  3. 动网格和overset物体速度快速震荡导致崩溃的问题
18 帖子 10 发布者 14.5k 浏览
  • towerT 离线
    towerT 离线
    tower
    各位,
    我尝试增大PIMPLE里面循环次数来增加p_rgh的迭代次数,但是发现每次迭代的次数还是很多 不是一个递减的趋势
    如下:
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 8.72710724614e-07, Final residual = 8.72514217379e-09, No Iterations 382
    time step continuity errors : sum local = 7.03336340027e-09, global = 1.9150124018e-09, cumulative = 3.04929773866e-07
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 3.69104939702e-07, Final residual = 1.44876414351e-09, No Iterations 335
    time step continuity errors : sum local = 1.11124908301e-09, global = 1.95050292461e-10, cumulative = 3.05124824159e-07
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 2.2782727071e-07, Final residual = 1.06023228234e-09, No Iterations 607
    time step continuity errors : sum local = 7.68585702259e-10, global = -3.36686161497e-10, cumulative = 3.04788137997e-07
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.47947887396e-07, Final residual = 9.72671115058e-10, No Iterations 464
    time step continuity errors : sum local = 6.73366904995e-10, global = 7.62059709157e-11, cumulative = 3.04864343968e-07
    smoothSolver:  Solving for epsilon, Initial residual = 0.000146170038677, Final residual = 5.6866402182e-09, No Iterations 8
    smoothSolver:  Solving for k, Initial residual = 0.00238502525139, Final residual = 9.25193944196e-09, No Iterations 20
    ExecutionTime = 689.06 s  ClockTime = 695 s
    尝试修改为层流之后,连续迭代,次数基本成一个下降趋势,但是受力情况还是不变,错误依旧
    如下:
    Updating StokesII wave model for patch inlet
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.33810842593e-07, Final residual = 1.05803239609e-09, No Iterations 95
    time step continuity errors : sum local = 2.20723157353e-08, global = 6.73895228141e-09, cumulative = 7.30414848751e-06
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 8.58642796578e-09, Final residual = 9.05674029848e-10, No Iterations 23
    time step continuity errors : sum local = 1.87310827339e-08, global = 5.04129159013e-09, cumulative = 7.3091897791e-06
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.88155187954e-09, Final residual = 9.84985998753e-10, No Iterations 1
    time step continuity errors : sum local = 1.99973561049e-08, global = 4.66563789626e-09, cumulative = 7.313855417e-06
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.11812493747e-09, Final residual = 9.39334225107e-10, No Iterations 1
    time step continuity errors : sum local = 1.91664654171e-08, global = 4.75521938246e-09, cumulative = 7.31861063638e-06
    ExecutionTime = 8152.77 s  ClockTime = 8159 s
    我这没装wave2foam,所以.. :135: 看看其他大佬有什么意见
  • xiezhuoyuX 离线
    xiezhuoyuX 离线
    xiezhuoyu
    虽然我算例的浮体和你不一样,但是问题很类似:在波浪还没有传播到浮体附近之前,浮体就受力振荡,p_rgh的迭代次数不是递减的趋势,感觉我就是在踩你踩过的坑:135: @tower
    overset: oversetMesh.zip 这个算例用的是OF1906自带的造波消波模块吧,不需要waves2Foam造波消波,@东岳 老师能不能给我们一点建议o_0,看看应该从什么角度着手尝试解决这个问题?谢谢!
    也希望有其他前辈能够就这个问题指点一下,缩短小白踩坑的时间,感谢!!
    CFDngu
    我用overset计算过浮体大幅度运动的问题,没遇到你们说的问题。
    第一种可能是设置问题,可以仔细检查一下算例的设置,包括overset网格的设置;
    第二中可能就是waves2Foam与overset网格结合的问题。这个我也不确定,因为我之前算的时候采用了自己写的造波程序。
  • xiezhuoyuX 离线
    xiezhuoyuX 离线
    xiezhuoyu
    @CFDngu 谢谢建议!!
  • 卡 离线
    卡 离线
    卡洛
    老哥,请问最终问题怎么解决的,我最近也遇到这个问题了
  • O 离线
    O 离线
    OItoCFD
    老哥,我来歪个楼,问你一下,wave2foam作用是啥?原版OpenFOAM不就有各种波浪么,或者自己自建个波浪边界条件也行吧,为啥还要额外一个wave2foam呢?
    jlx
    在 中回复了 tower 最后由 编辑
    @tower 老哥,请问下问题解决了么:143:
    hachikoi
    老哥们,你们是如何解决这个问题
    我在使用两套overset做浮体自衰减的时候也遇到类似的问题
    wangwang
    你好,请问这个问题解决了吗?
    wzlr2023
    大家好,请问这个问题解决了吗?我用overinerDyMFoam算一个二维方块浮体也遇到了这个问题,更改了很多参数都没解决。。。
