  3. 关于数值模拟离心泵过程中发散的一些问题
关于数值模拟离心泵过程中发散的一些问题
15 帖子 3 发布者 16.7k 浏览
    运算的log文件贴一下?simpleFoam的log
    cfd-cxb
    您好,算例运行不起来,只能跑一步
    Create time
    Create mesh for time = 0
    Initializing the GGI interpolator between master/shadow patches: GUIDE-OUTLET/IMPELLER-INLET
    Initializing the GGI interpolator between master/shadow patches: IMPELLER-OUTLET/VOLUTE-INLET
    SIMPLE: no convergence criteria found. Calculations will run for 1400 steps.
    Reading field p
    Reading field U
    Selecting RAS turbulence model RNGkEpsilon
    RNGkEpsilonCoeffs
        Cmu             0.0845;
        C1              1.42;
        C2              1.68;
        alphak          1.39;
        alphaEps        1.39;
        eta0            4.38;
        beta            0.012;
        sigmak          0.71942;
        sigmaEps        0.71942;
    Creating MRF for cell zone IMPELLER. rpm = 2900
    Excluded patches: 2(3 4)
    Starting time loop
    Time = 1
    smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.0108375, No Iterations 2
    smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.0104409, No Iterations 2
    smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.0104084, No Iterations 2
    GAMG:  Solving for p, Initial residual = 1, Final residual = 0.027634, No Iterations 6
    GAMG:  Solving for p, Initial residual = 0.0357851, Final residual = 0.000575861, No Iterations 2
    time step continuity errors : sum local = 7.76946, global = 0.352411, cumulative = 0.352411
    smoothSolver:  Solving for epsilon, Initial residual = 0.13384, Final residual = 0.00135303, No Iterations 2
    bounding epsilon, min: -2.55034 max: 52.4243 average: 2.34921
    smoothSolver:  Solving for k, Initial residual = 1, Final residual = 0.0250789, No Iterations 2
    ExecutionTime = 12.85 s  ClockTime = 13 s
    Time = 2
    smoothSolver:  Solving for Ux, Initial residual = 0.20708, Final residual = 0.00402441, No Iterations 2
    smoothSolver:  Solving for Uy, Initial residual = 0.249236, Final residual = 0.0056065, No Iterations 2
    smoothSolver:  Solving for Uz, Initial residual = 0.222885, Final residual = 0.00479877, No Iterations 2
    cfd-cxb
    我换用linearUpwind后到200多步还是发散了,谢谢您!
    调节一下你的k和epsilon初始的值,从log来看你的epsilon不可实现。
    cfd-cxb
    首先,非常感谢您的回复
    我调整了k以及epsilon,但是还是不可以,当我将div(phi,U)调为upwind或者linearUpwind Gauss时,div(phi,k)与div(phi,epsilon)不管是那种格式都能算,但是若是我将div(phi,U)设为limitedlinearV 1格式,div(phi,k)与div(phi,epsilon)不管那种格式都不行,算例都只算一步。
  • 赵 离线
    赵 离线
    赵一铭
    我发现个问题,你那个同时调用GGI和MRF?
    cfd-cxb
    恩恩,是的,交界面处理使用的是GGI
  • 赵 离线
    赵 离线
    赵一铭
    我记得ggi和MRF不能同时用的。。
    cfd-cxb
    谢谢您的回复,我用的是foam-extend版本,里面有同时调用的例子的
    如果是用稳态算例,可以先迎风算出来流场之后,再加阶数,SIMPLEFoam很稳健,一般不会出现问题。我觉得还是设置的问题。
    cfd-cxb
    明白了,谢谢前辈
