  3. VMware Ubuntu1804
VMware Ubuntu1804
26 帖子 5 发布者 22.3k 浏览
    准备工作还需要进行这一步:
    sudo apt-get install curl
    P 小 3 条回复 最后回复
  • P 离线
    P 离线
    Peng
    @东岳 搞定啦,正在下载,编译,谢谢!
    现在是官方支持ParaView 5.7了么,为什么自动下载的是5.7,还是您哪里做了些改动呢。。。昨天我自己编译安装下载的是5.6
    官方的5.7
    P 1 条回复 最后回复
  • P 离线
    P 离线
    Peng
    @东岳 4K 高分屏幕,paraview里面图标和标题栏太小,促使我想换个新版本试试这个问题有没有解决
  • P 离线
    P 离线
    Peng
    @东岳 谢谢:xinxin:
    在 中回复了 Peng 最后由 编辑
    @Peng 在 VMware Ubuntu1804 中说:
    我18年的时候用的paraview就解决了啊,忘记什么版本了
    现在肯定解决了,
  • P 离线
    P 离线
    Peng
    @东岳 在 VMware Ubuntu1804 中说:
    @东岳 睡醒一觉发现又出问题了,编译不过去。。。,问题如下:
    CMake Error at /home/dyfluid/OpenFOAM/ThirdParty-7/ParaView-5.7.0/CMake/ParaViewClient.cmake:526 (message):
      Failed to convert servermanager XML: xmlpatterns: could not exec
      '/usr/lib/qt5/bin/xmlpatterns': No such file or directory
    make[2]: *** [Plugins/AcceleratedAlgorithms/CMakeFiles/AcceleratedAlgorithms_doc.dir/build.make:66: Plugins/AcceleratedAlgorithms/paraview_help/AcceleratedAlgorithms_doc.xslt] Error 1
    make[1]: *** [CMakeFiles/Makefile2:23530: Plugins/AcceleratedAlgorithms/CMakeFiles/AcceleratedAlgorithms_doc.dir/all] Error 2
    make[1]: *** Waiting for unfinished jobs....
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/internal/VariantArrayHandleContainer.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/Field.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/FieldRangeCompute.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/FieldRangeGlobalCompute.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/MultiBlock.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/PointLocator.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/PointLocatorUniformGrid.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/RuntimeDeviceInformation.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/StorageVirtual.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/Timer.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/serial/internal/ArrayManagerExecutionSerial.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/serial/internal/DeviceAdapterAlgorithmSerial.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/serial/internal/DeviceAdapterRuntimeDetectorSerial.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/serial/internal/ExecutionArrayInterfaceBasicSerial.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/tbb/internal/DeviceAdapterRuntimeDetectorTBB.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/openmp/internal/DeviceAdapterRuntimeDetectorOpenMP.cxx.o
    [  6%] Building CXX object VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/cont/CMakeFiles/vtkm_cont.dir/cuda/internal/DeviceAdapterRuntimeDetectorCuda.cxx.o
    [  6%] Linking CXX static library ../../../../../../../lib/libvtkm_cont-pv5.7.a
    [  6%] Built target vtkm_cont
    make: *** [Makefile:130: all] Error 2
    Command exited with non-zero status 2
    472.23user 51.13system 4:37.84elapsed 188%CPU (0avgtext+0avgdata 574040maxresident)k
    113184inputs+294992outputs (214major+9706377minor)pagefaults 0swaps
    P 1 条回复 最后回复
  • P 离线
    P 离线
    Peng
    @同学博 @东岳
    Ubuntu 18 永久设置分辨率1920x1080:
    https://blog.csdn.net/geekqian/article/details/82965319
    这个帖子亲测有效
  • P 离线
    P 离线
    Peng
    在 中回复了 Peng 最后由 编辑
    @东岳 东岳老师,重新按照教程里的步骤(http://dyfluid.com/docs/install.html :2.2. 编译版paraFoam)编译安装成功了,但是安装的是paraview 5.6.0,而不是5.7.0。
    问题是Layout内的图标太小,看不清。如图所示:WeChat Screenshot_20200104195442.png
    用的电脑是 Microsoft Surface Studio,如何解决这个问题呢?
    同学博同 1 条回复 最后回复
    那几个图标就是那么大的,你经常用那几个图标么?
    P 1 条回复 最后回复
  • P 离线
    P 离线
    Peng
    @东岳 好吧,那就这样吧:papa:
  • 同学博同 离线
    同学博同 离线
    同学博
    在 中回复了 Peng 最后由 编辑
    @Peng 才看到 谢谢!:baobao:
  • 小 离线
    小 离线
    小火人
    @李东岳 2021-10-05 00 28 15.png 东岳老师,我在ubuntu-16.04.6-desktop-i386上面安装of-8,在编译paraview时提示这个异常,查了好久仍没弄明白,想请教下:140:
    另外有个疑问,就是我看paraview官网都是64位的,i386的ubuntu不能使用paraview吗?我下载解压后,双击bin\paraview没反应:haqi:
    在 中回复了 小火人 最后由 编辑
    @小火人 为什么不直接用绿色版paraview呢
