  3. 请教关于进口条件的设置的问题
请教关于进口条件的设置的问题
32 帖子 6 发布者 42.4k 浏览
    写于 最后由 CFD中文网 编辑
    1. 你这个网格哪里调用了交界面边界?抱歉看到了。
    2. 结果从第一步就没有保证连续性
    3. 将网格贴图(而非显示面)
    4. 贴chechMesh结果
    5. 贴fvSolution
    6. 贴fvScheme
    注意是贴哦不是上传附近如:
    Time = 2001
    GAMG:  Solving for Ux, Initial residual = 0.00638252, Final residual = 0.000400813, No Iterations 1
    GAMG:  Solving for Uy, Initial residual = 0.00114759, Final residual = 5.63775e-05, No Iterations 1
    GAMG:  Solving for Uz, Initial residual = 0.0283682, Final residual = 0.000925109, No Iterations 1
    GAMG:  Solving for p, Initial residual = 0.867854, Final residual = 0.0670769, No Iterations 4
    time step continuity errors : sum local = 43.0388, global = -0.914839, cumulative = -0.914839
    GAMG:  Solving for omega, Initial residual = 0.0563256, Final residual = 0.00245155, No Iterations 1
    GAMG:  Solving for k, Initial residual = 1, Final residual = 0.0431817, No Iterations 1
    ExecutionTime = 32.24 s  ClockTime = 33 s
    Time = 2002
    GAMG:  Solving for Ux, Initial residual = 0.00830621, Final residual = 0.000239452, No Iterations 1
    GAMG:  Solving for Uy, Initial residual = 0.00165236, Final residual = 4.55896e-05, No Iterations 1
    GAMG:  Solving for Uz, Initial residual = 0.0188184, Final residual = 0.000526957, No Iterations 1
    GAMG:  Solving for p, Initial residual = 0.837434, Final residual = 0.0711894, No Iterations 2
    time step continuity errors : sum local = 148.659, global = -0.294784, cumulative = -1.20962
    GAMG:  Solving for omega, Initial residual = 0.0143057, Final residual = 8.19713e-06, No Iterations 1
    bounding omega, min: -2.58031e+07 max: 3.30734e+11 average: 4.70801e+09
    GAMG:  Solving for k, Initial residual = 0.11034, Final residual = 0.000207143, No Iterations 1
    ExecutionTime = 39.79 s  ClockTime = 40 s
    Time = 2003
    GAMG:  Solving for Ux, Initial residual = 0.00392685, Final residual = 7.6632e-05, No Iterations 1
    GAMG:  Solving for Uy, Initial residual = 0.00110286, Final residual = 1.82308e-05, No Iterations 1
    GAMG:  Solving for Uz, Initial residual = 0.0143816, Final residual = 0.000210414, No Iterations 1
    GAMG:  Solving for p, Initial residual = 0.791161, Final residual = 0.0685184, No Iterations 2
    time step continuity errors : sum local = 111.167, global = -0.185086, cumulative = -1.39471
    GAMG:  Solving for omega, Initial residual = 1, Final residual = 0.0313884, No Iterations 3
    bounding omega, min: -1.11841e+23 max: 5.89039e+26 average: 3.21879e+22
    GAMG:  Solving for k, Initial residual = 0.999599, Final residual = 4.49893e-17, No Iterations 1
    ExecutionTime = 47.54 s  ClockTime = 48 s
    Time = 2004
    GAMG:  Solving for Ux, Initial residual = 0.0028955, Final residual = 7.92784e-05, No Iterations 1
    GAMG:  Solving for Uy, Initial residual = 0.0009558, Final residual = 2.10947e-05, No Iterations 1
    GAMG:  Solving for Uz, Initial residual = 0.0218884, Final residual = 0.000373211, No Iterations 1
    GAMG:  Solving for p, Initial residual = 0.777876, Final residual = 0.065162, No Iterations 3
    time step continuity errors : sum local = 78.0342, global = 0.432795, cumulative = -0.961914
    GAMG:  Solving for omega, Initial residual = 0.538686, Final residual = 3.00162e-09, No Iterations 1
    bounding omega, min: -9.64586e+19 max: 1.32289e+42 average: 7.89521e+35
    GAMG:  Solving for k, Initial residual = 0.178897, Final residual = 1.16811e-20, No Iterations 1
    ExecutionTime = 54.91 s  ClockTime = 56 s
    Time = 2005
    另外,这是一个极为简单的几何,建议采用全六面体。
    CFD中国标准用户测试帐号
    目前由徐笑笑登录
  • 小 离线
    小 离线
    小葱小虫
    |  \\    /   O peration     | Version:  3.0.1                                 |
    Build  : 3.0.1-119cac7e8750
    Exec   : checkMesh
    Date   : Mar 23 2017
    Time   : 23:51:13
    Host   : "ubuntu"
    PID    : 41427
    Case   : /home/cc/OpenFOAM/cc-3.0.1/run/tutorials/incompressible/simpleFoam/nasa65
    nProcs : 1
    Create time
    Create polyMesh for time = 0
    Time = 0
    Mesh stats
        faces:            5504237
        internal faces:   5380555
        cells:            1814132
        faces per cell:   6
        boundary patches: 8
        point zones:      0
        face zones:       0
        cell zones:       0
        hexahedra:     1814132
        prisms:        0
        wedges:        0
        pyramids:      0
        tet wedges:    0
        tetrahedra:    0
        polyhedra:     0
    Checking topology...
        Boundary definition OK.
        Cell to face addressing OK.
        Point usage OK.
        Upper triangular ordering OK.
        Face vertices OK.
        Number of regions: 1 (OK).
        hub                 30748    31275    ok (non-closed singly connected)
        inlet               5546     5700     ok (non-closed singly connected)
        outlet              4543     4680     ok (non-closed singly connected)
        per1                15340    15660    ok (non-closed singly connected)
        per2                15340    15660    ok (non-closed singly connected)
        ps                  10266    10500    ok (non-closed singly connected)
        ss                  11151    11400    ok (non-closed singly connected)
        sym                 30748    31275    ok (non-closed singly connected)
    Checking geometry...
        Overall domain bounding box (-0.0925 -0.0130406 -1.48492e-15) (0.13 0.0278965 0.02)
        Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
        Mesh has 3 solution (non-empty) directions (1 1 1)
        Boundary openness (-1.04226e-16 4.59207e-16 4.83911e-16) OK.
     ***High aspect ratio cells found, Max aspect ratio: 10084.9, number of cells 119355
      <<Writing 119355 cells with high aspect ratio to set highAspectRatioCells
        Minimum face area = 9.85732e-14. Maximum face area = 3.49678e-06.  Face area magnitudes OK.
        Min volume = 9.85915e-19. Max volume = 2.44324e-09.  Total volume = 9.66559e-05.  Cell volumes OK.
        Mesh non-orthogonality Max: 54.3818 average: 6.13782
        Non-orthogonality check OK.
        Face pyramids OK.
        Max skewness = 0.752069 OK.
    Failed 1 mesh checks.
  • 小 离线
    小 离线
    小葱小虫
        class       dictionary;
        object      fvSolution;
    solvers
       p
            solver          GAMG;
            smoother        GaussSeidel;
            cacheAgglomeration true;
            nCellsInCoarsestLevel 10;
            agglomerator    faceAreaPair;
            mergeLevels     1;
            tolerance       1e-06;
            relTol          0.05;
        pFinal
            $p;
            tolerance       1e-06;
            relTol          0;
        "(U|k|epsilon)"
            solver          smoothSolver;
            tolerance       1e-05;
            relTol          0.1;
        "(U|k|epsilon)Final"
            $U;
            tolerance       1e-05;
            relTol          0;
    PIMPLE
        nOuterCorrectors 4;
        nCorrectors     1;
        nNonOrthogonalCorrectors 0;
        pRefCell        0;
        pRefValue       0;
    SIMPLE
        residualControl
            p               1e-2;
            U               1e-3;
            "(k|epsilon)"   1e-3;
    relaxationFactors
        fields
            p               0.3;
        equations
            U               0.7;
            k               0.7;
            "epsilon.*"     0.7;
    cache
        grad(U);
  • 小 离线
    小 离线
    小葱小虫
        class       dictionary;
        object      fvSchemes;
    ddtSchemes
        default         steadyState;
         default         Gauss linear;
    divSchemes
        efault         none;
        div(phi,U)      bounded Gauss limitedLinearV 1;
        div(phi,k)      bounded Gauss limitedLinear 1;
        div(phi,epsilon) bounded Gauss limitedLinear 1;
        div(phi,R)      bounded Gauss limitedLinear 1;
        div(R)          Gauss linear;
        div(phi,nuTilda) bounded Gauss limitedLinear 1;
    laplacianSchemes
    interpolationSchemes
        default         linear;
    snGradSchemes
        default         corrected;
    wallDist
        method meshWave;
  • 小 离线
    小 离线
    小葱小虫
    0_1490344753819_upload-1d58f4d0-683b-446a-884b-a44fff459031
    谢谢。
    进出口边界条件?
    CFD中国标准用户测试帐号
    目前由徐笑笑登录
    小 1 条回复 最后回复
  • 小 离线
    小 离线
    小葱小虫
    在 中回复了 CFD中文网 最后由 编辑
    @cfd-china
    这个是不是网格不好的意思
    这不是个很重要的报错,可以容忍。
    CFD中国标准用户测试帐号
    目前由徐笑笑登录
    小 1 条回复 最后回复
  • 小 离线
    小 离线
    小葱小虫
        class       volScalarField;
        object      p;
    internalField   uniform 122825;
    boundaryField
         hub
                  type            zeroGradient;
        inlet
            type		totalPressure;
    	p0 		uniform 132700;
    	value 		uniform 132700;
    	gamma 		1.4;
        outlet
           type            fixedValue;
            value           uniform 111500;
        per1
           type            cyclicAMI;
        per2
        	type             cyclicAMI;
        ps
              type            zeroGradient;
        ss
        	 type            zeroGradient;
        sym
       	type symmetryPlane;
  • 小 离线
    小 离线
    小葱小虫
    @cfd-china 您看有什么问题吗
        class       volVectorField;
        object      U;
    internalField   uniform (126 113 0);
    boundaryField
        hub
           type            fixedValue;
        inlet
           type            pressureDirectedInletVelocity;
           inletDirection 	uniform	(0.743 0.669 0);
        outlet
             type            zeroGradient;
        per1
             type            cyclicAMI;
        per2
        	  type            cyclicAMI;
        ps
              type            fixedValue;
        ss
        	  type            fixedValue;
        sym
        		type symmetryPlane;
  • 小 离线
    小 离线
    小葱小虫
        location    "0";
        object      k;
    internalField   uniform 194.6;
    boundaryField
      hub
            type            kqRWallFunction;
            value           uniform 194.6;
        inlet
            type            turbulentIntensityKineticEnergyInlet;
            intensity       0.05;
            U               U;
            phi             phi;
        outlet
            type            zeroGradient;
        per1
              type            cyclicAMI;
        per2
        	   type            cyclicAMI;
        ps
        ss
        sym
        type symmetryPlane;
  • 小 离线
    小 离线
    小葱小虫
        object      omega;
    omegaInlet      630.0;
    dimensions      [0 0 -1 0 0 0 0];
    internalField   uniform $omegaInlet;
    boundaryField
         hub
            type            omegaWallFunction;
          inlet
           type            turbulentMixingLengthFrequencyInlet;
            mixingLength    0.025;
            k               k;
        outlet
            type            zeroGradient;
         per1
              type            cyclicAMI;
        per2
        	   type            cyclicAMI;
        ps
        ss
        sym
           type symmetryPlane;
    我注意到你的log 文件里面从第二个时间步长开始, specific dissipation rate (omega)就已经发散了(10^9)。
    omega 文件里
        object      omega;
    你的 internalField uniform $omegaInlet = 630 这个神奇的数字是怎么算的?
    从你的log file 看出,你是从2000 s 开始算的,贴出2000s的初始条件或许能帮助解决问题?
    对于你的的进,出口边界条件不是特别理解。用进口速度边界条件,出口用压力边界条件不能满足你的需求吗?气动问题大家通常都是用这个方法。
    小 1 条回复 最后回复
  • 小 离线
    小 离线
    小葱小虫
    @random_ran 我开始没有开湍流模型,想算个初场,2000部之前都是没有湍流模型的,omega用这个公式算的
    omega = k^0.5/(C^0.25 * l) c=0.09
    我的是进口条件是进口已知总压,和气流方向出口知道静压,算出来速度大约是0.67Ma
  • 小 离线
    小 离线
    小葱小虫
    写于 最后由 CFD中文网 编辑
    这是最新算的几部,麻烦老师们给看一下
    Exec   : simpleFoam
    Date   : Mar 25 2017
    Time   : 02:33:53
    Host   : "ubuntu"
    PID    : 44090
    nProcs : 1
    Create time
    Create mesh for time = 0
    SIMPLE: convergence criteria
        field U	 tolerance 1e-05
        field p	 tolerance 1e-05
        field "(k|epsilon|omega)"	 tolerance 1e-05
    Reading field p
    AMI: Creating addressing and weights between 15340 source faces and 15340 target faces
    AMI: Patch source sum(weights) min/max/average = 0.999911, 1.00059, 1.00001
    AMI: Patch target sum(weights) min/max/average = 0.999839, 1.00646, 1.00006
    Reading field U
    Selecting turbulence model type RAS
    Selecting RAS turbulence model kOmegaSST
    Selecting patchDistMethod meshWave
    kOmegaSSTCoeffs
        alphaK1         0.85;
        alphaK2         1;
        alphaOmega1     0.5;
        alphaOmega2     0.856;
        gamma1          0.555556;
        gamma2          0.44;
        beta1           0.075;
        beta2           0.0828;
        betaStar        0.09;
        a1              0.31;
        b1              1;
        c1              10;
        F3              false;
    No MRF models present
    Starting time loop
    Time = 1
    smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.0813711, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.0714855, No Iterations 5
    smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.0771402, No Iterations 4
    GAMG:  Solving for p, Initial residual = 1, Final residual = 0.0876464, No Iterations 5
    time step continuity errors : sum local = 10.8537, global = 4.01707, cumulative = 4.01707
    smoothSolver:  Solving for omega, Initial residual = 0.259035, Final residual = 0.0221475, No Iterations 3
    smoothSolver:  Solving for k, Initial residual = 1, Final residual = 0.0890898, No Iterations 5
    ExecutionTime = 34.31 s  ClockTime = 36 s
    Time = 2
    smoothSolver:  Solving for Ux, Initial residual = 0.886786, Final residual = 0.058124, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 0.979345, Final residual = 0.0631154, No Iterations 6
    smoothSolver:  Solving for Uz, Initial residual = 0.810242, Final residual = 0.0670691, No Iterations 6
    GAMG:  Solving for p, Initial residual = 0.986904, Final residual = 0.0565546, No Iterations 4
    time step continuity errors : sum local = 1345.89, global = -10.0278, cumulative = -6.0107
    smoothSolver:  Solving for omega, Initial residual = 0.0850778, Final residual = 0.00220061, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 0.814193, Final residual = 0.0238861, No Iterations 2
    ExecutionTime = 45.36 s  ClockTime = 47 s
    Time = 3
    smoothSolver:  Solving for Ux, Initial residual = 0.0193303, Final residual = 0.00152468, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 0.011814, Final residual = 0.00102405, No Iterations 6
    smoothSolver:  Solving for Uz, Initial residual = 0.422504, Final residual = 0.0419746, No Iterations 6
    GAMG:  Solving for p, Initial residual = 0.791662, Final residual = 0.0642592, No Iterations 4
    time step continuity errors : sum local = 957.279, global = -143.421, cumulative = -149.432
    smoothSolver:  Solving for omega, Initial residual = 0.00274129, Final residual = 4.02132e-05, No Iterations 2
    smoothSolver:  Solving for k, Initial residual = 0.169936, Final residual = 0.0157838, No Iterations 1
    ExecutionTime = 56.05 s  ClockTime = 58 s
    Time = 4
    smoothSolver:  Solving for Ux, Initial residual = 0.0983965, Final residual = 0.00679746, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 0.0657851, Final residual = 0.00457164, No Iterations 6
    smoothSolver:  Solving for Uz, Initial residual = 0.206983, Final residual = 0.0189299, No Iterations 6
    GAMG:  Solving for p, Initial residual = 0.980449, Final residual = 0.0634521, No Iterations 4
    time step continuity errors : sum local = 1261.26, global = -92.2404, cumulative = -241.672
    smoothSolver:  Solving for omega, Initial residual = 0.000609973, Final residual = 3.54731e-05, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 0.10451, Final residual = 0.0098634, No Iterations 1
    ExecutionTime = 66.79 s  ClockTime = 69 s
    Time = 5
    smoothSolver:  Solving for Ux, Initial residual = 0.0261376, Final residual = 0.00214716, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 0.0187723, Final residual = 0.00145964, No Iterations 6
    smoothSolver:  Solving for Uz, Initial residual = 0.0626224, Final residual = 0.00595206, No Iterations 6
    GAMG:  Solving for p, Initial residual = 0.921146, Final residual = 0.0735434, No Iterations 4
    time step continuity errors : sum local = 1305.03, global = -174.17, cumulative = -415.842
    smoothSolver:  Solving for omega, Initial residual = 0.000273909, Final residual = 9.03935e-06, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 0.0349887, Final residual = 0.00218001, No Iterations 3
    ExecutionTime = 78.4 s  ClockTime = 81 s
    Time = 6
    smoothSolver:  Solving for Ux, Initial residual = 0.0566235, Final residual = 0.00458913, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 0.0400099, Final residual = 0.00302616, No Iterations 6
    smoothSolver:  Solving for Uz, Initial residual = 0.0384566, Final residual = 0.00324406, No Iterations 6
    GAMG:  Solving for p, Initial residual = 0.916166, Final residual = 0.0603851, No Iterations 4
    time step continuity errors : sum local = 668.506, global = -94.6009, cumulative = -510.443
    smoothSolver:  Solving for omega, Initial residual = 0.000292328, Final residual = 1.62378e-05, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 0.046623, Final residual = 0.00262596, No Iterations 2
    ExecutionTime = 89.53 s  ClockTime = 92 s
    Time = 7
    smoothSolver:  Solving for Ux, Initial residual = 0.233958, Final residual = 0.0176323, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 0.128911, Final residual = 0.00936957, No Iterations 6
    smoothSolver:  Solving for Uz, Initial residual = 0.0442786, Final residual = 0.00376373, No Iterations 6
    GAMG:  Solving for p, Initial residual = 0.952315, Final residual = 0.0728294, No Iterations 4
    time step continuity errors : sum local = 1263.9, global = -195.294, cumulative = -705.737
    smoothSolver:  Solving for omega, Initial residual = 0.000206228, Final residual = 1.22213e-05, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 0.0167436, Final residual = 0.00109875, No Iterations 4
    ExecutionTime = 100.52 s  ClockTime = 103 s
    Time = 8
    smoothSolver:  Solving for Ux, Initial residual = 0.064942, Final residual = 0.00538914, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 0.0316677, Final residual = 0.00284742, No Iterations 6
    smoothSolver:  Solving for Uz, Initial residual = 0.0769102, Final residual = 0.00692843, No Iterations 6
    GAMG:  Solving for p, Initial residual = 0.791177, Final residual = 0.0625584, No Iterations 6
    time step continuity errors : sum local = 645.649, global = -319.458, cumulative = -1025.19
    smoothSolver:  Solving for omega, Initial residual = 0.000258477, Final residual = 1.59141e-05, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 0.0181236, Final residual = 0.00171421, No Iterations 3
    ExecutionTime = 113.31 s  ClockTime = 116 s
    Time = 9
    smoothSolver:  Solving for Ux, Initial residual = 0.219725, Final residual = 0.0183762, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 0.158121, Final residual = 0.0111089, No Iterations 7
    smoothSolver:  Solving for Uz, Initial residual = 0.303528, Final residual = 0.0257045, No Iterations 6
    GAMG:  Solving for p, Initial residual = 0.94797, Final residual = 0.064793, No Iterations 4
    time step continuity errors : sum local = 1113.34, global = -309.45, cumulative = -1334.64
    smoothSolver:  Solving for omega, Initial residual = 0.000122954, Final residual = 1.00576e-05, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 0.0197785, Final residual = 0.00176744, No Iterations 3
    ExecutionTime = 126.36 s  ClockTime = 129 s
    Time = 10
    smoothSolver:  Solving for Ux, Initial residual = 0.0821976, Final residual = 0.00721542, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 0.03459, Final residual = 0.00247223, No Iterations 7
    smoothSolver:  Solving for Uz, Initial residual = 0.1429, Final residual = 0.0115741, No Iterations 6
    GAMG:  Solving for p, Initial residual = 0.861997, Final residual = 0.084008, No Iterations 5
    time step continuity errors : sum local = 1083.47, global = 389.776, cumulative = -944.868
    smoothSolver:  Solving for omega, Initial residual = 0.000136441, Final residual = 2.43071e-06, No Iterations 2
    smoothSolver:  Solving for k, Initial residual = 0.0235868, Final residual = 0.00172782, No Iterations 3
    ExecutionTime = 138.69 s  ClockTime = 141 s
    Time = 11
    smoothSolver:  Solving for Ux, Initial residual = 0.163168, Final residual = 0.0136899, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 0.0793402, Final residual = 0.00752288, No Iterations 5
    smoothSolver:  Solving for Uz, Initial residual = 0.386931, Final residual = 0.0294783, No Iterations 6
    GAMG:  Solving for p, Initial residual = 0.870129, Final residual = 0.0711586, No Iterations 6
    time step continuity errors : sum local = 919.618, global = 516.016, cumulative = -428.851
    smoothSolver:  Solving for omega, Initial residual = 0.000106145, Final residual = 1.01946e-05, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 0.0196961, Final residual = 0.0018465, No Iterations 3
    ExecutionTime = 151.28 s  ClockTime = 154 s
    Time = 12
    smoothSolver:  Solving for Ux, Initial residual = 0.274151, Final residual = 0.0245354, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 0.186447, Final residual = 0.0165338, No Iterations 5
    smoothSolver:  Solving for Uz, Initial residual = 0.156144, Final residual = 0.0136401, No Iterations 6
    GAMG:  Solving for p, Initial residual = 0.887478, Final residual = 0.070432, No Iterations 6
    time step continuity errors : sum local = 1119.32, global = 661.637, cumulative = 232.786
    smoothSolver:  Solving for omega, Initial residual = 0.000100293, Final residual = 2.24457e-06, No Iterations 2
    smoothSolver:  Solving for k, Initial residual = 0.0248731, Final residual = 0.00212404, No Iterations 3
    ExecutionTime = 164.01 s  ClockTime = 167 s
    Time = 13
    smoothSolver:  Solving for Ux, Initial residual = 0.205525, Final residual = 0.0187076, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 0.0923904, Final residual = 0.00894338, No Iterations 5
    smoothSolver:  Solving for Uz, Initial residual = 0.196898, Final residual = 0.0175523, No Iterations 6
    GAMG:  Solving for p, Initial residual = 0.817651, Final residual = 0.0790382, No Iterations 8
    time step continuity errors : sum local = 1128.57, global = 728.044, cumulative = 960.83
    smoothSolver:  Solving for omega, Initial residual = 0.00010952, Final residual = 2.80076e-06, No Iterations 2
    smoothSolver:  Solving for k, Initial residual = 0.0218195, Final residual = 0.00158256, No Iterations 4
    ExecutionTime = 178.57 s  ClockTime = 181 s
    Time = 14
    smoothSolver:  Solving for Ux, Initial residual = 0.209248, Final residual = 0.0174402, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 0.234617, Final residual = 0.0220479, No Iterations 6
    smoothSolver:  Solving for Uz, Initial residual = 0.330718, Final residual = 0.0281098, No Iterations 6
    GAMG:  Solving for p, Initial residual = 0.871195, Final residual = 0.0759581, No Iterations 10
    time step continuity errors : sum local = 1172.79, global = 858.035, cumulative = 1818.86
    smoothSolver:  Solving for omega, Initial residual = 0.000111802, Final residual = 3.26755e-06, No Iterations 2
    smoothSolver:  Solving for k, Initial residual = 0.0256925, Final residual = 0.00171392, No Iterations 4
    ExecutionTime = 193.33 s  ClockTime = 196 s
    Time = 15
    smoothSolver:  Solving for Ux, Initial residual = 0.173376, Final residual = 0.0142151, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 0.141625, Final residual = 0.0112524, No Iterations 7
    smoothSolver:  Solving for Uz, Initial residual = 0.203415, Final residual = 0.0168199, No Iterations 6
    GAMG:  Solving for p, Initial residual = 0.850352, Final residual = 0.0820699, No Iterations 8
    time step continuity errors : sum local = 1261.82, global = 852.091, cumulative = 2670.96
    smoothSolver:  Solving for omega, Initial residual = 0.000119946, Final residual = 3.04546e-06, No Iterations 2
    smoothSolver:  Solving for k, Initial residual = 0.0523867, Final residual = 0.00451596, No Iterations 2
    ExecutionTime = 206.27 s  ClockTime = 209 s
    Time = 16
    smoothSolver:  Solving for Ux, Initial residual = 0.189402, Final residual = 0.0147132, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 0.172538, Final residual = 0.0148313, No Iterations 6
    smoothSolver:  Solving for Uz, Initial residual = 0.216101, Final residual = 0.0175322, No Iterations 6
    GAMG:  Solving for p, Initial residual = 0.831111, Final residual = 0.0800892, No Iterations 13
    time step continuity errors : sum local = 1124.03, global = -888.775, cumulative = 1782.18
    smoothSolver:  Solving for omega, Initial residual = 0.000132821, Final residual = 2.71341e-06, No Iterations 2
    smoothSolver:  Solving for k, Initial residual = 0.0429148, Final residual = 0.00279213, No Iterations 3
    ExecutionTime = 220.4 s  ClockTime = 223 s
    Time = 17
    smoothSolver:  Solving for Ux, Initial residual = 0.240906, Final residual = 0.0185245, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 0.481738, Final residual = 0.0406032, No Iterations 5
    smoothSolver:  Solving for Uz, Initial residual = 0.306464, Final residual = 0.0227411, No Iterations 6
    GAMG:  Solving for p, Initial residual = 0.829137, Final residual = 0.0797512, No Iterations 5
    time step continuity errors : sum local = 1176.95, global = 495.085, cumulative = 2277.27
    smoothSolver:  Solving for omega, Initial residual = 0.000148683, Final residual = 1.27859e-05, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 0.0542324, Final residual = 0.0033722, No Iterations 3
    ExecutionTime = 231.68 s  ClockTime = 235 s
    Time = 18
    smoothSolver:  Solving for Ux, Initial residual = 0.206106, Final residual = 0.0161844, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 0.255402, Final residual = 0.0223374, No Iterations 5
    smoothSolver:  Solving for Uz, Initial residual = 0.341787, Final residual = 0.0275786, No Iterations 6
    GAMG:  Solving for p, Initial residual = 0.827099, Final residual = 0.082525, No Iterations 7
    time step continuity errors : sum local = 1134.39, global = 819.278, cumulative = 3096.54
    smoothSolver:  Solving for omega, Initial residual = 9.46476e-05, Final residual = 2.25188e-06, No Iterations 2
    smoothSolver:  Solving for k, Initial residual = 0.0505738, Final residual = 0.00348548, No Iterations 3
    ExecutionTime = 242.31 s  ClockTime = 246 s
    Time = 19
    smoothSolver:  Solving for Ux, Initial residual = 0.199931, Final residual = 0.0167285, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 0.361021, Final residual = 0.0275666, No Iterations 6
    smoothSolver:  Solving for Uz, Initial residual = 0.234612, Final residual = 0.0186392, No Iterations 6
    GAMG:  Solving for p, Initial residual = 0.829252, Final residual = 0.0781392, No Iterations 18
    time step continuity errors : sum local = 1182.87, global = 1048.32, cumulative = 4144.86
    smoothSolver:  Solving for omega, Initial residual = 0.000103443, Final residual = 9.28303e-06, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 0.160832, Final residual = 0.0122526, No Iterations 1
    ExecutionTime = 255.21 s  ClockTime = 259 s
    Time = 20
    smoothSolver:  Solving for Ux, Initial residual = 0.203207, Final residual = 0.0177404, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 0.328249, Final residual = 0.0269088, No Iterations 6
    smoothSolver:  Solving for Uz, Initial residual = 0.224519, Final residual = 0.0164899, No Iterations 6
    GAMG:  Solving for p, Initial residual = 0.838448, Final residual = 0.0774968, No Iterations 16
    time step continuity errors : sum local = 1282.19, global = 1084.48, cumulative = 5229.34
    smoothSolver:  Solving for omega, Initial residual = 0.000137159, Final residual = 1.18779e-05, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 0.105212, Final residual = 0.00733032, No Iterations 2
    ExecutionTime = 268.59 s  ClockTime = 273 s
    Time = 21
    smoothSolver:  Solving for Ux, Initial residual = 0.195891, Final residual = 0.0166656, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 0.295498, Final residual = 0.0264212, No Iterations 6
    smoothSolver:  Solving for Uz, Initial residual = 0.256556, Final residual = 0.019235, No Iterations 6
    GAMG:  Solving for p, Initial residual = 0.820159, Final residual = 0.0809549, No Iterations 27
    time step continuity errors : sum local = 1210.13, global = -1110.62, cumulative = 4118.72
    smoothSolver:  Solving for omega, Initial residual = 0.000209472, Final residual = 1.33081e-05, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 0.0963909, Final residual = 0.00779254, No Iterations 2
    ExecutionTime = 283.95 s  ClockTime = 288 s
    Time = 22
    smoothSolver:  Solving for Ux, Initial residual = 0.210533, Final residual = 0.0180219, No Iterations 5
    smoothSolver:  Solving for Uy, Initial residual = 0.451871, Final residual = 0.0368704, No Iterations 6
    smoothSolver:  Solving for Uz, Initial residual = 0.267514, Final residual = 0.0242343, No Iterations 5
    GAMG:  Solving for p, Initial residual = 0.828406, Final residual = 0.0758993, No Iterations 30
    time step continuity errors : sum local = 1183.8, global = 1080.35, cumulative = 5199.06
    smoothSolver:  Solving for omega, Initial residual = 0.00040392, Final residual = 1.58342e-05, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 0.116199, Final residual = 0.00839545, No Iterations 2
    ExecutionTime = 299.9 s  ClockTime = 304 s
    Time = 23
    smoothSolver:  Solving for Ux, Initial residual = 0.223249, Final residual = 0.0207695, No Iterations 5
    smoothSolver:  Solving for Uy, Initial residual = 0.479522, Final residual = 0.0438371, No Iterations 5
    smoothSolver:  Solving for Uz, Initial residual = 0.287509, Final residual = 0.0233311, No Iterations 5
    GAMG:  Solving for p, Initial residual = 0.819938, Final residual = 0.0816971, No Iterations 21
    time step continuity errors : sum local = 1364, global = -1206.8, cumulative = 3992.26
    smoothSolver:  Solving for omega, Initial residual = 0.000308337, Final residual = 2.31198e-05, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 0.183739, Final residual = 0.0103415, No Iterations 2
    ExecutionTime = 314.31 s  ClockTime = 319 s
    质量严重不守恒,为何不把网格做到10万以下,轻量级跑跑试试?
    CFD中国标准用户测试帐号
    目前由徐笑笑登录
    小 1 条回复 最后回复
  • 小 离线
    小 离线
    小葱小虫
    @cfd-china 好的,我这么设置周期边界没有问题吧,两个面的距离是22mm
        class       polyBoundaryMesh;
        location    "constant/polyMesh";
        object      boundary;
    8
        hub
            type wall;
            nFaces          30748;
            startFace       5380555;
        inlet
            type patch;
            nFaces          5546;
            startFace       5411303;
        outlet
            type patch;
            nFaces          4543;
            startFace       5416849;
        per1
              type            cyclicAMI;
            nFaces          15340;
            startFace       5421392;
            neighbourPatch   per2;
            matchTolerance    0.01;
    	transform         translational;
    	separationVector (0 0.022 0);
        per2
             type            cyclicAMI;
           nFaces          15340;
           startFace       5436732;
           neighbourPatch   per1;
           separationVector (0 -0.022 0);
        ps
            type            wall;
            nFaces          10266;
            startFace       5452072;
        ss
            type            wall;
            nFaces          11151;
            startFace       5462338;
        sym
            type symmetryPlane;
            nFaces          30748;
            startFace       5473489;
    为何不用cyclic?
    per1
              type            cyclic;
            nFaces          15340;
            startFace       5421392;
        per2
             type            cyclic;
           nFaces          15340;
           startFace       5436732;
    CFD中国标准用户测试帐号
    目前由徐笑笑登录
    小 2 条回复 最后回复
  • 小 离线
    小 离线
    小葱小虫
    @cfd-china 我感觉这个我理解的可能有问题,是应该给平移距离的大小(0.022m),还是(0,1,0)这么给。当时从这里看见的0_1490441899214_cyclic.jpg
  • 小 离线
    小 离线
    小葱小虫
    @cfd-china 使用cyclic会有这个问题,因为两侧网格并不完全匹配
    Exec   : simpleFoam
    Date   : Mar 25 2017
    Time   : 05:33:37
    Host   : "ubuntu"
    PID    : 48984
    Case   : /home/cc/OpenFOAM/cc-3.0.1/run/tutorials/incompressible/simpleFoam/cynasa
    nProcs : 1
    Create time
    --> FOAM FATAL ERROR:
    face 47 area does not match neighbour by 10.4554% -- possible face ordering problem.
    patch:per1 my area:1.63789e-10 neighbour area:1.47515e-10 matching tolerance:0.1
    Mesh face:5421439 fc:(0.0411928 0.00446869 5e-07)
    Neighbour fc:(0.040347 0.0264296 5e-07)
    If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file.
    Rerun with cyclic debug flag set for more information.
        From function cyclicPolyPatch::calcTransforms()
        in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 221.
    FOAM exiting
