  3. ICEM无法打开
ICEM无法打开
7 帖子 3 发布者 7.8k 浏览
  • liujunCFDL 离线
    liujunCFDL 离线
    liujunCFD
    兄弟们,两个版本的ICEM不知道为啥都打不开了,重装了也不行,你们有没有遇到过这种情况啊:136: :136: :136: :136: :136:
    车企
  • liujunCFDL 离线
    liujunCFDL 离线
    liujunCFD
    icemcfdbat那个文件在的,但是不知道为啥就是打不开了
    车企
    liujunCFDL 1 条回复 最后回复
  • liujunCFDL 离线
    liujunCFDL 离线
    liujunCFD
    在 中回复了 liujunCFD 最后由 编辑
    老铁们,我知道问题出在哪了,应该是使用批处理功能的时候杀毒软件把bat文件给删了
    现在给大家分享一下解决方法:chitang:
    在记事本中输入以下代码,并且将后缀改为bat
    @echo off
    rem set ICEM_LICENSING_FLAGS=ansys
    rem set ICEM_LICENSING_FLAGS=icem
    rem set ICEM_LICENSE_FILE=c:\icemcfd\5.1-win\lic\license.dat
    rem set ANSYSLMD_LICENSE_FILE=c:\icemcfd\5.1-win\lic\license.dat
    rem if "%ICEM_ACN%"=="" set ICEM_ACN=%~dp0..
    set sub=\bin\
    set full=%~dp0
    call set work=%%full:%sub%=%%
    set ICEM_ACN=%work%
    set aie_mode=1
    rem No default - determine during initialization
    rem if "%AI_ENV_PRODUCT%" == "" set AI_ENV_PRODUCT=fsi
    rem Need to allow user to hard set AI_ENV_PRODUCT for PRO/E External
    rem Analysis to work properly.
    rem Since bat files set the variables in the calling msdos prompt window if you
    rem run icemcfd -ai and then icemcfd -4 you will not get the -4 GUI.  So reset the
    rem variables here to clean out old values.  -Wayne
    set ICEM_AI_ENVIRONMENT=
    set AI_ENV_CFD=
    set AI_ENV_CFD_ONLY=
    set AI_ENV_CFX=
    set AI_NO_BLOCKING=
    set AI_NO_POST=
    set AI_ENV_CART3D=
    set AI_ENV_LSTC=
    set AI_ENV_ANSYS_SOLVERS=
    if not exist "%ANSYS81_DIR%" set ANSYS81_DIR=%ICEM_ACN%\bin
    if not exist "%ANSYS90_DIR%" set ANSYS90_DIR=%ICEM_ACN%\bin
    if not exist "%ANSYS100_DIR%" set ANSYS100_DIR=%ICEM_ACN%\bin
    if not exist "%ANSYS110_DIR%" set ANSYS110_DIR=%ICEM_ACN%\bin
    if not exist "%ANSYS120_DIR%" set ANSYS120_DIR=%ICEM_ACN%\bin
    if not exist "%ANSYS121_DIR%" set ANSYS121_DIR=%ICEM_ACN%\bin
    if not exist "%ANSYS130_DIR%" set ANSYS130_DIR=%ICEM_ACN%\bin
    set PRINT_MESSAGE=
    if "%ANS_FLEXLM_DEBUG%"=="1" set PRINT_MESSAGE=1
    if "%ANS_FLEXLM_DEBUG%"=="2" set PRINT_MESSAGE=1
    set VAR1=
    set FLAVOR=
    set AI_ENV_TEST_LICENSING=
    set VAR1=%~1
    if "%PRINT_MESSAGE%"=="1" echo VAR1 is %VAR1%
    if "%VAR1%" == "-4" goto top
    rem if "%VAR1%" == "-batch" goto top
    rem if "%VAR1%" == "-script" goto top
    rem if "%VAR1%" == "-app" goto top
    if "%VAR1%" == "-ai" goto top
    if "%VAR1%" == "-cfd" goto top
    if "%VAR1%" == "-cfx" goto top
    if "%VAR1%" == "-ansys" goto top
    if "%VAR1%" == "-fsi" goto top
    if "%VAR1%" == "-lstc" goto top
    if "%VAR1%" == "-autohex" goto top
    if "%VAR1%" == "-batchsurf" goto top
    rem move call for test_licensing to initialization stage
    set AI_ENV_TEST_LICENSING=1
    :top
    if "%~1"=="" goto bot
    if "%~1"=="-4" (
        set aie_mode=0
        set AI_ENV_PRODUCT=cfd
        shift
        goto top
    rem if "%~1"=="-app" (
    rem     set AI_ENV_PRODUCT=%~2
    rem     shift
    rem     shift
    rem     goto top
    rem )
    if "%~1"=="-cfd" (
        set FLAVOR=-cfd
        if "%~2"=="-no_hexa" set AI_NO_BLOCKING=1
        if "%~3"=="-no_hexa" set AI_NO_BLOCKING=1
        if "%~4"=="-no_hexa" set AI_NO_BLOCKING=1
        if "%~2"=="-no_post" set AI_NO_POST=1
        if "%~3"=="-no_post" set AI_NO_POST=1
        if "%~4"=="-no_post" set AI_NO_POST=1
        if "%~2"=="-cart3d" set AI_ENV_CART3D=1
        if "%~3"=="-cart3d" set AI_ENV_CART3D=1
        if "%~4"=="-cart3d" set AI_ENV_CART3D=1
        shift
        goto top
    if "%~1"=="-cfx" (
        set FLAVOR=-cfx
        set AI_ENV_PRODUCT=cfx
        shift
        goto top
    if "%~1"=="-ansys" (
        set FLAVOR=-ansys
        shift
        goto top
    if "%~1"=="-ai" (
        set FLAVOR=-ai
        set AI_ENV_PRODUCT=fea2.0
        shift
        goto top
    if "%~1"=="-fsi" (
        set FLAVOR=-fsi
        shift
        goto top
    if "%~1"=="-lstc" (
        set FLAVOR=-lstc
        set AI_ENV_PRODUCT=lstc
        shift
        goto top
    if "%~1" == "-autohex" goto AUTOHEXA
    if "%~1" == "-batchsurf" goto BATCHSURF
    if "%~1" == "-h" goto UsageCFD
    if "%~1" == "-help" goto UsageCFD
    if "%~1" == "/?" goto UsageCFD
    :bot
    if "%PRINT_MESSAGE%"=="1" echo FLAVOR is %FLAVOR%
    if "%~1"=="-no_hexa" set AI_NO_BLOCKING=1
    if "%~1"=="-no_post" set AI_NO_POST=1
    if "%~1"=="-cart3d" set AI_ENV_CART3D=1
    if "%FLAVOR%"=="-cfd" (
        goto bot1
    if "%FLAVOR%"=="-cfx" (
        set AI_NO_POST=1
        set AI_ENV_ANSYS_SOLVERS=1
        goto bot1
    if "%FLAVOR%"=="-ansys" (
        set AI_NO_POST=1
        set AI_ENV_PRODUCT=ansys
        goto bot1
    if "%FLAVOR%"=="-ai" (
        goto bot1
    if "%FLAVOR%"=="-fsi" (
        goto bot1
    if "%FLAVOR%"=="-lstc" (
        goto bot1
    :bot1
    if "%AI_NO_BLOCKING%"=="0" set AI_NO_BLOCKING=
    if "%AI_NO_POST%"=="0" set AI_NO_POST=
    if "%AI_ENV_CART3D%"=="0" set AI_ENV_CART3D=
    if "%PRINT_MESSAGE%"=="1" echo AI_NO_BLOCKING is %AI_NO_BLOCKING%
    if "%PRINT_MESSAGE%"=="1" echo AI_NO_POST is %AI_NO_POST%
    if "%PRINT_MESSAGE%"=="1" echo AI_ENV_CART3D is %AI_ENV_CART3D%
    if "%aie_mode%"=="1" (
        set ICEM_AI_ENVIRONMENT=1
        if "%AI_ENV_PRODUCT%"=="fea2.0" (
            set AI_ENV_ANSYS=1
            set AI_ENV_LSDYNA=1
            set AI_ENV_ABAQUS=1
            set AI_ENV_AUTODYN=1
        if "%AI_ENV_PRODUCT%"=="cfd" (
            set AI_ENV_CFD=1
            set AI_ENV_CFD_ONLY=1
        if "%AI_ENV_PRODUCT%"=="cfx" (
            set AI_ENV_CFD=1
            set AI_ENV_CFX=1
        if "%AI_ENV_PRODUCT%"=="ansys" (
            set AI_ENV_CFD=1
            set AI_ENV_ANSYS=1
            set AI_ENV_LSDYNA=1
        if "%AI_ENV_PRODUCT%"=="fsi" (
            set AI_ENV_CFD=1
            set AI_ENV_ANSYS=1
            set AI_ENV_LSDYNA=1
            set AI_ENV_ABAQUS=1
        if "%AI_ENV_PRODUCT%"=="commonstruct" (
            set AI_ENV_ANSYS=1
            set AI_ENV_LSDYNA=1
            set AI_ENV_ABAQUS=1
        if "%AI_ENV_PRODUCT%"=="lstc" (
            set AI_ENV_CFD=1
            set AI_ENV_LSTC=1
    if "%PRINT_MESSAGE%"=="1" echo AI_ENV_PRODUCT is %AI_ENV_PRODUCT%
    if not exist Uninst.isu goto StartCFD
    if exist icemcfd.bat goto WrongDir
    :StartCFD
    if not exist "%ICEM_ACN%\bin\med.exe" goto NoInstall
    if "%PROCESSOR_ARCHITECTURE%"=="x86" (
        set AWP_FRAMEWORK_PLATFORM=Win32
    ) else if "%PROCESSOR_ARCHITECTURE%"=="AMD64" (
        set AWP_FRAMEWORK_PLATFORM=Win64
    ) else (
        echo.Error: Environment variable PROCESSOR_ARCHITECTURE should contain
        echo.either x86 or AMD64
        Pause
        exit /b 1
    set KEEP_PATH=%PATH%
    set PATH=%ICEM_ACN%\bin;%ICEM_ACN%\lib;%PATH%;%ICEM_ACN%\toolswin32
    if exist "%AWP_ROOT130%\AISOL\Bin\%ANSYS_SYSDIR%" set PATH=%PATH%;%AWP_ROOT130%\AISOL\Bin\%ANSYS_SYSDIR%
    if exist "%AWP_ROOT130%\Framework\Bin\%AWP_FRAMEWORK_PLATFORM%" set PATH=%PATH%;%AWP_ROOT130%\Framework\Bin\%AWP_FRAMEWORK_PLATFORM%
    if "%~1" == "-batch" goto StartBatch
    rem med.exe %* | "%ICEM_ACN%\toolswin32\cat.exe"
    start /wait med.exe %*
    goto StartFinish
    :AUTOHEXA
    set AUTOHEX_ROOT=%ICEM_ACN%
    if not exist "%AUTOHEX_ROOT%\bin\autohex.exe" goto NoInstall
    goto StartFinish
    :BATCHSURF
    set AI_ENV_ANSYS=1
    set AI_ENV_LSDYNA=1
    set AI_ENV_ABAQUS=1
    set ICEM_SCRIB=%ICEM_ACN%\lib\scrib
    set TCL_LIBRARY=%ICEM_ACN%\lib\tcl8.3.3
    set TK_LIBRARY=%ICEM_ACN%\lib\tk8.3.3
    if not exist "%ICEM_ACN%\bin\wish.exe" goto NoInstall
    "%ICEM_ACN%\bin\wish.exe" "%ICEM_SCRIB%\app\main.tcl" app_bsm_generic"
    goto StartFinish
    :StartBatch
    start /b /wait med_batch.exe %*
    :StartFinish
    set PATH=%KEEP_PATH%
    goto ExitCFD
    :WrongDir
    echo Can't run ICEM CFD in the Installation Directory!
    pause
    goto ExitCFD
    :NoInstall
    echo Can't find the Installation Directory!
    pause
    goto ExitCFD
    :UsageCFD
    echo Usage: icemcfd.bat [-script ScriptName] [-4] [-app APP] [-cfd] [-batch] [projectfile]
    pause
    :ExitCFD
    然后放到以下路路径就可以了
    D:\ANSYS2020R1\ANSYS Inc\v201\icemcfd\win64_amd\bin
    车企
  • liujunCFDL 离线
    liujunCFDL 离线
    liujunCFD
    参考:https://www.jianshu.com/p/a66b731e0794
    车企
    感谢分享 很专业啊!
  • liujunCFDL 离线
    liujunCFDL 离线
    liujunCFD
    @李东岳 :::high: 嘿嘿嘿,被这个问题困扰了好几天,留下此贴,希望以后可以帮到别人。
    车企
    bestucanB 1 条回复 最后回复
    @liujunCFD
    小骗叽:136: :136: :136:
