchFields/wallFunctions/kqRWallFunctions/kOngWallFunction/kOngWallFunctionFvPatchScalarField.C: In member function 'virtual void Foam::kOngWallFunctionFvPatchScalarField::updateCoeffs()':
    derivedFvPatchFields/wallFunctions/kqRWallFunctions/kOngWallFunction/kOngWallFunctionFvPatchScalarField.C:190:40: error: 'class Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >' has no member named 'mesh'
         const fvMesh& mesh = turbModel.k().mesh();
    @kimy 在 change the k at first grid? 中说:
    kqRWallFunctions
    If p is a fvPatch
    const fvMesh& mesh = p.boundaryMesh().mesh();
    K 1 条回复 最后回复
  • K 离线
    K 离线
    kimy
    @东岳
    derivedFvPatchFields/wallFunctions/kqRWallFunctions/kOngWallFunction/kOngWallFunctionFvPatchScalarField.C:204:22: error: 'p' was not declared in this scope
    derivedFvPatchFields/wallFunctions/kqRWallFunctions/kOngWallFunction/kOngWallFunctionFvPatchScalarField.C:209:28: error: passing 'const volScalarField {aka const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>}' as 'this' argument discards qualifiers [-fpermissive]
             k.boundaryFieldRef()[patchID] = 0;
    You should highlight you code yourself. Otherwise I need modify it everytime.
    The above code runs well if your put it inside the following
    template<class Type>
    Foam::kqRWallFunctionFvPatchField<Type>::kqRWallFunctionFvPatchField
        const kqRWallFunctionFvPatchField& ptf,
        const fvPatch& p,
        const DimensionedField<Type, volMesh>& iF,
        const fvPatchFieldMapper& mapper
        zeroGradientFvPatchField<Type>(ptf, p, iF, mapper)
  • K 离线
    K 离线
    kimy
    Hi Dongyue, I changed the codes as following, but the result dosn't change, k in the first grid is still not calculated by my formulation. I cannot understand.
     tmp<volScalarField> tk = turbModel.k();
         volScalarField k = tk;
        const tmp<scalarField> tnuw = turbModel.nu(patchi);
        const scalarField& nuw = tnuw();
        const tmp<scalarField> tnutw = turbModel.nut(patchi);
        const scalarField& nutw = tnutw();
        const fvPatchVectorField& Uw = turbModel.U().boundaryField()[patchi];
        const scalarField magGradUw(mag(Uw.snGrad()));
        const scalar Cmu25 = pow025(Cmu_);
        scalarField& kw = *this;
    forAll(nutw,facei)
             label celli = patch().faceCells()[facei];
                k[celli] =
                   ((nutw[facei] + nuw[facei])*magGradUw[facei])*((nutw[facei] + nuw[facei])*magGradUw[facei])/(Cmu25*Cmu25);
  • K 离线
    K 离线
    kimy
    @东岳 I tried to write these codes in simpleFoam.C,
    label patchID = mesh.boundaryMesh().findPatchID("wall");
    turbulence->k().boundaryFieldRef()[patchID] = 0;
    And I got the error:
    newsimpleFoam.C: In function 'int main(int, char**)':
    newsimpleFoam.C:77:25: error: 'class Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >' has no member named 'boundaryFieldRef' turbulence->k().boundaryFieldRef()[patchID] = 0;
    Thats a tmp, not a regular volScalarField, try turbulence->k().ref().boundaryFieldRef()[patchID] = 0;
