  3. shm对于blockMesh和gmsh生成的背景网格计算时长不同
21 帖子 4 发布者 17.2k 浏览
    Samuel-Tu
    写于 最后由 Samuel-Tu 编辑
    用diff比较了差异,选取了主要的差异出来。<是blockMesh的,>是gmsh的。
    Gmsh的背景网格比BlockMesh的还要多,但是shm用时却少了很多。如果需要的话。我可以严格控制两套网格基本一致,提供给大家用于shm试验
    44c35
    <     Number of edges             : 246036
    >     Number of edges             : 406712
    48,49c39,40
    <     Number of edges to retest   : 246036
    >     Number of edges to retest   : 406712
    51c42
    < Calculated surface intersections in = 0.16 s
    > Calculated surface intersections in = 0.28 s
    53c44
    < Initial mesh : cells:61380  faces:246036  points:123794
    > Initial mesh : cells:101504  faces:406712  points:204402
    55c46
    <     0 61380
    >     0 101504
    65c56
    128c119
    < dupNonManifoldPoints : Found : 0 non-manifold points (out of 123794)
    > dupNonManifoldPoints : Found : 0 non-manifold points (out of 204402)
    149c140
    < down 330      10     0.0298    0.544
    > down 488      10     0.03      0.547
    216,217c207,208
    < Extruding 330 out of 330 faces (100%). Removed extrusion at 0 faces.
    < Added 3300 out of 3300 cells (100%).
    > Extruding 488 out of 488 faces (100%). Removed extrusion at 0 faces.
    > Added 4880 out of 4880 cells (100%).
    219c210
    <     Number of edges             : 259246
    >     Number of edges             : 426242
    226c217
    < down 330      10       0.544     100
    > down 488      10       0.547     100
    228,229c219,220
    < Writing 3300 added cells to cellSet addedCells
    < Writing 2970 faces inside added layer to faceSet layerFaces
    > Writing 4880 added cells to cellSet addedCells
    > Writing 4392 faces inside added layer to faceSet layerFaces
    236c227
    < Layer mesh : cells:64680  faces:259246  points:130414
    > Layer mesh : cells:106384  faces:426242  points:214182
    238,241c229,232
    <     0 64680
    < Writing mesh to time constant
    < Wrote mesh in = 30.25 s.
    < Layers added in = 30.25 s.
    >     0 106384
    > Writing mesh to time 0.01
    > Wrote mesh in = 2.52 s.
    > Layers added in = 2.52 s.
    254c245,246
    < Finished meshing in = 30.82 s.
    \ 文件尾没有换行符
    > Finished meshing in = 3.49 s.
    > End
    \ 文件尾没有换行符
    最后网格做完了之后数量查的多么
    你两个终端同时跑就应该能感觉出来那个步骤卡的慢了 我看你blockMesh的edge大约是gmsh的2倍
    Samuel-Tu
    @李东岳 我后来比较严格控制了gmsh和blockMesh的网格数量,膨胀率一样,生成的网格几乎一样了,11万的网格总量,差了3千个网格左右。gmsh的网格shm用时3s左右,blockMesh的网格shm用啥110s。差的也太多了,完全想不通为什么。。
    @Samuel-Tu 不涉密可以把算例发上来玩玩
    S 3 条回复 最后回复
    cresendo
    想请教一下gmsh画背景网格是有什么优势吗@Samuel-Tu
    Samuel-Tu
    在 中回复了 李东岳 最后由 Samuel-Tu 编辑
    @李东岳 我想发,但是有20MB,发不上来了。。分卷压缩上传提示格式后缀不对。。我留个百度网盘的连接吧
    Samuel-Tu
    在 中回复了 cresendo 最后由 编辑
    @cresendo gmsh建模还是比较方便的。当时觉得blockMesh要找各个点,面的序号很麻烦。
    Samuel-Tu
    @李东岳 链接:
    https://pan.baidu.com/s/13TAxxBcLouq7SGAj5kdtOw
    提取码:zkmi
    解压缩后有两个文件夹,一个叫gmsh,一个叫blockMesh,constant里面的网格是用两种方法分别生成好的背景网格,只需运行snappyHexMesh即可。snappyHexMesh里面只打开了addlayers,是给down边界加一个十层的边界层。gmsh和blockMesh的shm文件完全一样。checkMesh应该可以发现gmsh和blockMesh网格计算域,网格数量,最小最大尺寸是差不多的。
    但是根据我的shm处理时间,gmsh的只用了3秒,而blockMesh的用了110秒。。差距很大
    Samuel-Tu
    @李东岳 有一个很大的发现,blockMesh的时候我设置了empty边界。然后shm的时候 "correcting 2-D motion"这个信息运算了很久。然后我把blockMesh里面的empty边界改成了patch,瞬间治愈!!!!!!!!!!现在blockMesh的shm时间也是3秒了。。。
    原来用gmsh的时候是没法定义empty的,默认是patch边界!所以gmsh的shm信息里没有"correcting 2-D motion"这个信息,也没有相应的计算。
    现在看来shm似乎面对2D网格(尽管是伪三维网格,厚度方向只有一层网格)的时候出现了一些问题。因此我建议shm的时候先不要设置empty,画完网格后再改边界类型。
    感谢分享 恭喜你debug成功 :146:
    Samuel-Tu
    紧接着,由于gmsh网格转换时是没有empty边界的,我又把gmsh网格里改成empty。果然shm的时候耗时110秒。因此我的结论是:
    SHM疑似在发现使用了二维网格后,会做一个额外的计算,这个额外的计算消耗了大量的时间。
    另外我觉得这个额外计算是不必要的,因为本来二维网格就是厚度方向只有一层,不用细分的。。。
    cresendo
    在 中回复了 Samuel-Tu 最后由 编辑
    @Samuel-Tu 受教了,有空尝试一下:146:
    leilei
    @Samuel-Tu :
    谢谢分享。。。 再讨教下:
    portable的win版gmsh,怎么用python调用?。。。要编辑系统变量吗? 谢谢
    Samuel-Tu
    在 中回复了 leilei 最后由 编辑
    @leilei 没用过python调用gmsh
    leilei
    @Samuel-Tu: 好, 但仍谢谢Tu兄的回复,Tu兄,辛苦了
