  3. New scalar in phaseModel.c
30 帖子 3 发布者 24.8k 浏览
    在 中回复了 kimy 最后由 编辑
    @kimy do it slowly.
    1 find a normal case which works well. ensure basement is good
    2 add myBeta() only, and not use it. ensure compile works
    3 use cout << myBeta() << "somg flag". ensure function myBeta() works.
    4 use myBeta_ as a constant value in calculation. ensure framework is well.
    5 use myBeta_ as variable
    divide int more step if needed
    then use it as your wish. special case, special solver. If something wrong. there's nothing to do with myBeta(). maybe case? maybe solver? maybe variable overflow?
    you combine all steps into one step. it's hardly to debug.
    have you print myBeta_ value? just same as the value in case file?
    the error message seems not a special error. something about cout (Ostream&)
    K 1 条回复 最后回复
  • K 离线
    K 离线
    kimy
    在 中回复了 bestucan 最后由 kimy 编辑
    @bestucan Thanks. Your suggestions are very helpful. However, the solver met the same error mentioned before. I uploaded my solver and case files. Hope you can see them if you wish (I cannot upload). I modified the solver based on twophaseeulerfoam.
  • K 离线
    K 离线
    kimy
    2020twoPhaseEulerFoam.zip
    I've tried. seems like your OpenFOAM version is different with mine. my version is 8
    K 1 条回复 最后回复
  • K 离线
    K 离线
    kimy
    @bestucan Thanks a lot. What you mean is that you did not meet any problem in your OpenFOAM version? Could you please upload the whole modified solver files here (twophaseeulerfoam)? The files I uploaed above was copied from blueCFD (maybe openfoam 5). Additionally, I am also using HPC where openfoam-v1906 is loaded.
  • K 离线
    K 离线
    kimy
    This is the solver file of openfoam_v1906
    slurrypipebendsolver.zip
  • K 离线
    K 离线
    kimy
    I have already reached my goal in another way. Thanks for all helps.
    coagulation. complex for me to compile your solver. downloading and compiling openfoam 5 and openfoam v1906 cost lot of time. and several source file end with ".T.C" hadn't been upload.
    emmm..... not a good way to debug.:mihu: we have different OS and different environment.
    anyway, you've solved the problem.:high:
    李东岳李 K 2 条回复 最后回复
    @bestucan Thanks for tracking this issue :xiexie:
    bestucanB 1 条回复 最后回复
    @东岳 :xinxin2:
  • K 离线
    K 离线
    kimy
    @bestucan Thanks for your attention.
