  3. OpenFOAM使用icoFoam周期边界条件时压力如何处理?
17 帖子 3 发布者 13.1k 浏览
  • 学流体的小明学 离线
    学流体的小明学 离线
    学流体的小明 神
    在 中回复了 MingfengWang 最后由 学流体的小明 编辑
    @MingfengWang
    1. fvOptions单独成一个文件fvOptions ,在constant或者system目录下。在controlDict中加不会fvOptions 起作用。如果生效的话会有这样的输出:
    Courant Number mean: 5.2432853e-05 max: 0.0046787387
    Interface Courant Number mean: 4.565481e-08 max: 0.0046787387
    deltaT = 1.4332535e-07
    Time = 6.199610856e-07
    PIMPLE: iteration 1
    smoothSolver:  Solving for alpha.water, Initial residual = 4.7622511e-07, Final residual = 6.3664377e-13, No Iterations 1
    Phase-1 volume fraction = 0.9736  Min(alpha.water) = -1.7852346e-28  Max(alpha.water) = 1.0007297
    MULES: Correcting alpha.water
    Phase-1 volume fraction = 0.9736  Min(alpha.water) = -2.7157011e-21  Max(alpha.water) = 1.0007297
    smoothSolver:  Solving for alpha.water, Initial residual = 4.7608513e-07, Final residual = 6.3691332e-13, No Iterations 1
    Phase-1 volume fraction = 0.9736  Min(alpha.water) = -1.7851287e-28  Max(alpha.water) = 1.0007295
    Phase-1 volume fraction = 0.9736  Min(alpha.water) = -8.890103e-22  Max(alpha.water) = 1.0007295
    smoothSolver:  Solving for alpha.water, Initial residual = 4.7594589e-07, Final residual = 6.3718766e-13, No Iterations 1
    Phase-1 volume fraction = 0.9736  Min(alpha.water) = -1.7850229e-28  Max(alpha.water) = 1.0007294
    Phase-1 volume fraction = 0.9736  Min(alpha.water) = -1.3578505e-21  Max(alpha.water) = 1.0007294
    GAMG:  Solving for p_rgh, Initial residual = 0.0020968541, Final residual = 8.4986345e-06, No Iterations 3
    **Pressure gradient source: uncorrected Ubar = 0.040000839, pressure gradient = 3324.6917** //这一行
    time step continuity errors : sum local = 8.2519519e-10, global = -9.3757905e-24, cumulative = -9.9860764e-23
    GAMG:  Solving for p_rgh, Initial residual = 0.00014216941, Final residual = 1.3187746e-06, No Iterations 3
    **Pressure gradient source: uncorrected Ubar = 0.040000842, pressure gradient = 3323.7643** //这一行
    time step continuity errors : sum local = 1.2809363e-10, global = 3.3488584e-24, cumulative = -9.6511905e-23
    GAMG:  Solving for p_rgh, Initial residual = 8.9943051e-06, Final residual = 8.3146747e-08, No Iterations 5
    **Pressure gradient source: uncorrected Ubar = 0.040000838, pressure gradient = 3325.0637** //这一行
    time step continuity errors : sum local = 8.102696e-12, global = -6.6915661e-25, cumulative = -9.7181062e-23
    ExecutionTime = 5.7 s  ClockTime = 6 s
    你看看你那边是不是就没有生效。
    2. 原理是在流场中添加一个体积力源项,不是你想的压差,具体深入的探索可以看 http://xiaopingqiu.github.io/2016/03/20/fvOptions2/ 。 压差的方法可以找找帖子,我记得也有讨论。
    3. 是的,就是UEqn.H和pEqn.H都得改。
    M 2 条回复 最后回复
    MingfengWang
    在 中回复了 学流体的小明 最后由 编辑
    @学流体的小明 非常感谢!
    1. 我是在constant文件夹下添加了fvOptions文件,但是没有得到像你列出的这样的输出,可能是我fvOptinos设置有问题?我再检查一下。
    2. 这个原理我去好好看一下,谢谢!
    3. 关于压差的方法,我也看到论坛上有讨论,我是按照论坛说的方法改的UEqn.H和pEqn.H,但是结果好想不太对,因为压力是集中到入口的一个点上而不是整个入口,这就很怪异,下面是图片:
    学流体的小明学 1 条回复 最后回复
    @李东岳 在 OpenFOAM使用icoFoam周期边界条件时压力如何处理? 中说:
    原理可以看一下这个。不过有一阵子没更新了。我这几天重新整理一下
    http://dyfluid.com/boundaryFoam.html
    插一句,我更新了一下 http://dyfluid.com/boundaryFoam.html
    M 1 条回复 最后回复
    MingfengWang
    @学流体的小明 这是我的邮箱mingfeng.wang@outlook.com,能不能单独交流一下,谢谢!
    MingfengWang
    @李东岳 谢谢李老师:140:
    “icoFoam不能使用fvOptions“我好想是在cfd-online上看到的,但是现在找不到了......
    我给你看了一下,icoFoam确实没有这个功能,你直接换pisoFoam好了。
    M 1 条回复 最后回复
    MingfengWang
    @李东岳 谢谢李老师!是不是查看icoFoam.C代码中没有fvOptions这一项?
    在 中回复了 MingfengWang 最后由 编辑
    @MingfengWang 是的,没有这个
    M 1 条回复 最后回复
  • 学流体的小明学 离线
    学流体的小明学 离线
    学流体的小明 神
    @MingfengWang 压差的方法我也没用过。我也没啥经验,帮不了太多的忙,邮件交流就算了。李老师建议你换pisoFoam应该能解决问题。
    M 1 条回复 最后回复
    MingfengWang
    @学流体的小明 好的,非常感谢!
    MingfengWang
    @李东岳 跟李老师汇报一下,pisoFoam可以使用fvOptions并且有了结果,非常感谢李老师!!!
