  3. 200万网格并行算力测试(OpenFOAM版本)
244 帖子 61 发布者 1.1m 浏览
    在 中回复了 kennyadapter 最后由 编辑
    @kennyadapter 你这个看起来就是带宽跟不上了
    @来瓶热阔落 你看下你8核和4核的最开始时间步的log?类似这种,分别贴一下:
    Time = 0.1
    Courant Number mean: 0.733413 max: 1.27933
    GAMG:  Solving for p, Initial residual = 0.0999699, Final residual = 0.000818608, No Iterations 6
    time step continuity errors : sum local = 4.79761e-07, global = 8.13808e-20, cumulative = 1.63519e-17
    Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 0.00012387
    GAMG:  Solving for p, Initial residual = 0.081007, Final residual = 0.000576888, No Iterations 6
    time step continuity errors : sum local = 3.41793e-07, global = 5.45899e-20, cumulative = 1.64065e-17
    Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 0.000120508
    GAMG:  Solving for p, Initial residual = 0.0189675, Final residual = 9.02577e-07, No Iterations 39
    time step continuity errors : sum local = 5.28191e-10, global = 1.77208e-20, cumulative = 1.64242e-17
    Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 0.00011971
    ExecutionTime = 173.99 s  ClockTime = 174 s
    K 来 2 条回复 最后回复
  • K 离线
    K 离线
    kennyadapter
    @东岳 在 200万网格管道流qDNS并行算力测试 中说:
    东岳老师,那怎么调整带宽呢?有什么方法,或者需要更换什么配件吗?
  • 来 离线
    来 离线
    来瓶热阔落
    Time = 0.1
    Courant Number mean: 0.731999 max: 1.22083
    GAMG:  Solving for p, Initial residual = 0.629705, Final residual = 0.00421935, No Iterations 3
    time step continuity errors : sum local = 7.82336e-06, global = -1.9955e-20, cumulative = -1.9955e-20
    Pressure gradient source: uncorrected Ubar = 0.13349, pressure gradient = 0.000114208
    GAMG:  Solving for p, Initial residual = 0.0563421, Final residual = 0.000354153, No Iterations 4
    time step continuity errors : sum local = 9.75747e-07, global = 2.11991e-20, cumulative = 1.24408e-21
    Pressure gradient source: uncorrected Ubar = 0.133489, pressure gradient = 0.000117378
    GAMG:  Solving for p, Initial residual = 0.0152771, Final residual = 8.66768e-07, No Iterations 18
    time step continuity errors : sum local = 2.28999e-09, global = -1.80834e-20, cumulative = -1.68393e-20
    Pressure gradient source: uncorrected Ubar = 0.133489, pressure gradient = 0.00011696
    ExecutionTime = 4.61 s  ClockTime = 5 s
    Time = 0.2
    Courant Number mean: 0.731698 max: 1.1641
    GAMG:  Solving for p, Initial residual = 0.75843, Final residual = 0.00508023, No Iterations 3
    time step continuity errors : sum local = 6.71701e-06, global = 1.79247e-12, cumulative = 1.79247e-12
    Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 0.000119141
    GAMG:  Solving for p, Initial residual = 0.0716405, Final residual = 0.000689194, No Iterations 5
    time step continuity errors : sum local = 5.93336e-07, global = 1.79247e-12, cumulative = 3.58494e-12
    Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 0.000117204
    GAMG:  Solving for p, Initial residual = 0.014621, Final residual = 9.75203e-07, No Iterations 25
    time step continuity errors : sum local = 8.46786e-10, global = 1.79247e-12, cumulative = 5.37741e-12
    Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 0.000116758
    ExecutionTime = 9.1 s  ClockTime = 9 s
    上面是4核,下面8核
    Time = 0.1
    GAMG:  Solving for p, Initial residual = 0.629703, Final residual = 0.00603973, No Iterations 3
    time step continuity errors : sum local = 1.11982e-05, global = 8.06587e-21, cumulative = 8.06587e-21
    Pressure gradient source: uncorrected Ubar = 0.13349, pressure gradient = 0.000114193
    GAMG:  Solving for p, Initial residual = 0.0566187, Final residual = 0.00046644, No Iterations 4
    time step continuity errors : sum local = 1.28491e-06, global = -2.9891e-20, cumulative = -2.18251e-20
    Pressure gradient source: uncorrected Ubar = 0.133489, pressure gradient = 0.000117396
    GAMG:  Solving for p, Initial residual = 0.0153571, Final residual = 7.70794e-07, No Iterations 20
    time step continuity errors : sum local = 2.0346e-09, global = -1.94705e-20, cumulative = -4.12956e-20
    Pressure gradient source: uncorrected Ubar = 0.133489, pressure gradient = 0.000116978
    ExecutionTime = 5.64 s  ClockTime = 6 s
    Time = 0.2
    Courant Number mean: 0.731698 max: 1.16413
    GAMG:  Solving for p, Initial residual = 0.75841, Final residual = 0.00736995, No Iterations 3
    time step continuity errors : sum local = 9.74458e-06, global = 8.78067e-13, cumulative = 8.78067e-13
    Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 0.000119176
    GAMG:  Solving for p, Initial residual = 0.073429, Final residual = 0.000652992, No Iterations 6
    time step continuity errors : sum local = 5.62596e-07, global = 8.78067e-13, cumulative = 1.75613e-12
    Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 0.000117203
    GAMG:  Solving for p, Initial residual = 0.0147366, Final residual = 9.38466e-07, No Iterations 23
    time step continuity errors : sum local = 8.14733e-10, global = 8.78067e-13, cumulative = 2.6342e-12
    Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 0.000116759
    ExecutionTime = 11.02 s  ClockTime = 11 s
    CPU:  AMD Opteron(tm) Processor 6376
    OS:   debian 10
    OpenFOAM: 8
    # cores   Wall time (s):
    64 164.29
    32 180.06
    16 305.33
    8 407.37
    4 800.44
    2 1981.19
    1 3383.18
    CPU: Intel(R) Xeon(R) Platinum 8175M
    OS:  ubuntu 18.04
    OpenFOAM: 8
    48 77.08
    24 99.2
    12 123.14
    6 234.82
    3 366.02
    1 1149.63
    CPU: Intel(R) Xeon(R) E5-2683
    OS:  ubuntu 14.04
    OpenFOAM: 8
    28 224.8
    14 214.99
    8 246.61
    4 383.36
    2 721.88
    1 1361
    @bestucan 8175这个可以按照12468163248这个跑一遍不 跟我那个表格里面对不上不好放进去:huahua:
    bestucanB 2 条回复 最后回复
    @东岳 好的,我回去后就试:huahua:
    @东岳
    OS:  ubuntu 18.04
    OpenFOAM: 8
    48 76.67
    32 87
    16 132.63
    8 167.32
    6 234.28
    4 312.67
    2 573.06
    1 1124.36
    @bestucan 已更新 数据挺好的
    ustbwenwuU 1 条回复 最后回复
    在 中回复了 来瓶热阔落 最后由 编辑
    @来瓶热阔落 我最近在测试也发现了这个问题 你换PCG算压力方程试试?但这样跟别的就没有可比性了。但可以看看结果。
    一些CPU确实存在这个问题,目前我没有解决办法,只能加在CPU黑名单里 :135:
  • ustbwenwuU 离线
    ustbwenwuU 离线
    ustbwenwu
    CPU: EPYC 7402 x 2
    OS:  ubuntu 18.04
    OpenFOAM 7
    48 65.01
    32 68.3
    16 84.09
    8 140.9
    4 283.94
    2 568.89
  • ustbwenwuU 离线
    ustbwenwuU 离线
    ustbwenwu
    在 中回复了 ustbwenwu 最后由 编辑
    @东岳
    #38
    @ustbwenwu 多谢,已更新 :140:
  • T 离线
    T 离线
    TINGHAIK
    win10_bash ubuntu18.04
    CPU:  i7-9750H
    RAM: 16G
    OpenFOAM-6
    8 842.92
    4 838.84
    2 846.9
    1 1414.95
    感觉有问题啊:143:
    心血来潮测一下服务器 为什么会有这样的error 提示? of41能做么
    No MRF models present
    Creating finite volume options from "constant/fvOptions"
    Selecting finite volume options model type meanVelocityForce
    [0]
    [0]
    [0] --> FOAM FATAL IO ERROR:
    [0] keyword meanVelocityForceCoeffs is undefined in dictionary "/home/local.njord/maosui/benchMark/core_8/constant/fvOptions.momentumSource"
    [0]
    [0] file: /home/local.njord/maosui/benchMark/core_8/constant/fvOptions.momentumSource from line 20 to line 25.
    [0]
    [0]     From function const Foam::dictionary& Foam::dictionary::subDict(const Foam::word&) const
    [0]     in file db/dictionary/dictionary.C at line 642.
    [0] [2]
    [2]
    [2] --> FOAM FATAL IO ERROR:
    [2] keyword meanVelocityForceCoeffs is undefined in dictionary "IOstream.momentumSource"
    [2]
    ubuntu18.04
    CPU: AMD EPYC 7282 16-Core Processor*2
    RAM: 252G
    OpenFOAM-4.1
    32 82.4
    16 121.69
    8 140.26
    4 268.85
    2 498.06
    1 1125.41
    感谢大家 已更新主表
    在 中回复了 TINGHAIK 最后由 编辑
    @TINGHAIK 虚拟机的都特别慢 bash的应该也会受影响
    jowong
    CPU型号:i7-7700
    系统:linux系统
    OpenFOAM版本:OpenFOAM-8
    4 594.83
    2 666.07
    1 956.33
  • F 离线
    F 离线
    Fu
    CPU型号: Intel(R) Xeon(R) Gold 6248R
    系统:ubuntu 18.04
    版本:openfoam-8
    48 98.12
    32 96.14
    16 128.01
    8 155.18
    4 304.95
    2 542.82
    1 1068.49
    没关超线程,物理核48 感觉不合理啊哈哈 明天再弄一次:136:
  • cfd_xfxC 离线
    cfd_xfxC 离线
    cfd_xfx
    中午在服务器上测试了一下这个算例,发现算例受核间通信的影响确实很大,在核心数较高时计算时长的收益很小甚至负收益==
    以及8164是老cpu了吧,单核计算能力捉急。。
    CPU型号: Intel(R) Xeon(R) Platinum 8164 CPU @ 2GHz (8)
    系统:    Ubuntu 18.04.5 LTS
    内存:  791160068 kB
    OpenFOAM版本:OpenFOAM-6
    192 149.49
    128 51.77
    64 48.97
    32 64.36
    16 111.44
    8 153.07
    4 338.46
    2 611.9
    1 1249.7```
    逢山开路,遇水架桥
    对流换热强化
