  3. 关于多相流的电势方程(Laplace方程)的求解问题
18 帖子 4 发布者 13.1k 浏览
    cfd_lilili
    @东岳
    谢谢东岳老师!
    我简单修改了一下代码,让它迭代多次
        scalar phiEEqRes = cttProperties.lookupOrDefault<scalar>("phiEEqRes", 1e-6 ) ;
        // Max number of iterations
        int maxIterPhiE = cttProperties.lookupOrDefault<int>("maxIterPhiE", 20 ) ;
       // Transport of passive scalar
        sigmaE == alpha1*sigmaE1 + alpha2*sigmaE2;
        scalar res=GREAT;
        int    iter=0;
        while (res > phiEEqRes && iter < maxIterPhiE)
            fvScalarMatrix phiEEqn
                fvm::laplacian( sigmaE, phiE)
            phiEEqn.relax();
            res = phiEEqn.solve().initialResidual();
            iter++;
    同样的算例下,log文件如下
    |  \\    /   O peration     | Version:  4.x                                   |
    Build  : 4.x
    Exec   : rheoEHDPhaseFieldFoam
    Date   : Oct 28 2019
    Time   : 11:01:00
    Host   : "cfd"
    PID    : 103447
    Case   : /home/cfd/OpenFOAM/cfd-4.x/run/rheoEHDPhaseFieldFoam/electric_test2
    nProcs : 1
    Create time
    Create mesh for time = 0
    PIMPLE: Operating solver in PISO mode
    Reading field p_rgh
    Reading field U
    Reading transportProperties
    Selecting constitutive equation Newtonian
    Reading g
    Reading hRef
    Calculating field g.h
    No MRF models present
    DICPCG:  Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
    time step continuity errors : sum local = 0, global = 0, cumulative = 0
    Courant Number mean: 0 max: 0
    Starting time loop
    Interface Courant Number mean: 0 max: 0
    Time = 0.001
    Phase-1 volume fraction = 0.0248178  Min(alpha.water) = -2.12354e-55  Max(alpha.water) - 1 = 0
    smoothSolver:  Solving for phiE, Initial residual = 2.00047e-06, Final residual = 9.0829e-09, No Iterations 2
    smoothSolver:  Solving for phiE, Initial residual = 2.00062e-06, Final residual = 9.08496e-09, No Iterations 2
    smoothSolver:  Solving for phiE, Initial residual = 2.00079e-06, Final residual = 9.08756e-09, No Iterations 2
    smoothSolver:  Solving for phiE, Initial residual = 2.00098e-06, Final residual = 9.09235e-09, No Iterations 2
    smoothSolver:  Solving for phiE, Initial residual = 2.00131e-06, Final residual = 9.10815e-09, No Iterations 2
    smoothSolver:  Solving for phiE, Initial residual = 2.0024e-06, Final residual = 9.20389e-09, No Iterations 2
    smoothSolver:  Solving for phiE, Initial residual = 2.00751e-06, Final residual = 1.05039e-08, No Iterations 2
    smoothSolver:  Solving for phiE, Initial residual = 2.06764e-06, Final residual = 2.18651e-08, No Iterations 2
    smoothSolver:  Solving for phiE, Initial residual = 2.72883e-06, Final residual = 8.38954e-08, No Iterations 2
    smoothSolver:  Solving for phiE, Initial residual = 7.30545e-06, Final residual = 2.6689e-08, No Iterations 4
    smoothSolver:  Solving for phiE, Initial residual = 3.10926e-05, Final residual = 3.82843e-08, No Iterations 5
    smoothSolver:  Solving for phiE, Initial residual = 0.000149551, Final residual = 5.68219e-08, No Iterations 6
    smoothSolver:  Solving for phiE, Initial residual = 0.000753353, Final residual = 8.61768e-08, No Iterations 7
    smoothSolver:  Solving for phiE, Initial residual = 0.00389063, Final residual = 3.72685e-08, No Iterations 9
    smoothSolver:  Solving for phiE, Initial residual = 0.0201471, Final residual = 5.71e-08, No Iterations 10
    smoothSolver:  Solving for phiE, Initial residual = 0.0968377, Final residual = 8.0832e-08, No Iterations 11
    smoothSolver:  Solving for phiE, Initial residual = 0.330082, Final residual = 8.08282e-08, No Iterations 12
    smoothSolver:  Solving for phiE, Initial residual = 0.583957, Final residual = 4.1842e-08, No Iterations 13
    smoothSolver:  Solving for phiE, Initial residual = 0.671177, Final residual = 4.92793e-08, No Iterations 13
    smoothSolver:  Solving for phiE, Initial residual = 0.687466, Final residual = 5.15537e-08, No Iterations 13
    DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 8.88689e-11, No Iterations 49
    DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 8.54483e-11, No Iterations 47
    DILUPBiCG:  Solving for Uz, Initial residual = 1, Final residual = 9.77718e-11, No Iterations 46
    DICPCG:  Solving for p_rgh, Initial residual = 1, Final residual = 9.26224e-11, No Iterations 481
    time step continuity errors : sum local = 5.4911e-05, global = -9.71439e-09, cumulative = -9.71439e-09
    ExecutionTime = 9.1 s  ClockTime = 9 s
    Courant Number mean: 1.63727e+07 max: 5.36038e+08
    Interface Courant Number mean: 1.56047e+06 max: 5.36038e+08
    Time = 0.002
    #3  Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
    #4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator*<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
    #5  Foam::interfaceEHDPropertiesPFM::calculateMobility() at ??:?
    #6  ? at ??:?
    #7  ? at ??:?
    #8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    #9  ? at ??:?
    可以看到,Initial residual在几个迭代步后迅速增大,这应该是计算发散的表征。这个算例里,我的不同相的sigmaE的比值是5,Laplace方程求解的格式是常用的Gauss linear corrected。所以,我猜想这应该和我引入的电场力无关,而主要是laplace方程的求解分散问题。
    @cfd_lilili 在 关于多相流的电势方程(Laplace方程)的求解问题 中说:
    这个方程不需要迭代多次
    yfclark 神
    这个应该是类似虚假流动的现象,初始化的时候给个电场和压力梯度表面张力平衡的的初始场试一下会不会好一点
    cfd_lilili
    @东岳 和@yfclark 感谢两位的建议
    对这个问题,我实在无从下手,于是刚刚尝试了一下换个版本的求解器试试看。于是,我将同样的代码片段植入到of4.0和fe4.0的interFoam求解器中,并做了同样的算例。结果发现同样的条件下的Laplace方程,of4.0解不了,fe4.0可以解。这让我很迷惑。
    这个是of4.0求解器的算例的log文件,可以看到它的 Initial residual并没有收敛的迹象。
    Build  : 4.x
    Exec   : interFoamtest
    Date   : Oct 28 2019
    Time   : 16:51:11
    Host   : "cfd"
    PID    : 116917
    Case   : /home/cfd/OpenFOAM/cfd-4.x/run/interFoamtest/damBreak
    nProcs : 1
    Create time
    Reading field p_rgh
    Reading field U
    Reading g
    Reading hRef
    Starting time loop
    Time = 0.001
    PIMPLE: iteration 1
    smoothSolver:  Solving for alpha.water, Initial residual = 0, Final residual = 0, No Iterations 0
    Phase-1 volume fraction = 0.0247173  Min(alpha.water) = 0  Max(alpha.water) = 1
    MULES: Correcting alpha.water
    smoothSolver:  Solving for phiE, Initial residual = 1, Final residual = 0.00666667, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.969654, Final residual = 0.955898, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.999906, Final residual = 0.999906, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.999943, Final residual = 0.999943, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.999959, Final residual = 0.999959, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.99997, Final residual = 0.99997, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.999977, Final residual = 0.999977, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.999982, Final residual = 0.999982, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.999986, Final residual = 0.999986, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.999989, Final residual = 0.999989, No Iterations 1000
    DICPCG:  Solving for p_rgh, Initial residual = 1, Final residual = 0.0288118, No Iterations 2
    time step continuity errors : sum local = 3.79873e-07, global = -1.14217e-22, cumulative = -1.14217e-22
    DICPCG:  Solving for p_rgh, Initial residual = 0.014257, Final residual = 0.000679011, No Iterations 51
    time step continuity errors : sum local = 1.80931e-08, global = 1.97801e-23, cumulative = -9.44368e-23
    DICPCG:  Solving for p_rgh, Initial residual = 0.000685827, Final residual = 9.85239e-08, No Iterations 330
    time step continuity errors : sum local = 2.59978e-12, global = -2.24454e-24, cumulative = -9.66814e-23
    ExecutionTime = 29.16 s  ClockTime = 29 s
    Courant Number mean: 8.45892e-06 max: 0.00486238
    Time = 0.002
    PIMPLE: iteration 1
    smoothSolver:  Solving for alpha.water, Initial residual = 1.03138e-05, Final residual = 1.278e-11, No Iterations 1
    Phase-1 volume fraction = 0.0247173  Min(alpha.water) = -1.02138e-12  Max(alpha.water) = 1
    smoothSolver:  Solving for phiE, Initial residual = 0.999991, Final residual = 0.999991, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.999993, Final residual = 0.999993, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.999994, Final residual = 0.999994, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.999995, Final residual = 0.999995, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.999996, Final residual = 0.999996, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.999997, Final residual = 0.999997, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.999998, Final residual = 0.999998, No Iterations 1000
    DICPCG:  Solving for p_rgh, Initial residual = 0.148216, Final residual = 0.00717185, No Iterations 8
    time step continuity errors : sum local = 1.53736e-07, global = 1.00047e-22, cumulative = 3.36563e-24
    DICPCG:  Solving for p_rgh, Initial residual = 0.00694699, Final residual = 0.00032885, No Iterations 69
    time step continuity errors : sum local = 7.31529e-09, global = -5.63383e-24, cumulative = -2.2682e-24
    DICPCG:  Solving for p_rgh, Initial residual = 0.000331229, Final residual = 9.04502e-08, No Iterations 320
    time step continuity errors : sum local = 2.00174e-12, global = -1.03358e-23, cumulative = -1.2604e-23
    ExecutionTime = 55.26 s  ClockTime = 55 s
    Courant Number mean: 1.00744e-05 max: 0.00608536
    Time = 0.003
    PIMPLE: iteration 1
    smoothSolver:  Solving for alpha.water, Initial residual = 1.17667e-05, Final residual = 1.48862e-11, No Iterations 1
    Phase-1 volume fraction = 0.0247173  Min(alpha.water) = -7.81203e-23  Max(alpha.water) = 1
    Phase-1 volume fraction = 0.0247173  Min(alpha.water) = -2.49888e-15  Max(alpha.water) = 1
    smoothSolver:  Solving for phiE, Initial residual = 0.999999, Final residual = 0.999999, No Iterations 1000
    DICPCG:  Solving for p_rgh, Initial residual = 0.0570031, Final residual = 0.00216312, No Iterations 3
    time step continuity errors : sum local = 4.53781e-08, global = -1.07358e-25, cumulative = -1.27114e-23
    DICPCG:  Solving for p_rgh, Initial residual = 0.00216994, Final residual = 0.000103227, No Iterations 32
    time step continuity errors : sum local = 2.19448e-09, global = 2.56894e-23, cumulative = 1.29781e-23
    DICPCG:  Solving for p_rgh, Initial residual = 0.000103679, Final residual = 9.68435e-08, No Iterations 180
    time step continuity errors : sum local = 2.06555e-12, global = 2.39499e-23, cumulative = 3.6928e-23
    ExecutionTime = 80.51 s  ClockTime = 80 s
    Courant Number mean: 1.02305e-05 max: 0.0059902
    Time = 0.004
    PIMPLE: iteration 1
    smoothSolver:  Solving for alpha.water, Initial residual = 1.14624e-05, Final residual = 1.20817e-11, No Iterations 1
    Phase-1 volume fraction = 0.0247173  Min(alpha.water) = -2.32959e-16  Max(alpha.water) = 1
    Phase-1 volume fraction = 0.0247173  Min(alpha.water) = -6.27415e-12  Max(alpha.water) = 1
    DICPCG:  Solving for p_rgh, Initial residual = 0.025679, Final residual = 0.00121229, No Iterations 2
    time step continuity errors : sum local = 2.4847e-08, global = 4.56559e-24, cumulative = 4.14936e-23
    DICPCG:  Solving for p_rgh, Initial residual = 0.00123628, Final residual = 5.7827e-05, No Iterations 29
    time step continuity errors : sum local = 1.18735e-09, global = -1.92179e-25, cumulative = 4.13014e-23
    DICPCG:  Solving for p_rgh, Initial residual = 5.83662e-05, Final residual = 9.44483e-08, No Iterations 129
    time step continuity errors : sum local = 1.94768e-12, global = -2.79384e-23, cumulative = 1.3363e-23
    ExecutionTime = 105.48 s  ClockTime = 105 s
    Courant Number mean: 1.02721e-05 max: 0.00571222
    Time = 0.005
    PIMPLE: iteration 1
    smoothSolver:  Solving for alpha.water, Initial residual = 1.10272e-05, Final residual = 9.91906e-12, No Iterations 1
    Phase-1 volume fraction = 0.0247173  Min(alpha.water) = -1.84397e-16  Max(alpha.water) = 1
    Phase-1 volume fraction = 0.0247173  Min(alpha.water) = -5.64491e-12  Max(alpha.water) = 1
    DICPCG:  Solving for p_rgh, Initial residual = 0.0170557, Final residual = 0.000707649, No Iterations 2
    time step continuity errors : sum local = 1.40556e-08, global = 5.55595e-24, cumulative = 1.8919e-23
    DICPCG:  Solving for p_rgh, Initial residual = 0.00072258, Final residual = 3.40642e-05, No Iterations 66
    time step continuity errors : sum local = 6.7235e-10, global = -1.97122e-24, cumulative = 1.69477e-23
    DICPCG:  Solving for p_rgh, Initial residual = 3.47482e-05, Final residual = 9.44334e-08, No Iterations 110
    time step continuity errors : sum local = 1.97407e-12, global = 2.71579e-25, cumulative = 1.72193e-23
    ExecutionTime = 132.15 s  ClockTime = 132 s
    Courant Number mean: 1.03787e-05 max: 0.00551763
    这里是fe4.0的求解器的算例的log文件,它的Initial residual则呈现了收敛的趋势
    | \\      /  F ield         | foam-extend: Open Source CFD                    |
    |  \\    /   O peration     | Version:     4.0                                |
    |   \\  /    A nd           | Web:         http://www.foam-extend.org         |
    |    \\/     M anipulation  | For copyright notice see file Copyright         |
    Build    : 4.0
    Date     : Oct 28 2019
    Time     : 16:44:23
    Host     : cfd
    PID      : 116498
    CtrlDict : "/home/cfd/foam/cfd-4.0/run/damBreak/system/controlDict"
    Case     : /home/cfd/foam/cfd-4.0/run/damBreak
    nProcs   : 1
    SigFpe   : Enabling floating point exception trapping (FOAM_SIGFPE).
    Create time
    Reading g
    Reading field pd
    Reading field alpha1
    Reading field U
    Courant Number mean: 0 max: 0 velocity magnitude: 0
    Starting time loop
    Time = 0.001
    PIMPLE: iteration 1
    MULES: Solving for alpha1
    Liquid phase volume fraction = 0.0247173  Min(alpha1) = 0  Max(alpha1) = 1
    BiCGStab:  Solving for Ux, Initial residual = 1, Final residual = 8.84344e-16, No Iterations 1
    BiCGStab:  Solving for Uy, Initial residual = 1, Final residual = 2.39687e-15, No Iterations 1
    BiCGStab:  Solving for Uz, Initial residual = 0.999809, Final residual = 1.01154e-15, No Iterations 1
    smoothSolver:  Solving for phiE, Initial residual = 1, Final residual = 0.00885022, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.00440562, Final residual = 0.00275942, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.00276397, Final residual = 0.00177986, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.00178161, Final residual = 0.00114823, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.00114896, Final residual = 0.000740514, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.000740817, Final residual = 0.000477462, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.000477588, Final residual = 0.000307809, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.000307862, Final residual = 0.000198419, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.000198441, Final residual = 0.000127897, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 0.000127906, Final residual = 8.24364e-05, No Iterations 1000
    DICPCG:  Solving for pd, Initial residual = 1, Final residual = 0.0228419, No Iterations 2
    DICPCG:  Solving for pd, Initial residual = 0.0113008, Final residual = 0.000494115, No Iterations 19
    DICPCG:  Solving for pd, Initial residual = 0.00049866, Final residual = 2.39276e-05, No Iterations 115
    DICPCG:  Solving for pd, Initial residual = 2.39472e-05, Final residual = 9.68596e-08, No Iterations 302
    time step continuity errors : sum local = 9.29479e-09, global = 1.57022e-22, cumulative = 1.57022e-22
    ExecutionTime = 30.3 s  ClockTime = 30 s
    Courant Number mean: 0.000308178 max: 0.120588 velocity magnitude: 1.20588
    Time = 0.002
    PIMPLE: iteration 1
    BiCGStab:  Solving for Ux, Initial residual = 0.776521, Final residual = 8.28489e-11, No Iterations 2
    BiCGStab:  Solving for Uy, Initial residual = 0.488694, Final residual = 2.35091e-11, No Iterations 2
    BiCGStab:  Solving for Uz, Initial residual = 0.492107, Final residual = 6.27383e-10, No Iterations 2
    smoothSolver:  Solving for phiE, Initial residual = 8.24401e-05, Final residual = 5.31333e-05, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 5.31349e-05, Final residual = 3.42459e-05, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 3.42465e-05, Final residual = 2.20722e-05, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 2.20724e-05, Final residual = 1.42259e-05, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 1.4226e-05, Final residual = 9.16875e-06, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 9.1688e-06, Final residual = 5.90937e-06, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 5.90939e-06, Final residual = 3.80865e-06, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 3.80866e-06, Final residual = 2.45471e-06, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 2.45471e-06, Final residual = 1.58208e-06, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 1.58208e-06, Final residual = 1.01967e-06, No Iterations 1000
    DICPCG:  Solving for pd, Initial residual = 0.146545, Final residual = 0.00361308, No Iterations 2
    DICPCG:  Solving for pd, Initial residual = 0.00335961, Final residual = 0.000167276, No Iterations 105
    DICPCG:  Solving for pd, Initial residual = 0.000188382, Final residual = 9.23987e-06, No Iterations 49
    DICPCG:  Solving for pd, Initial residual = 9.8482e-06, Final residual = 9.46082e-08, No Iterations 286
    time step continuity errors : sum local = 2.47934e-09, global = -3.54267e-22, cumulative = -1.97245e-22
    ExecutionTime = 58.46 s  ClockTime = 58 s
    Courant Number mean: 0.000218338 max: 0.0405799 velocity magnitude: 0.405799
    Time = 0.003
    PIMPLE: iteration 1
    BiCGStab:  Solving for Ux, Initial residual = 0.431649, Final residual = 2.74542e-08, No Iterations 1
    BiCGStab:  Solving for Uy, Initial residual = 0.223545, Final residual = 5.07216e-10, No Iterations 1
    BiCGStab:  Solving for Uz, Initial residual = 0.212763, Final residual = 1.13065e-09, No Iterations 1
    smoothSolver:  Solving for phiE, Initial residual = 1.01967e-06, Final residual = 6.57184e-07, No Iterations 1000
    smoothSolver:  Solving for phiE, Initial residual = 6.57184e-07, Final residual = 4.23565e-07, No Iterations 1000
    DICPCG:  Solving for pd, Initial residual = 0.027659, Final residual = 0.000699273, No Iterations 2
    DICPCG:  Solving for pd, Initial residual = 0.00069462, Final residual = 3.42751e-05, No Iterations 109
    DICPCG:  Solving for pd, Initial residual = 3.70155e-05, Final residual = 1.75277e-06, No Iterations 49
    DICPCG:  Solving for pd, Initial residual = 1.78108e-06, Final residual = 9.77867e-08, No Iterations 266
    time step continuity errors : sum local = 2.18185e-09, global = 1.21446e-22, cumulative = -7.57986e-23
    ExecutionTime = 65.25 s  ClockTime = 65 s
    Courant Number mean: 0.000237433 max: 0.0260814 velocity magnitude: 0.260814
    Time = 0.004
    PIMPLE: iteration 1
    Liquid phase volume fraction = 0.0247173  Min(alpha1) = -5.52899e-28  Max(alpha1) = 1
    BiCGStab:  Solving for Ux, Initial residual = 0.212063, Final residual = 1.20667e-11, No Iterations 1
    BiCGStab:  Solving for Uy, Initial residual = 0.157791, Final residual = 5.26792e-13, No Iterations 1
    BiCGStab:  Solving for Uz, Initial residual = 0.144847, Final residual = 8.02311e-13, No Iterations 1
    smoothSolver:  Solving for phiE, Initial residual = 4.23565e-07, Final residual = 2.73004e-07, No Iterations 1000
    DICPCG:  Solving for pd, Initial residual = 0.00638702, Final residual = 0.000228527, No Iterations 2
    DICPCG:  Solving for pd, Initial residual = 0.000229721, Final residual = 1.09143e-05, No Iterations 115
    DICPCG:  Solving for pd, Initial residual = 1.142e-05, Final residual = 4.41946e-07, No Iterations 58
    DICPCG:  Solving for pd, Initial residual = 4.43246e-07, Final residual = 9.98953e-08, No Iterations 236
    time step continuity errors : sum local = 1.92551e-09, global = -2.38779e-22, cumulative = -3.14578e-22
    ExecutionTime = 69.77 s  ClockTime = 69 s
    Courant Number mean: 0.000307195 max: 0.0317014 velocity magnitude: 0.317014
    Time = 0.005
    PIMPLE: iteration 1
    BiCGStab:  Solving for Ux, Initial residual = 0.141162, Final residual = 1.73043e-11, No Iterations 1
    BiCGStab:  Solving for Uy, Initial residual = 0.123101, Final residual = 6.00829e-13, No Iterations 1
    BiCGStab:  Solving for Uz, Initial residual = 0.11123, Final residual = 9.9712e-13, No Iterations 1
    smoothSolver:  Solving for phiE, Initial residual = 2.73004e-07, Final residual = 1.75965e-07, No Iterations 1000
    DICPCG:  Solving for pd, Initial residual = 0.0068371, Final residual = 0.000235051, No Iterations 2
    DICPCG:  Solving for pd, Initial residual = 0.000232659, Final residual = 1.10913e-05, No Iterations 27
    DICPCG:  Solving for pd, Initial residual = 1.12968e-05, Final residual = 5.32458e-07, No Iterations 125
    DICPCG:  Solving for pd, Initial residual = 5.36239e-07, Final residual = 9.64374e-08, No Iterations 42
    time step continuity errors : sum local = 1.68223e-09, global = 4.27902e-22, cumulative = 1.13324e-22
    ExecutionTime = 74.91 s  ClockTime = 75 s
    Courant Number mean: 0.000376038 max: 0.0360665 velocity magnitude: 0.360665
    姑且假设我写的求解器没有大问题的条件下,上述结果说明,两个版本的求解结果存在了不同。
    所以,我在想是不是of40和fe40的Laplace求解器在什么地方存在差异,导致了这样的结果?
    fe4.0
    这是啥。。。
    cfd_lilili
    @东岳 openFoam-extend4.0,不好意思,我以为这个是通用的简写
    你在求解一个方程求解多次。另外,迭代次数1000,没有收敛,
    这是一个非常简单的方程,你需要更细心的debug
    cfd_lilili
    @东岳 谢谢老师
    我把代码换了写法,问题就解决了
    这是原来的写法
                fvm::laplacian(  phiE )
            phiEEqn.relax();
            solve(phiEEqn);
    把它简单地写为
        solve( fvm::laplacian(sigmaE, phiE) );
    问题勉强算解决了,但还不知道之前的问题出在哪。
    后来这个解决了吗 :-)
  • G 离线
    G 离线
    gzs20
    老师,请教一下,不同相的交界面电势的边界条件采用的那种了
    但其电导系数(sigma)在不同的相中具有不同的值。
    我去年在笔记的附录中整理了这部分内容。这部分采取多计算域的方法处理比较好。
  • G 离线
    G 离线
    gzs20
    @李东岳 东岳老师,您好,请问您说的笔记的附录在哪里可以找到,告知一下,目前卡在了电势的求解这一步
    http://dyfluid.com/index.html 主页有下载
    G 1 条回复 最后回复
  • G 离线
    G 离线
    gzs20
    @李东岳 谢谢东岳老师
