  3. OpenFOAM有方法能够使一部分网格不参与计算吗?
29 帖子 10 发布者 26.7k 浏览
    Samuel-Tu
    @东岳 嗯嗯,就是考虑怎么在流固交界面上把壁面剪切力修正一下
    借鉴一下沉浸边界的思路?
  • 马乔马 离线
    马乔马 离线
    马乔 大神
    #include "fvCFD.H"
    #include "pisoControl.H"
        argList::addNote
            "Transient solver for incompressible, laminar flow"
            " of Newtonian fluids."
        #include "postProcess.H"
        #include "addCheckCaseOptions.H"
        #include "setRootCaseLists.H"
        #include "createTime.H"
        #include "createMesh.H"
        pisoControl piso(mesh);
        #include "createFields.H"
        #include "initContinuityErrs.H"
        Info<< "\nStarting time loop\n" << endl;
        DynamicList<label> lowerFaceCells(mesh.C().size());
        DynamicList<label>  upperFaceCells(mesh.C().size());
        //mesh LDU address
        const labelUList& lowAddr = mesh.lduAddr().lowerAddr();
        const labelUList& upAddr = mesh.lduAddr().upperAddr();
        if(mesh.cellZones().size())
    	const cellZone& cellBlock = mesh.cellZones()[0];
    	Info << "cell block size: " << cellBlock.size() << endl;
    	Info << cellBlock << endl;
    	//low efficient
    	forAll(lowAddr, faceI)
    	    for(auto cellI : cellBlock)
    		if(lowAddr[faceI] == cellI)
    		    lowerFaceCells.append(faceI);
    		if(upAddr[faceI] == cellI)
    		    upperFaceCells.append(faceI);
        lowerFaceCells.shrink();
        upperFaceCells.shrink();
        Info << "low Cells size: " << lowerFaceCells.size() << ", low Cells size: " << upperFaceCells.size() << endl;
        while (runTime.loop())
            Info<< "Time = " << runTime.timeName() << nl << endl;
            #include "CourantNo.H"
            // Momentum predictor
            fvVectorMatrix UEqn
                fvm::ddt(U)
              + fvm::div(phi, U)
              - fvm::laplacian(nu, U)
    	//modify matrix
    	    const cellZone& cellBlock = mesh.cellZones()[0]; //should select cellZone accor name
    	    scalarField& lower = UEqn.lower();
    	    scalarField& upper = UEqn.upper();
    	    scalarField& diag = UEqn.diag();
    		diag[cellI] = 1.;
    		UEqn.source()[cellI] = vector::zero; //vector(0.,0.,0.); you can set your deserved value here, or read from dict, ref. fvoptions
    	    for(auto faceI : lowerFaceCells)
    	 	lower[faceI] = 0.;
    	    for(auto faceI : upperFaceCells)
    	 	upper[faceI] = 0.;
    	else
    	    Info << "There is no cell selected" << endl;
            if (piso.momentumPredictor())
                solve(UEqn == -fvc::grad(p));
            // --- PISO loop
            while (piso.correct())
                volScalarField rAU(1.0/UEqn.A());
                volVectorField HbyA(constrainHbyA(rAU*UEqn.H(), U, p));
                surfaceScalarField phiHbyA
                    "phiHbyA",
                    fvc::flux(HbyA)
                  + fvc::interpolate(rAU)*fvc::ddtCorr(U, phi)
                adjustPhi(phiHbyA, U, p);
                // Update the pressure BCs to ensure flux consistency
                constrainPressure(p, U, phiHbyA, rAU);
                // Non-orthogonal pressure corrector loop
                while (piso.correctNonOrthogonal())
                    // Pressure corrector
                    fvScalarMatrix pEqn
                        fvm::laplacian(rAU, p) == fvc::div(phiHbyA)
                    pEqn.setReference(pRefCell, pRefValue);
    		//modify p matrix
    		    //p matrix symmetry
    		    scalarField& offDiag = pEqn.hasUpper() ? pEqn.upper() : pEqn.lower();
    		    scalarField& diag = pEqn.diag();
    			diag[cellI] = 1.;
    			pEqn.source()[cellI] = 0.;
    		    //for(auto faceI : upperFaceCells) //should find faces again?
    		    //    offDiag[faceI] = 0.;
    		    const labelUList& offAddr = pEqn.hasUpper() ? pEqn.lduAddr().upperAddr() : pEqn.lduAddr().lowerAddr();
    		    forAll(offAddr, faceI)
    			    if(offAddr[faceI] == cellI)
                    pEqn.solve(mesh.solver(p.select(piso.finalInnerIter())));
                    if (piso.finalNonOrthogonalIter())
                        phi = phiHbyA - pEqn.flux();
                #include "continuityErrs.H"
                U = HbyA - rAU*fvc::grad(p);
                U.correctBoundaryConditions();
            runTime.write();
            runTime.printExecutionTime(Info);
        Info<< "End\n" << endl;
        return 0;
    toposetDict
    actions
        // porousBlockage
            name    porousBlockageCellSet;
            type    cellSet;
            action  new;
            source  boxToCell;
            box     (0.04 0.04 -1) (0.06 0.06 1);
            name    porousBlockage;
            type    cellZoneSet;
            action  new;
            source  setToCellZone;
            set     porousBlockageCellSet;
    :wocao:
    装逼没输过,吵架没赢过!
    Samuel-Tu
    @cccrrryyy 对,现在我用的就是浸入边界法
    Samuel-Tu
    在 中回复了 马乔 最后由 编辑
    @马乔 这是建立了一个集合,然后对这个集合赋予不同的粘度吗
  • 马乔马 离线
    马乔马 离线
    马乔 大神
    modify the matrix, set the value of p and U as 0.
    装逼没输过,吵架没赢过!
    我 1 条回复 最后回复
    在 中回复了 Samuel-Tu 最后由 编辑
    @Samuel-Tu 沉浸边界法流体域和固体域都计算吧?我记得它的核心思想就是把固体域也囊括到流体域的计算里面,通过修改计算域的控制方程(类似于NS方程的一个东西?),是的计算域内某一部分的表征是固体某一部分的表征是流体。如果你是想让计算域中其中一部分不参与计算,那和普通的只计算流体域不计算固体域(固体域作为流场边界)的区别是什么呢?挺好奇的。
    Samuel-Tu
    @cccrrryyy 浸入边界法其中的一种方法是加入附加体积力,确实如你所说是所有计算域都会计算,只是原本的固体域由于附加体积力的影响形成旋涡,不与流体域发生质量交换了,相当于就是固体了。
    所以说你这个做的应该不是这个体积力的东西,是另外一种了。有什么参考文献可以分享一下么?我很好奇别的处理是什么样子的:chouchou:
    S O 2 条回复 最后回复
    Samuel-Tu
    @cccrrryyy 我现在做的就是体积力的方法,我在想有没有其他办法。。
  • 我 离线
    我 离线
    我是河滩
    在 中回复了 马乔 最后由 编辑
    @马乔 在 OpenFOAM有方法能够使一部分网格不参与计算吗? 中说:
    可以给出一些有关矩阵修改的参考文献吗?目前也需要对一些给定单元赋值(通过周围正常求解网格单元的值进行插值),OpenFoam中的fixedinternalValue边界条件也有类似功能,但不是很理解。
    动边界
    (Sorry, I don't have chinese input right now)
    I once had the exactly same issue!
    Check my thesis Chapter 6.3 :
    https://scholar.uwindsor.ca/cgi/viewcontent.cgi?article=8585&context=etd
    I wrote a paper in this: https://ascelibrary.org/doi/pdf/10.1061/9780784415153.ch06
    Figure 2 is the original plate. (Sorry due to copy-right reason, I cannot put it here.)
    In my thesis, I had to open the plate with some holes in ICEM. So, I maual dig out the block out of the computation domain.
    It's really a painful process.
    But it works!
    This is the original plate:
    This is after the "dig":
            fvVectorMatrix UEqn
                fvm::ddt(U)
              + fvm::div(phi, U)
            // 固定值
            labelList cells = mesh.cellZones()["null"];
            vectorField value(cells.size(), Zero);
            UEqn.setValues(cells, value);
    可以通过设定一个null区域,然后对区域的网格点强行赋值,但就像我之前说的,总觉得边界处需要处理。也就像 @cccrrryyy 说的,变成了浸没边界法。这个代码只是大体上是个思路,需要更深的研究。可以看看fvOptions里面一些源项的处理,都是操纵矩阵的,比如fixedTempresure,meanVelocityForce等,
    Samuel-Tu
    @东岳 嗯嗯,我试一下看看能不能行。我记得setVAlue是切断了相邻面上的联系。我处理下剪切力试试
    Samuel-Tu
    @random_ran 主要的,我的边界随时要改变。这样的话就会一直改网格,有点像自适应网格了。。
  • O 离线
    O 离线
    OItoCFD
    @cccrrryyy 他现在这个方法属于cut cell方法的一种吧 我也今天刚要尝试 在固体切割网格的地方要特殊处理 然后当固体是运动时候 为了保持质量守恒 要对连续性方程修正一下减去一个固体相对速度 详情见这篇论文:A fixed-grid model for simulation of a moving body in free surface flows
    最近把理论这部分弄了一下,
