66 帖子 15 发布者 102.3k 浏览
    1、李老师,我用OpenFOAM-8编译了这个程序,编译过程提示有一些未使用变量,但能正常编译。
    Making dependency list for source file Rotex.C
    g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I/home/install/OpenFOAM/OpenFOAM-8/src/finiteVolume/lnInclude -I/home/install/OpenFOAM/OpenFOAM-8/src/meshTools/lnInclude -IlnInclude -I. -I/home/install/OpenFOAM/OpenFOAM-8/src/OpenFOAM/lnInclude -I/home/install/OpenFOAM/OpenFOAM-8/src/OSspecific/POSIX/lnInclude   -fPIC -c Rotex.C -o Make/linux64GccDPInt32Opt/Rotex.o
    Rotex.C: In function \u2018int main(int, char**)\u2019:
    Rotex.C:153:20: warning: unused variable \u2018eig1c_r\u2019 [-Wunused-variable]
      153 |             scalar eig1c_r=-0.5*(aaaa+bbbb)-aa/3.0;
    Rotex.C:154:20: warning: unused variable \u2018eig1c_i\u2019 [-Wunused-variable]
      154 |             scalar eig1c_i=0.5*Foam::sqrt(scalar(3.0))*(aaaa-bbbb);
    Rotex.C:155:20: warning: unused variable \u2018eig2c_r\u2019 [-Wunused-variable]
      155 |             scalar eig2c_r=-0.5*(aaaa+bbbb)-aa/3.0;
    Rotex.C:156:20: warning: unused variable \u2018eig2c_i\u2019 [-Wunused-variable]
      156 |             scalar eig2c_i=-0.5*Foam::sqrt(scalar(3.0))*(aaaa-bbbb);
    g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I/home/install/OpenFOAM/OpenFOAM-8/src/finiteVolume/lnInclude -I/home/install/OpenFOAM/OpenFOAM-8/src/meshTools/lnInclude -IlnInclude -I. -I/home/install/OpenFOAM/OpenFOAM-8/src/OpenFOAM/lnInclude -I/home/install/OpenFOAM/OpenFOAM-8/src/OSspecific/POSIX/lnInclude   -fPIC -fuse-ld=bfd -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/Rotex.o -L/home/install/OpenFOAM/OpenFOAM-8/platforms/linux64GccDPInt32Opt/lib \
        -lfiniteVolume -lfvOptions -lmeshTools -lOpenFOAM -ldl  \
         -lm -o /home/user1/OpenFOAM/user1-8/platforms/linux64GccDPInt32Opt/bin/Rotex
    2、提供4个加载CDRFG脉动风的空风洞算例结果下载链接:
    (1)3个算例用snappyHexMesh画的六面体网格,数量分别为9.6w,150w,364w。
    (2)1个算例用fluentmeshing画的poly网格,网格数量为141w
    (3)RotexCase下载链接:
    链接:https://pan.baidu.com/s/1HQZkWVg2-ZKUF8SmqwkwOg
    提取码:fgzl
    3、测试结果
    (1)9.6w SHM网格算例,Rotex用单核、并行都能正常计算,单核40 s,并行20核计算用0.36 s。但用paraview看后处理结果,虽然可以看到Rotex数据,但由于Rotex输出的结果为矢量,画contour图的时候,选项找不到Rotex,但能选择Lambda2和Q画等值面图。
    问题是采用Liutex如何画出三维形状的涡?
    这是选择Rotex画出来的纵向截面图:
    这是选择Q准则画出的涡形状:
    (2)150w SHM网格算例。Rotex并行20核计算用时127 s。
    (3)364w SHM网格算例。Rotex并行20核计算用时1855 s。可以看出运行Rotex随着网格增加,运行时间是非线性增加的。
    (4)141w poly网格算例。Rotex并行20核计算,报错Floating point exception,但运行Lambda2和Q画等值面图,能正常运行。
    Time = 9
        Reading U
    [4] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
    [4] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [4] #2  ? in "/lib64/libc.so.6"
    [4] #3  ? at ??:?
    [4] #4  __libc_start_main in "/lib64/libc.so.6"
    [4] #5  ? at ??:?
    [hpws14:21072] *** Process received signal ***
    [hpws14:21072] Signal: Floating point exception (8)
    [hpws14:21072] Signal code:  (-6)
    [hpws14:21072] Failing at address: 0x3e800005250
    [hpws14:21072] [ 0] /lib64/libc.so.6(+0x36400)[0x7fab592fb400]
    [hpws14:21072] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x7fab592fb387]
    [hpws14:21072] [ 2] /lib64/libc.so.6(+0x36400)[0x7fab592fb400]
    [hpws14:21072] [ 3] Rotex[0x4136e0]
    [hpws14:21072] [ 4] /lib64/libc.so.6(__libc_start_main+0xf5)[0x7fab592e7555]
    [hpws14:21072] [ 5] Rotex[0x4146f0]
    [hpws14:21072] *** End of error message ***
    [9] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
    [9] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [9] #2  ? in "/lib64/libc.so.6"
    [9] #3  ? at ??:?
    [9] #4  __libc_start_main in "/lib64/libc.so.6"
    [9] #5  ? at ??:?
    [hpws14:21077] *** Process received signal ***
    [hpws14:21077] Signal: Floating point exception (8)
    [hpws14:21077] Signal code:  (-6)
    [hpws14:21077] Failing at address: 0x3e800005255
    [hpws14:21077] [ 0] /lib64/libc.so.6(+0x36400)[0x7f02ac8ea400]
    [hpws14:21077] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x7f02ac8ea387]
    [hpws14:21077] [ 2] /lib64/libc.so.6(+0x36400)[0x7f02ac8ea400]
    [hpws14:21077] [ 3] Rotex[0x4136e0]
    [hpws14:21077] [ 4] /lib64/libc.so.6(__libc_start_main+0xf5)[0x7f02ac8d6555]
    [hpws14:21077] [ 5] Rotex[0x4146f0]
    [hpws14:21077] *** End of error message ***
    Primary job  terminated normally, but 1 process returned
    a non-zero exit code. Per user-direction, the job has been aborted.
    [6] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
    [6] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [6] #2  ? in "/lib64/libc.so.6"
    [6] #3  ? at ??:?
    [6] #4  __libc_start_main--------------------------------------------------------------------------
    mpirun noticed that process rank 9 with PID 0 on node hpws14 exited on signal 8 (Floating point exception).
    这是poly网格选择Q准则画出的涡形状:
    @coolhhh 在 请教:第三代涡识别方法Liutex的代码在linux中运行的问题 中说:
    你用calculator做一个计算器,计算Liutex的mag,然后做等值面图可以么。
    这个可能要看一下liutex的sci的定义,看是不是通过这个方法来进行的。
    我下载你150万网格的看下Liutex哪一块最耗费时间。
    李老师,我看了刘老师的论文(刘超群, Liutex-涡定义和第三代涡识别方法. 空气动力学学报, 2020. 038(003): 第413-431,478页.),里边提到以下几点:
    1. Liutex算出的是一个矢量,而Q是标量。
    2.文章中提到Liutex为基础的几个涡识别方法,其中之一就是可以用计算mag来画等值面,但这个时候又需要指定阈值:
    3.用paraview计算9.6w 网格的算例的mag(Rotex),阈值分别取不同结果如下。Liutex采用幅值等值面因此会存在跟用Q准则一样指定阈值的问题,但根据论文意思是此时画出的等值面和Liutex向量线是大致平行的。
    (1)mag(Rotex)=0.1结果
    (2)mag(Rotex)=0.5结果
    (3)mag(Rotex)=2结果
    我测试了一下,单核计算,对于这个150万网格的算例,每个网格的操作要占用30ms来计算,150万网格就是45000秒。
    因为我对Liutex这个计算过程不熟悉,不清楚这个是否能做简化。
    RQLI_CFD
    @尚善若水 请问fortran代码在哪里可以找到呢
    lizhisongsjtu
    @李东岳 近期科研需要,花了两天研究这个程序。没调通,但发现一个bug。
    原始程序142行qq=(Foam::pow(aa,2), 3*bb)/9与《LiutexG涡定义和第三代涡识别方法》中公式12不同。应改为qq=(-Foam::pow(aa,2)+3*bb)/9。
    另外,求具体执行Rotex的命令!
    L M 2 条回复 最后回复
    lizhisongsjtu
    在 中回复了 lizhisongsjtu 最后由 编辑
    @lizhisongsjtu 在 请教:第三代涡识别方法Liutex的代码在linux中运行的问题 中说:
    原始程序142行qq=(Foam::pow(aa,2), 3bb)/9与《LiutexG涡定义和第三代涡识别方法》中公式12不同。应改为qq=(-Foam::pow(aa,2)+3bb)/9。
    另外,求具体执行Rotex的命令!
    我执行的命令是
    postProcess -latestTime -func Rotex,提示cannot find functionObject file Rotex.
    在 中回复了 RQLI_CFD 最后由 编辑
    #44
    @RQLI_CFD 看这篇文章有写《刘超群, Liutex-涡定义和第三代涡识别方法. 空气动力学学报, 2020. 038(003): 第413-431,478页.》,需要按照要求跟刘老师发邮件
    @lizhisongsjtu
    单进程执行
    Rotex -latestTime > log.Rotex-single
    并行执行,20改为实际用的线程数
    decomposePar
    mpirun -np 20 Rotex -latestTime -parallel > log.Rotex-parallel
    reconstructPar
    lizhisongsjtu
    在 中回复了 coolhhh 最后由 lizhisongsjtu 编辑
    #46
    @coolhhh 谢谢大佬
    下载:RotexZhisong.zip
    在原始版本和东岳大佬版本基础上,用OF自带的场函数替换PQR\delta 的计算语句,200万网格,单核6s。
    提示:新旧PQR\delta计算结果的差异,量级是-12,但最后Rotex的x和y分量有一点差异,z分量差异可忽略。
    我把 http://www.jhydrodynamics.com/en/download-of-liutex-code/ 这个链接里面的代码,小改了一下,放到了OpenFOAM-9里面可以编译成功。
    下载:Rotex.zip
    李东岳李 R B 3 条回复 最后回复
    @lizhisongsjtu
    200万网格,单核6s。
    这个绝对神了!!!属实流弊!
    RQLI_CFD
    #48
    @lizhisongsjtu 感觉这个liutex没有那么好啊,我计算的是槽道流,liutex识别的结果很混乱(liutex的等值面),感觉还没Q准则显示的涡结构清晰,但是看刘老师文章里的效果挺好的。。。
    下图是Q准则识别的涡(只显示了下半部分区域),可以看出清晰的流向结构(Q等值由速度染色)
    (下图Q等值由温度(这里是被动标量)染色)
    but,liutex等值面画出来就很混乱,我调了一些阈值都不是很好,感觉很混乱,下面是统一阈值的各个角度的liutex等值面,总体感觉就很混乱。
    (下面图liutex等值面都为速度染色)
    PS:之前用omega方法识别涡时也出现了跟liutex等值面差不多的现象,刘老师文章里也提到omega方法是跟阈值关系不大的(优于Q准则),但是在我的槽道流算例里,这两种方法似乎都不如Q准则好,请问大家在进行涡识别时有没有类似的经历,请格外大佬指教。
    L 东方白杨东 2 条回复 最后回复
    zzcfd
    具体的代码还没有看,我测试了一下程序运行很有效率,但是我想问一下这个magRotex是liutex的等值面么?还是结合了omega的liutex-omega方法呢?
  • B 离线
    B 离线
    BznW
    @lizhisongsjtu 感谢分享,请问下在of7下同样编译成功,但运行Rotex -latestTime会出现这种报错是什么原因呢82ec2cca-7da5-44b9-b931-61307503ac33-image.png
    L 尚 2 条回复 最后回复
    lizhisongsjtu
    @RQLI_CFD 我不熟悉剪切流动,暂时无法回复楼主的问题。
    对旋转流动,使用经验确实印证了Liutex方法在涡核心区识别方面的卓越表现。文章见刊后,会共享识别涡核心区的结果。
    lizhisongsjtu
    在 中回复了 BznW 最后由 编辑
    @BznW
    感谢您的认可。
    我的使用环境是OF2206和OF2306。没出现类似的问题。建议用2206或2306试验。
    B 1 条回复 最后回复
  • B 离线
    B 离线
    BznW
    #53
    @lizhisongsjtu 又测试了一下,似乎对于blockMesh生成的网格都不会出问题,SHM生成的网格有一定程度会出问题,然后pointwise生成的网格就都会出问题报这种错误:135:
  • 尚 在线
    尚 在线
    尚善若水
    在 中回复了 BznW 最后由 编辑
    #54
    @BznW 在 请教:第三代涡识别方法Liutex的代码在linux中运行的问题 中说:
    遇到同样的问题,blockMesh 生成的结构化网格。李老师和 lizhisongsjtu 程序在 Openfoam v9 和v2212下编译使用,都会浮点溢出。
    Create time
    Create mesh for time = 0.0012
    Time = 0.0012
        Reading U
    #3  ? in "/home/scramjetfoam/OpenFOAM/scramjetfoam-9/platforms/linux64GccDPInt32Opt/bin/Rotex"
    #4  ? in "/lib/x86_64-linux-gnu/libc.so.6"
    #5  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    #6  ? in "/home/scramjetfoam/OpenFOAM/scramjetfoam-9/platforms/linux64GccDPInt32Opt/bin/Rotex"
    lizhisongsjtu
    回复一下Liutex使用效果和使用报错的反馈:
    1. 关于Liutex识别的涡结构:在类似澡盆涡这样的旋转流动里,Liutex的方法确实会有(或者近似会有)阈值独立的涡结构,近似阈值独立的涡结构,lambda2方法、Q方法,都不存在阈值独立的涡结构。
    2. 关于报错:本人使用平台是of2206和of2306,而且流场本身的旋转占优。对剪切流动的效果,本人没有验证。关于浮点溢出,大概率是除数接近0,用户可以自行debug。
    如上!
    zzcfd
    文章出来的时候,烦请通知一下哈。
