  3. 安装openfoam
安装openfoam
22 帖子 3 发布者 10.9k 浏览
    你之前用过4.1,那就自己装吧,编译4.1要编译器降级,https://www.cfd-china.com/topic/4196/ubuntu-20-04-安装-openfoam-v1712
    亦 1 条回复 最后回复
  • 亦 离线
    亦 离线
    亦又
    @李东岳 我用到了gcc5了,别的那些包有什么需要改动或者那个些源网站要怎么调整,./Allwmake -j 总是出问题?
    我不太确定,但我记得应该是5以下的4.8,你试试4.8
    别的不需要调整
    亦 1 条回复 最后回复
  • 亦 离线
    亦 离线
    亦又
    insertSurfaceNearestPointPairs.C: In member function ‘void Foam::CV2D::insertSurfaceNearestPointPairs()’:
    insertSurfaceNearestPointPairs.C:178:31: error: ‘toPoint3D’ was not declared in this scope
    toPoint3D(vert),
    insertSurfaceNearestPointPairs.C:225:67: error: no matching function for call to ‘Foam::CV2D::toPoint2D(const Foam::Vector<double>&)’
    surfacePoints.append(toPoint2D(pHit.hitPoint()));
    insertSurfaceNearestPointPairs.C:225:67: note: candidates are:
    In file included from CV2D.H:469:0,
    from insertSurfaceNearestPointPairs.C:26:
    CV2DI.H:what:29: note: const point2D& Foam::CV2D::toPoint2D(const int&) const
    inline const Foam::point2D& Foam::CV2D::toPoint2D(const point& p) const
    CV2DI.H:what:29: note: no known conversion for argument 1 from ‘const Foam::Vector<double>’ to ‘const int&’
    CV2DI.H:chigua2:33: note: const point2DField Foam::CV2D::toPoint2D(const pointField&) const
    inline const Foam::point2DField Foam::CV2D::toPoint2D(const pointField& p) const
    CV2DI.H:chigua2:33: note: no known conversion for argument 1 from ‘const Foam::Vector<double>’ to ‘const pointField& {aka const Foam::Field<Foam::Vector<double> >&}’
    CV2DI.H:149:37: note: const point2D& Foam::CV2D::toPoint2D(const Point&) const
    inline Foam::CV2D::point2DFromPoint Foam::CV2D::toPoint2D(const Point& P) const
    CV2DI.H:149:37: note: no known conversion for argument 1 from ‘const Foam::Vector<double>’ to ‘const Point& {aka const CGAL::Point_2CGAL::Epick&}’
    from insertBoundaryConformPointPairs.C:26:
    CV2DI.H: In member function ‘bool Foam::CV2D::insertMirrorPoint(const point2D&, const point2D&)’:
    CV2DI.H:94:1: warning: control reaches end of non-void function [-Wreturn-type]
    make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/foamyQuadMesh/insertBoundaryConformPointPairs.o] 错误 1
    make[2]: *** 正在等待未完成的任务....
    make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/foamyQuadMesh/CV2D.o] 错误 1
    make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/foamyQuadMesh/foamyQuadMesh.o] 错误 1
    make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/foamyQuadMesh/insertSurfaceNearPointPairs.o] 错误 1
    make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/foamyQuadMesh/CV2DIO.o] 错误 1
    make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/foamyQuadMesh/insertFeaturePoints.o] 错误 1
    make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/foamyQuadMesh/insertSurfaceNearestPointPairs.o] 错误 1
    make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/foamyQuadMesh/shortEdgeFilter2D.o] 错误 1
    make[1]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/makefiles/apps:39:generation] 错误 2
    make: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/makefiles/apps:39:mesh] 错误 2
    老师,这是什么问题?
    不需要编译foamyQuadMesh,忽略
    亦 1 条回复 最后回复
  • 亦 离线
    亦 离线
    亦又
    @李东岳 老师,可是它自动停止了,到这里
    foamyQuadMesh是之前测试性的代码,后来给删了。你编译时候强制略过好了。或者自动停止之后,手动继续编译别的
    亦 4 条回复 最后回复
  • 亦 离线
    亦 离线
    亦又
    @李东岳 老师,如何强制跳过啊?如果手动编译别的,怎么查看还需要编译那些?
  • 亦 离线
    亦 离线
    亦又
    @李东岳 -ldynamicMesh -lgenericPatchFields -lOpenFOAM -ldl
    -lm -o /home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/bin/subsetMesh
    这是啥问题?
    亦 1 条回复 最后回复
  • 亦 离线
    亦 离线
    亦又
    在 中回复了 亦又 最后由 编辑
    @亦又 在 安装openfoam 中说:
    这是啥问题?
    .PHONY: application
    application: $(FOAM_APPS)
    .PHONY: $(FOAM_APPS)
    $(FOAM_APPS):
    +@wmake -all $(TARGET) $@ 这是34行到39行
    亦 1 条回复 最后回复
  • 亦 离线
    亦 离线
    亦又
    在 中回复了 亦又 最后由 编辑
    这是啥问题?
    .PHONY: application
    $(FOAM_APPS):
    dyz@dyz-VMware-Virtual-Platform:~/OpenFOAM/OpenFOAM-4.1$ cd ~/OpenFOAM/OpenFOAM-4.1/applications/utilities/mesh/manipulation/subsetMesh
    dyz@dyz-VMware-Virtual-Platform:~/OpenFOAM/OpenFOAM-4.1/applications/utilities/mesh/manipulation/subsetMesh$ wmake
    /home/dyz/OpenFOAM/OpenFOAM-4.1/applications/utilities/mesh/manipulation/subsetMesh
    make: “/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/bin/subsetMesh”已是最新。
    咋回事
  • 亦 离线
    亦 离线
    亦又
    在 中回复了 李东岳 最后由 亦又 编辑
    @李东岳 加上之前的,老师您再看看这些
    compilation terminated.
    make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/backgroundMeshDecomposition/backgroundMeshDecomposition.o] 错误 1
    In file included from lnInclude/CGALTriangulation3Ddefs.H:41:0,
    from lnInclude/conformalVoronoiMesh.H:46,
    from lnInclude/cellSizeFunction.H:39,
    from cellShapeControl/cellSizeAndAlignmentControl/searchableSurfaceControl/searchableSurfaceControl.H:37,
    from cellShapeControl/cellSizeAndAlignmentControl/searchableSurfaceControl/searchableSurfaceControl.C:26:
    lnInclude/CGALTriangulation3DKernel.H:48:60: fatal error: CGAL/Robust_circumcenter_filtered_traits_3.h: 没有那个文件或目录
    #include "CGAL/Robust_circumcenter_filtered_traits_3.h"
    make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/conformalVoronoiMesh/conformalVoronoiMeshConformToSurface.o] 错误 1
    make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/cellShapeControl/cellShapeControl/cellShapeControl.o] 错误 1
    make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/conformalVoronoiMesh/conformalVoronoiMesh.o] 错误 1
    make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/cellShapeControl/cellShapeControlMesh/cellShapeControlMesh.o] 错误 1
    make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/DelaunayMeshTools/DelaunayMeshTools.o] 错误 1
    make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/conformalVoronoiMesh/conformalVoronoiMeshFeaturePoints.o] 错误 1
    make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/cellShapeControl/cellSizeAndAlignmentControl/cellSizeAndAlignmentControls.o] 错误 1
    make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/conformalVoronoiMesh/conformalVoronoiMeshIO.o] 错误 1
    make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/conformationSurfaces/conformationSurfaces.o] 错误 1
    make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/cvControls/cvControls.o] 错误 1
    make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/cellShapeControl/cellSizeAndAlignmentControl/searchableSurfaceControl/searchableSurfaceControl.o] 错误 1
    这个foamyMesh里面好像又出现一些问题。
  • 亦 离线
    亦 离线
    亦又
    @李东岳 老师,openfoam4.1 是不是不用编译这个foamyMesh,是不是可以整个跳过
    是的,可以直接跳过
