  3. 东岳流体 hello CFD 编译案例 问题
10 帖子 4 发布者 8.3k 浏览
  • 小 离线
    小 离线
    小考拉
    大家好!
    最近刚刚接触编译。我按照东岳流体网站上的例子编译 myFirstFoam的求解器,输出 hello CFD
    .C文件 files文件 和 options文件 都是按照李老师网页上写的编写的。 wmake之后也没有报错,可是就是无法输出hello CFD
    我用的是Gcc编译,版本是openfoam4.1
    wmake之后如下
    Make/options:1:11: warning: backslash-newline at end of file [enabled by default]
     EXE_INC = \
    Making dependency list for source file myFirstFoam.C
    g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3  -DNoRepository -ftemplate-depth-100 -I/project/xiongqi/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude -I/project/xiongqi/OpenFOAM/OpenFOAM-4.1/src/meshTools/lnInclude -IlnInclude -I. -I/project/xiongqi/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude -I/project/xiongqi/OpenFOAM/OpenFOAM-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c myFirstFoam.C -o Make/linux64GccDPInt32Opt/myFirstFoam.o
    g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3  -DNoRepository -ftemplate-depth-100 -I/project/xiongqi/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude -I/project/xiongqi/OpenFOAM/OpenFOAM-4.1/src/meshTools/lnInclude -IlnInclude -I. -I/project/xiongqi/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude -I/project/xiongqi/OpenFOAM/OpenFOAM-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/myFirstFoam.o -L/project/xiongqi/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/lib \
         -lOpenFOAM -ldl  \
         -lm -o /project/xiongqi/OpenFOAM_tut/myFirstFoam
    然后我输入 myFirstFoam命令之后
    [xiongqi@swarm01 OpenFOAM_tut]$ myFirstFoam
    -bash: myFirstFoam: command not found
    大家知道这个原因吗??
    把你的options贴一下看看
  • 小 离线
    小 离线
    小考拉
    EXE_INC = \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude
    我在windows版本下的openFoam运行成功了,放到Linux系统下面就不行了。。
  • adcpkA 离线
    adcpkA 离线
    adcpk
    可能是windows和linux文件换行符的问题
    小 1 条回复 最后回复
    在 中回复了 小考拉 最后由 编辑
    @小考拉 可以把你的程序打包上传一下我在linux下试试
    小 1 条回复 最后回复
    我最近在打算重写这部分内容,包含在《无痛苦N-S方程笔记里面》,作为入门资料
    在 中回复了 小考拉 最后由 编辑
    @小考拉 输出文件的路径不对,一般是放到$FOAM_USER_APPBIN下面,你这个放到当前目录了。
    Windows可以执行当前目录下的可执行文件,但Linux需要用./app这种方式才能执行。
    小 1 条回复 最后回复
  • 小 离线
    小 离线
    小考拉
    @东岳
    OpenFOAM_tut.tar
    实验发现 利用openfoam4.1的Gcc编译器 无法生成 myFirstFoam.exe这个程序
  • 小 离线
    小 离线
    小考拉
    在 中回复了 adcpk 最后由 编辑
    @adcpk
    在windows下面编译也会出现这个warning
  • 小 离线
    小 离线
    小考拉
    在 中回复了 wwzhao 最后由 编辑
    @wwzhao
    谢谢老师!问题已经解决。果然是 输出文件的路径不对!应该是 放到$FOAM_USER_APPBIN下面:chitang:
